Default auto reply trigger failure
  • Used Zammad version: 3.1
  • Used Zammad installation source: Source
  • Operating system: ubuntu
  • Browser + version: Google Chrome Version 77.0.3865.90 (Official Build) (64-bit)
  • When receiving a new email from a custormer, the system should reply with with the auto reply email.
  • Currently no email is being sent. In the logs we find the following entries:
I, [2019-10-02T15:07:11.653703] INFO – : fetching imap (google mail server/system@mydomain.net port=993,ssl=true,starttls=false,folder=SupportChannels/BYD,keep_on_server=false)
I, [2019-10-02T15:07:13.026208] INFO – : - message 1/1
I, [2019-10-02T15:07:13.787672] INFO – : Process email with msgid ‘000f01d57932$ff1130a0$fd3391e0$@customerdomain.com
I, [2019-10-02T15:07:13.833009] INFO – : Enqueued SearchIndexJob (Job ID: af306554-4549-4632-bdd3-eba183f2c10d) to DelayedJob(default) with arguments: “User”, 10
I, [2019-10-02T15:07:14.858205] INFO – : Can’t fetch image for ‘customer1@customerdomain.com’ (maybe no avatar available), http code: 422
I, [2019-10-02T15:07:14.883338] INFO – : set_attributes_by_x_headers header x-zammad-ticket-customer_id found. Assign customer_id=10
I, [2019-10-02T15:07:14.913393] INFO – : set_attributes_by_x_headers header x-zammad-article-preferences found. Assign preferences={“send-auto-response”=>false, “is-auto-response”=>true}
I, [2019-10-02T15:07:15.059686] INFO – : Skip trigger (auto reply (on new tickets) - AWS/1) because sender do not want to get auto responder for object (Ticket/23/Article/60)
I, [2019-10-02T15:07:15.067774] INFO – : Skip trigger (Auto reply (on new tickets) - BYD/4) because sender do not want to get auto responder for object (Ticket/23/Article/60)
we don’t know if our current mail setup is the cause, since we use a single mail account in google for business and have the system read diferent folders to get the emails for each mail queue.
Our mail setup is like this:
Customer email —> Mailing group —> systemaccount —> clasification rule to asign to a folder (label)
Zammad uses the expert setting to read from the folders/labels to import email into zammad.
I saw a similar case but here is the link to it: Link
but I’m usign differente domains…
  • Install zammad per documentation on ubuntu 18.04
  • configure zammad to use email channels using gmail
  • configure groups and assign email address and signature
  • clone default trigger and personalize it for each group
  • disable the default trigger.
what’s more my fdqn is https://pruebasoporte.cibernetica.xyz and the email domain is cibernetica.net.
Best,
Javier
Please ensure:
  • to test this functionality with a customer account or a mail address that is not assigned to any agent
  • that the imported mail in question above is no notification mail from Zammad
  • the used mail account to send this mail is not a mail account from Zammad
If you could verify the above successfully (so this is not the cause), please send a test mail to your Zammad. Please provide the eml of that sent mail for us to check.
You may remove personal information to ensure privacy, however, please ensure to keep headers in takt and meaningful, other wise it will be impossible for us to help you.
If possible, also prove the logfile from the time you sent the mail until the moment Zammad (if it did) notified you about a new ticket.
Hi MrGeneration,
  1. I have tested this with two (2) diferent email accounts not assigned to any agents
  2. The email account is not a notification mail from zammad
  3. The email account is not a mail account from zammad.
here is the eml file:
Delivered-To: system@cibernetica.net
Received: by 2002:a2e:744:0:0:0:0:0 with SMTP id i4csp1026329ljd;
        Wed, 2 Oct 2019 08:06:45 -0700 (PDT)
X-Received: by 2002:a17:90a:a504:: with SMTP id a4mr4803214pjq.16.1570028805240;
        Wed, 02 Oct 2019 08:06:45 -0700 (PDT)
ARC-Seal: i=3; a=rsa-sha256; t=1570028805; cv=pass;
        d=google.com; s=arc-20160816;
        b=hpga9ogv17ovmrPyW3Umj4p+VWYotXDKmGas13G1FmYMSActBgWl0HokwP3R3iyLGx
         szVNnOPDMIXtAicuHNOcrvTJqvKY6Km96Ro4d3iHc+eKViXqMIxckbjtvjqq/Fb8BtVS
         CyjFvPyqjBx3A2cgZvkG0XWaH2LHqhZPpjr999d0Xu9Wp/Nr4DKQNCb5V8T9sN3k+rHd
         Y5opD288uDr86nWkz2v0ExO5F5Ppwd/lJcO66q6sg+IAJzAFA/A9HRPiqbFVDd9SJaSb
         9BRNl+/LFx8mp7ecZvz79s0EfSVpJoPd24OTLy51qGxIUG6pfJym5bub7KY9hqC5+Wxr
         UFHg==
ARC-Message-Signature: i=3; a=rsa-sha256; c=relaxed/relaxed; d=google.com; s=arc-20160816;
        h=list-help:list-id:mailing-list:precedence:content-language
         :thread-index:mime-version:message-id:organization:date:subject:to
         :from:dkim-signature;
        bh=c0rAdIUzJfJSEM+2hjJBESheWaa6w61Vdn2H5FWMV8I=;
        b=k8K4Q125PfbaW8+UtnmIqlKW0ucM7XPcesy+1QyKuBdwrG4iXtDGO8tS5+fkJ3s856
         gHtNkjsxFIniumi1VL52a88jhW2is24bGeXegVB4EZLxWMb0Kc8iDX0udwbzRiMKaAF+
         zKhLa53jZqohxs/7Pm2T/CiHyLKN9gZwf2jcnFKtyZwIEltux2mNfyBWASzcsv+uZa9Y
         O/zdAJpxoPOhtczwUb9ksjGAXQY0KfuiKqhylj68r6mJKG8SE61hB1EAS9D4g46HlHod
         urB0ym2jLRaBSNK+BfpQozwHs+upEx0kLfAUAQp/uW92izwisJOo8Pim7znQTZNLza+R
         DCsg==
ARC-Authentication-Results: i=3; mx.google.com;
       dkim=pass header.i=@cibernetica-net.20150623.gappssmtp.com header.s=20150623 header.b=piprC6pH;
       arc=pass (i=2 spf=pass spfdomain=multimedpma.com);
       spf=pass (google.com: domain of soportebyd+bncbaabbbh22lwakgqegum2jsq@cibernetica.net designates 209.85.220.69 as permitted sender) smtp.mailfrom=soportebyd+bncBAABBBH22LWAKGQEGUM2JSQ@cibernetica.net
Return-Path: <soportebyd+bncBAABBBH22LWAKGQEGUM2JSQ@cibernetica.net>
Received: from mail-sor-f69.google.com (mail-sor-f69.google.com. [209.85.220.69])
        by mx.google.com with SMTPS id h6sor21611495plk.48.2019.10.02.08.06.44
        for <system@cibernetica.net>
        (Google Transport Security);
Received-SPF: pass (google.com: domain of soportebyd+bncbaabbbh22lwakgqegum2jsq@cibernetica.net designates 209.85.220.69 as permitted sender) client-ip=209.85.220.69;
Authentication-Results: mx.google.com;
ARC-Seal: i=2; a=rsa-sha256; t=1570028804; cv=pass;
        b=b7ZEJ57eeE8t1GYpxl18MzMre+rdFpBsnRABBBEv5YlRlIL2KoKLhMxHQ6f/wvurBy
         xz2OPJVQA5uqT/JqvvjJlNaf2D5BYruRtmHzc+OThIIQlwJsaipDOH4d1H+c4rH5deMS
         b7mYn1HG9/gaqs3qiTiSIrJmLs+oskADk5Qu7jTBz7mxSvPSPi8bBH0LiCkZoG6dokbH
         sTTUmFD7+5Q6SXcV9qDGe7XoEhjfE0KoH/fPrShMP44BmVGmF6C6VwTt5WjoE+90PHhq
         dkgFkNi/kBnsbC1U26Dgi5mK91iD85zB+jYabG+Tdfi9SqHNUKxacxCwWYVF/W2SPFoy
         e8SQ==
ARC-Message-Signature: i=2; a=rsa-sha256; c=relaxed/relaxed; d=google.com; s=arc-20160816;
        b=Y9hv3Hj5hKxjilR8+qMaP54QmjPyUeTkQNJoX4FyeALTfYzXNkVeYHUpz/FVNky765
         W2590pojBzMkUaJkK8M/1p0peSGZL+ZzV3RJcdB+GdbBh3n8potMGV0mZ100Ksa9CpZ0
         ELinn1qWGGwWCo7vuhv2suJU/0pKmtAE9ZRSAIsJ2Yq5aBjr1KyN/IJNvg0XgWK85A2x
         PLr3d2gCY75ABbANdV3T27ttNZR9YtghJVnRVUAEGtcRd3LGMD+1TT8pAmzYKAZJgDpA
         13IXMHXgyUAXcaIGPWkWeiHQnyOD2joMG4lT2xJc7TvcRaGDyDfQuZRG8mRv7fzZNAWS
         u2kA==
ARC-Authentication-Results: i=2; mx.google.com;
       spf=pass (google.com: domain of lmiranda@multimedpma.com designates 173.201.192.109 as permitted sender) smtp.mailfrom=lmiranda@multimedpma.com
DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed;
        d=cibernetica-net.20150623.gappssmtp.com; s=20150623;
        h=from:to:subject:date:organization:message-id:mime-version
         :thread-index:content-language:x-original-sender
         :x-original-authentication-results:precedence:mailing-list:list-id
         :list-help;
        b=piprC6pHHPomRoyn5BGtEiayBrHyspvAPZLnCTkDMEMBkgX3xJncGnqQcg3VRo3Bic
         hjAsTHbo2dCwc9EPVxbOtYVs9QZYfGfVTPIvBmXAYsaTLi/ta3f2Ak/r6uMXd50bG1/s
         55KohRo26IYKboFd2h1S2uyCsmA9GgCiJhJ4BjHrc4fcTe2PJJRAgv3k2Ya+Ni9SDVhA
         6DiQq2U/fJJxTEBMLbzFJ5TIdKNVP8hwL3n6LksRM0rA87uf2Blss6O6ORL2dMVc6FO+
         xa3JJjoqCjeMZcz7N0K0iMAsGTqLKBe2CCYrOXep/WtKPOA0XEsg5tIkzuwb84/jpUnR
         hb/g==
X-Google-DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed;
        d=1e100.net; s=20161025;
        h=x-gm-message-state:from:to:subject:date:organization:message-id
         :mime-version:thread-index:content-language:x-original-sender
         :x-spam-checked-in-group:list-help;
        b=czVGGW985zMVYGlYAKvsayG0SGf9imlYMD0KYokCDNRofw42zLmwTUxjm71R/8OWLn
         LvdRHr0e5p3k97gHSRQa1BILuW5sS3HJ5xc2iqe7YLgQI8hI2sxJtlTWtZGvOi9rqHQr
         lPno39lPjJ3cKeB140/9wbdKoNpjYhjp0AMXUmxxeFj+xBkbsC5wkhl3ITeu6gpWTaWY
         CRok6z+XMWjtP0TOYmZGe6MmsKdA3MzeCaQSnnNrYRmBcuw75JNss+SXDGYgYeE+bO0Z
         KuqQjJddXzpxW4KMTu/S/AkN/Aec9jzEgxZrYRBCkkn2Ll1qqj8wiRJo6tIJ+u/OsZU0
         yv5g==
X-Gm-Message-State: APjAAAV0UqKb0kiUn1qOUzpamm17yO24gJz0fOmKFtHCfQjU1Wn3q/fB
	2J/Fnbn1cXH1xcLvyk9gx8Xl0Q==
X-Google-Smtp-Source: APXvYqxY/7CmhixUxHWDY/2FgQZtSOoo3+BY2cYbU5HB4icNMnz1TkiRovJ0FZobbDRRQ78ikqP+IQ==
X-Received: by 2002:a17:902:82c8:: with SMTP id u8mr4281743plz.38.1570028804631;
        Wed, 02 Oct 2019 08:06:44 -0700 (PDT)
X-BeenThere: soportebyd@cibernetica.net
Received: by 2002:a17:90a:c086:: with SMTP id o6ls665775pjs.4.canary-gmail;
X-Received: by 2002:a17:90a:da06:: with SMTP id e6mr4704758pjv.92.1570028804216;
ARC-Seal: i=1; a=rsa-sha256; t=1570028804; cv=none;
        b=WsJ1vKZOX/GefSipi5y8FyJYdEe6xqozLaCov5yM5jm/7hTZ9k0MLWh9gYokkvdG6b
         JLfOVWslAlsxZx0P5mM6cUF8Dk6U3aFShwQcC0HPU0mEg9/iQMsZ2ocUH+nTY71NIHaA
         L9dn274NStDAPaHTz4QbLQe7t9lyvZOKPHXrWZD3eB30WU7YPGLGDHGE2EKJcDdtD0Wh
         l74RRlbsKFh4scxXmHuRM6Puy/b7T+fpe8TdXiYaPz7etwUSAWwCHdVoAQKyjN3iyj8C
         mwy5yUZZciN2Hv0W1cchHiRMLxR8ffqsQsydlI9potQgVP3lJY1nUCEvAwYnTxeRmCrR
         Pi5g==
ARC-Message-Signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=google.com; s=arc-20160816;
        h=content-language:thread-index:mime-version:message-id:organization
         :date:subject:to:from;
        bh=1cPCtweuvJ/+ooDiV6LG/4k54XE8GL4iDn4/FEjxdds=;
        b=VkeeyOtaLF6Wy5PD4Topi658KhB8ByiGV3S/yb17vVh6luyrTlMzcAiPrqGeZgedS7
         JgF0rnHPpjubC7SQXh6U9ygt4SFchWDldQIQEbZef8/G2bfab4aZzbjR4ovMSzcwAjPW
         0ff7NQKRsg0yO/ACfHGtXeQxMGmU5vo9TBJ91KI5HO//+JX4tKqZgGpdn8mlcvttNBpv
         Ptvgs1gBz2vmDFZDZ2Ttf7XE++ZJIfraDfhG7792HPdMFjyL+9uMos40YJ2PEikxwiI0
         Q2flmyV6WI6WfBGv1yNt4DL+bDzXyfo5h2OLtpnBek0r1WxAxc9E56hvSwyOEq2SnZo4
         X5lg==
ARC-Authentication-Results: i=1; mx.google.com;
Received: from p3plsmtpa06-08.prod.phx3.secureserver.net (p3plsmtpa06-08.prod.phx3.secureserver.net. [173.201.192.109])
        by mx.google.com with ESMTPS id x19si21305923pgi.515.2019.10.02.08.06.43
        for <soportebyd@cibernetica.net>
        (version=TLS1_2 cipher=ECDHE-RSA-AES128-GCM-SHA256 bits=128/128);
Received-SPF: pass (google.com: domain of lmiranda@multimedpma.com designates 173.201.192.109 as permitted sender) client-ip=173.201.192.109;
Received: from MULTIMED17 ([200.75.251.102])
	by :SMTPAUTH: with ESMTPA
	id FgDCi29yCHGkNFgDDiYsRR; Wed, 02 Oct 2019 08:06:43 -0700
To: <soportebyd@cibernetica.net>
Subject: Prueba
Date: Wed, 2 Oct 2019 10:06:40 -0500
Organization: Multimed Solutions Panama, Inc.
Message-ID: <000f01d57932$ff1130a0$fd3391e0$@multimedpma.com>
MIME-Version: 1.0
Content-Type: multipart/related;
	boundary="----=_NextPart_000_0010_01D57909.163D7290"
X-Mailer: Microsoft Outlook 14.0
Thread-Index: AdV5Mv48lgYR2WukRCmEgF1a6VFh9w==
Content-Language: es
X-CMAE-Envelope: MS4wfM2N2hzqti9LWEraSHOeT4KZDKCwYDN9znel7U5ISBz9WZ/OtSzrXyxlLgUnWj8EKvXpd+hjFPKtMlYqqLP4v5gY0rqTSBYPtUt1GEiFhPmdK2prirci
 2rcq2mvQoizN0ODYXkaA1dN9Sr71bAdjtdP3ZFAwZti493Bp9SH3jAg3Lm1Sz5YLKVoBqTn2RLYd/g==
X-Original-Sender: lmiranda@multimedpma.com
X-Original-Authentication-Results: mx.google.com;       spf=pass (google.com:
Precedence: list
Mailing-list: list soportebyd@cibernetica.net; contact soportebyd+owners@cibernetica.net
List-ID: <soportebyd.cibernetica.net>
X-Spam-Checked-In-Group: soportebyd@cibernetica.net
X-Google-Group-Id: 652593412501
List-Help: <https://support.google.com/a/cibernetica.net/bin/topic.py?topic=25838>,
 <mailto:soportebyd+help@cibernetica.net>
This is a multipart message in MIME format.
------=_NextPart_000_0010_01D57909.163D7290
Content-Type: multipart/alternative;
	boundary="----=_NextPart_001_0011_01D57909.163D7290"
------=_NextPart_001_0011_01D57909.163D7290
Content-Type: text/plain; charset="UTF-8"
Content-Transfer-Encoding: quoted-printable
=20
=20
Saludos,=20
=20
Laneska Miranda
Regulatorio
+507 229-4530 / +507  229-4529
Urbanizaci=C3=B3n Los Angeles Calle 64B Oeste
Local 25, Ciudad de Panam=C3=A1, Panam=C3=A1
www.multimedpma.com <http://www.multimedpma.com/>=20
cid:A968F01B-26ED-42F0-BD72-9FC45A3C68C5
=20
Content-Type: text/html; charset="UTF-8"
<html xmlns:v=3D"urn:schemas-microsoft-com:vml" xmlns:o=3D"urn:schemas-micr=
osoft-com:office:office" xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:m=3D"http://schemas.microsoft.com/office/2004/12/omml" xmlns=3D"http:=
//www.w3.org/TR/REC-html40"><head><meta http-equiv=3DContent-Type content=
=3D"text/html; charset=3Diso-8859-1"><meta name=3DGenerator content=3D"Micr=
osoft Word 14 (filtered medium)"><!--[if !mso]><style>v\:* {behavior:url(#d=
efault#VML);}
o\:* {behavior:url(#default#VML);}
w\:* {behavior:url(#default#VML);}
.shape {behavior:url(#default#VML);}
</style><![endif]--><style><!--
/* Font Definitions */
@font-face
	{font-family:Cambria;
	panose-1:2 4 5 3 5 4 6 3 2 4;}
@font-face
	{font-family:Calibri;
	panose-1:2 15 5 2 2 2 4 3 2 4;}
@font-face
	{font-family:Tahoma;
	panose-1:2 11 6 4 3 5 4 4 2 4;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
	{margin:0cm;
	margin-bottom:.0001pt;
	font-size:11.0pt;
	font-family:"Calibri","sans-serif";
	mso-fareast-language:EN-US;}
a:link, span.MsoHyperlink
	{mso-style-priority:99;
	color:blue;
	text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
	color:purple;
p.MsoAcetate, li.MsoAcetate, div.MsoAcetate
	mso-style-link:"Texto de globo Car";
	margin:0cm;
	font-size:8.0pt;
	font-family:"Tahoma","sans-serif";
span.EstiloCorreo17
	{mso-style-type:personal-compose;
	color:windowtext;}
span.TextodegloboCar
	{mso-style-name:"Texto de globo Car";
	mso-style-link:"Texto de globo";
	font-family:"Tahoma","sans-serif";}
.MsoChpDefault
	{mso-style-type:export-only;
@page WordSection1
	{size:612.0pt 792.0pt;
	margin:70.85pt 3.0cm 70.85pt 3.0cm;}
div.WordSection1
	{page:WordSection1;}
--></style><!--[if gte mso 9]><xml>
<o:shapedefaults v:ext=3D"edit" spidmax=3D"1026" />
</xml><![endif]--><!--[if gte mso 9]><xml>
<o:shapelayout v:ext=3D"edit">
<o:idmap v:ext=3D"edit" data=3D"1" />
</o:shapelayout></xml><![endif]--></head><body lang=3DES link=3Dblue vlink=
=3Dpurple><div class=3DWordSection1><p class=3DMsoNormal><o:p>&nbsp;</o:p><=
/p><p class=3DMsoNormal><o:p>&nbsp;</o:p></p><p class=3DMsoNormal><span lan=
g=3DES-PA style=3D'font-family:"Cambria","serif";color:black;mso-fareast-la=
nguage:ES-PA'>Saludos, <o:p></o:p></span></p><p class=3DMsoNormal><b><span =
lang=3DES-PA style=3D'font-family:"Cambria","serif";mso-fareast-language:ES=
-PA'><o:p>&nbsp;</o:p></span></b></p><p class=3DMsoNormal><b><span lang=3DE=
S-PA style=3D'font-family:"Cambria","serif";color:#31849B;mso-fareast-langu=
age:ES-PA'>Laneska Miranda<o:p></o:p></span></b></p><p class=3DMsoNormal><s=
pan lang=3DES-PA style=3D'font-family:"Cambria","serif";color:black;mso-far=
east-language:ES-PA'>Regulatorio<o:p></o:p></span></p><p class=3DMsoNormal>=
<span lang=3DES-PA style=3D'font-family:"Cambria","serif";color:black;mso-f=
areast-language:ES-PA'>+507 229-4530 / +507&nbsp; 229-4529<o:p></o:p></span=
></p><p class=3DMsoNormal><span lang=3DES-PA style=3D'font-family:"Cambria"=
,"serif";color:black;mso-fareast-language:ES-PA'>Urbanizaci=C3=B3n Los Ange=
les Calle 64B Oeste<o:p></o:p></span></p><p class=3DMsoNormal><span lang=3D=
ES-PA style=3D'font-family:"Cambria","serif";color:black;mso-fareast-langua=
ge:ES-PA'>Local 25, Ciudad de Panam=C3=A1, Panam=C3=A1<o:p></o:p></span></p=
><p class=3DMsoNormal><span lang=3DES-PA style=3D'font-family:"Cambria","se=
rif";mso-fareast-language:ES-PA'><a href=3D"http://www.multimedpma.com/">ww=
w.multimedpma.com</a><o:p></o:p></span></p><p class=3DMsoNormal><span style=
=3D'color:#1F497D;mso-fareast-language:ES'><img border=3D0 width=3D299 heig=
ht=3D59 id=3D"_x0034_B479076-AF8A-457F-873F-6728693CF80F" src=3D"cid:image0=
01.jpg@01D57909.15754090" alt=3D"cid:A968F01B-26ED-42F0-BD72-9FC45A3C68C5">=
</span><span style=3D'mso-fareast-language:ES'><o:p></o:p></span></p><p cla=
ss=3DMsoNormal><o:p>&nbsp;</o:p></p></div></body></html>
------=_NextPart_001_0011_01D57909.163D7290--
Content-Type: image/jpeg;
	name="image001.jpg"
Content-Transfer-Encoding: base64
Content-ID: <image001.jpg@01D57909.15754090>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------=_NextPart_000_0010_01D57909.163D7290--
In another post I will put the log extract!
Hope this can help get to the bottom of this issue…
Best,
Javier
Here is the log file for the time the email was received:
I, [2019-10-02T15:07:06.085317 #1419-70258774367780]  INFO -- : execute Job.run (try_count 0)...
I, [2019-10-02T15:07:10.334876 #1419-47371599431860]  INFO -- : execute Channel.fetch (try_count 0)...
I, [2019-10-02T15:07:10.336665 #1419-47371599431860]  INFO -- : fetching imap (imap.gmail.com/system@cibernetica.net port=993,ssl=true,starttls=false,folder=SupportChannels/AWS,keep_on_server=false)
I, [2019-10-02T15:07:10.814139 #1031-46918501556780]  INFO -- : Started GET "/api/v1/channels_email?_=1570026671747" for 168.197.189.162 at 2019-10-02 15:07:10 +0000
I, [2019-10-02T15:07:10.819363 #1031-46918501556780]  INFO -- : Processing by ChannelsEmailController#index as JSON
I, [2019-10-02T15:07:10.819412 #1031-46918501556780]  INFO -- :   Parameters: {"_"=>"1570026671747"}
I, [2019-10-02T15:07:10.853457 #1031-46918501556780]  INFO -- : Completed 200 OK in 34ms (Views: 5.2ms | ActiveRecord: 7.2ms)
I, [2019-10-02T15:07:11.641954 #1419-47371599431860]  INFO -- :  - no message
I, [2019-10-02T15:07:11.642016 #1419-47371599431860]  INFO -- : done
I, [2019-10-02T15:07:11.653703 #1419-47371599431860]  INFO -- : fetching imap (imap.gmail.com/system@cibernetica.net port=993,ssl=true,starttls=false,folder=SupportChannels/BYD,keep_on_server=false)
I, [2019-10-02T15:07:13.026208 #1419-47371599431860]  INFO -- :  - message 1/1
I, [2019-10-02T15:07:13.787672 #1419-47371599431860]  INFO -- : Process email with msgid '<000f01d57932$ff1130a0$fd3391e0$@multimedpma.com>'
I, [2019-10-02T15:07:13.833009 #1419-47371599431860]  INFO -- : Enqueued SearchIndexJob (Job ID: af306554-4549-4632-bdd3-eba183f2c10d) to DelayedJob(default) with arguments: "User", 10
I, [2019-10-02T15:07:14.858205 #1419-47371599431860]  INFO -- : Can't fetch image for 'lmiranda@multimedpma.com' (maybe no avatar available), http code: 422
I, [2019-10-02T15:07:14.872503 #1419-47371599431860]  INFO -- : Enqueued SearchIndexJob (Job ID: 1c9c42bd-39a2-41d3-a681-ccc64db17099) to DelayedJob(default) with arguments: "User", 10
I, [2019-10-02T15:07:14.879907 #1419-47371599431860]  INFO -- :  process filter Quitar Flag ...
I, [2019-10-02T15:07:14.880315 #1419-47371599431860]  INFO -- :   perform 'x-zammad-ignore' = '{"value"=>"false"}'
I, [2019-10-02T15:07:14.883338 #1419-47371599431860]  INFO -- : set_attributes_by_x_headers header x-zammad-ticket-customer_id found. Assign customer_id=10
I, [2019-10-02T15:07:14.902624 #1419-47371599431860]  INFO -- : Enqueued SearchIndexJob (Job ID: cab9ab77-4dda-4bd2-be67-a33e558fcf2f) to DelayedJob(default) with arguments: "Ticket", 23
I, [2019-10-02T15:07:14.907670 #1419-47371599431860]  INFO -- : Enqueued SearchIndexJob (Job ID: d11849be-405d-4b6e-beb3-290fef5bc0ab) to DelayedJob(default) with arguments: "User", 10
I, [2019-10-02T15:07:14.913393 #1419-47371599431860]  INFO -- : set_attributes_by_x_headers header x-zammad-article-preferences found. Assign preferences={"send-auto-response"=>false, "is-auto-response"=>true}
I, [2019-10-02T15:07:14.947911 #1419-47371599431860]  INFO -- : Enqueued SearchIndexJob (Job ID: b348013c-4bb1-4454-8f61-c452009bcded) to DelayedJob(default) with arguments: "Ticket", 23
I, [2019-10-02T15:07:14.952799 #1419-47371599431860]  INFO -- : Enqueued SearchIndexJob (Job ID: 60d9477a-cb03-462a-8351-9e96be0db5f8) to DelayedJob(default) with arguments: "User", 10
I, [2019-10-02T15:07:15.059686 #1419-47371599431860]  INFO -- : Skip trigger (auto reply (on new tickets) - AWS/1) because sender do not want to get auto responder for object (Ticket/23/Article/60)
I, [2019-10-02T15:07:15.067774 #1419-47371599431860]  INFO -- : Skip trigger (Auto reply (on new tickets) - BYD/4) because sender do not want to get auto responder for object (Ticket/23/Article/60)
I, [2019-10-02T15:07:15.087784 #1419-47371599431860]  INFO -- : Enqueued TicketUserTicketCounterJob (Job ID: 42229bd7-c982-4035-9a8b-9139200b34b7) to DelayedJob(default) with arguments: 10, 10
I, [2019-10-02T15:07:15.712468 #1419-47371599474520]  INFO -- : 2019-10-02T15:07:15+0000: [Worker(host:ip-10-24-4-221 pid:1419)] Job SearchIndexJob [af306554-4549-4632-bdd3-eba183f2c10d] from DelayedJob(default) with arguments: ["User", 10] (id=1579) (queue=default) RUNNING
I, [2019-10-02T15:07:15.733757 #1419-47371599474520]  INFO -- : Performing SearchIndexJob (Job ID: af306554-4549-4632-bdd3-eba183f2c10d) from DelayedJob(default) with arguments: "User", 10
I, [2019-10-02T15:07:15.741577 #1419-47371599474520]  INFO -- : # curl -X POST "https://vpc-zammad-support-es-7j4b7cwdhqaiq4l2dl6ce6w4by.ca-central-1.es.amazonaws.com/zammad_production_user/_doc/10?pipeline=zammad379394531441" \
I, [2019-10-02T15:07:15.760804 #1419-47371599474520]  INFO -- : # 201
I, [2019-10-02T15:07:15.760936 #1419-47371599474520]  INFO -- : Performed SearchIndexJob (Job ID: af306554-4549-4632-bdd3-eba183f2c10d) from DelayedJob(default) in 27.03ms
I, [2019-10-02T15:07:15.763997 #1419-47371599474520]  INFO -- : 2019-10-02T15:07:15+0000: [Worker(host:ip-10-24-4-221 pid:1419)] Job SearchIndexJob [af306554-4549-4632-bdd3-eba183f2c10d] from DelayedJob(default) with arguments: ["User", 10] (id=1579) (queue=default) COMPLETED after 0.0514
I, [2019-10-02T15:07:15.766618 #1419-47371599474520]  INFO -- : 2019-10-02T15:07:15+0000: [Worker(host:ip-10-24-4-221 pid:1419)] Job SearchIndexJob [1c9c42bd-39a2-41d3-a681-ccc64db17099] from DelayedJob(default) with arguments: ["User", 10] (id=1580) (queue=default) RUNNING
I, [2019-10-02T15:07:15.767597 #1419-47371599431860]  INFO -- : done
I, [2019-10-02T15:07:15.792302 #1419-47371599474520]  INFO -- : Performing SearchIndexJob (Job ID: 1c9c42bd-39a2-41d3-a681-ccc64db17099) from DelayedJob(default) with arguments: "User", 10
I, [2019-10-02T15:07:15.802699 #1419-47371599474520]  INFO -- : # curl -X POST "https://vpc-zammad-support-es-7j4b7cwdhqaiq4l2dl6ce6w4by.ca-central-1.es.amazonaws.com/zammad_production_user/_doc/10?pipeline=zammad379394531441" \
I, [2019-10-02T15:07:15.817679 #1419-47371599474520]  INFO -- : # 200
I, [2019-10-02T15:07:15.817824 #1419-47371599474520]  INFO -- : Performed SearchIndexJob (Job ID: 1c9c42bd-39a2-41d3-a681-ccc64db17099) from DelayedJob(default) in 25.07ms
I, [2019-10-02T15:07:15.820723 #1419-47371599474520]  INFO -- : 2019-10-02T15:07:15+0000: [Worker(host:ip-10-24-4-221 pid:1419)] Job SearchIndexJob [1c9c42bd-39a2-41d3-a681-ccc64db17099] from DelayedJob(default) with arguments: ["User", 10] (id=1580) (queue=default) COMPLETED after 0.0535
I, [2019-10-02T15:07:15.823865 #1419-47371599474520]  INFO -- : 2019-10-02T15:07:15+0000: [Worker(host:ip-10-24-4-221 pid:1419)] Job SearchIndexJob [cab9ab77-4dda-4bd2-be67-a33e558fcf2f] from DelayedJob(default) with arguments: ["Ticket", 23] (id=1581) (queue=default) RUNNING
I, [2019-10-02T15:07:15.844464 #1419-47371599474520]  INFO -- : Performing SearchIndexJob (Job ID: cab9ab77-4dda-4bd2-be67-a33e558fcf2f) from DelayedJob(default) with arguments: "Ticket", 23
I, [2019-10-02T15:07:15.869983 #1419-47371599474520]  INFO -- : # curl -X POST "https://vpc-zammad-support-es-7j4b7cwdhqaiq4l2dl6ce6w4by.ca-central-1.es.amazonaws.com/zammad_production_ticket/_doc/23?pipeline=zammad379394531441" \
I, [2019-10-02T15:07:16.077174 #1419-47371599474520]  INFO -- : # 201
I, [2019-10-02T15:07:16.077357 #1419-47371599474520]  INFO -- : Performed SearchIndexJob (Job ID: cab9ab77-4dda-4bd2-be67-a33e558fcf2f) from DelayedJob(default) in 232.75ms
I, [2019-10-02T15:07:16.080656 #1419-47371599474520]  INFO -- : 2019-10-02T15:07:16+0000: [Worker(host:ip-10-24-4-221 pid:1419)] Job SearchIndexJob [cab9ab77-4dda-4bd2-be67-a33e558fcf2f] from DelayedJob(default) with arguments: ["Ticket", 23] (id=1581) (queue=default) COMPLETED after 0.2567
I, [2019-10-02T15:07:16.083580 #1419-47371599474520]  INFO -- : 2019-10-02T15:07:16+0000: [Worker(host:ip-10-24-4-221 pid:1419)] Job SearchIndexJob [d11849be-405d-4b6e-beb3-290fef5bc0ab] from DelayedJob(default) with arguments: ["User", 10] (id=1582) (queue=default) RUNNING
I, [2019-10-02T15:07:16.104154 #1419-47371599474520]  INFO -- : Performing SearchIndexJob (Job ID: d11849be-405d-4b6e-beb3-290fef5bc0ab) from DelayedJob(default) with arguments: "User", 10
I, [2019-10-02T15:07:16.110176 #1419-47371599474520]  INFO -- : # curl -X POST "https://vpc-zammad-support-es-7j4b7cwdhqaiq4l2dl6ce6w4by.ca-central-1.es.amazonaws.com/zammad_production_user/_doc/10?pipeline=zammad379394531441" \
I, [2019-10-02T15:07:16.140697 #1419-47371599474520]  INFO -- : # 200
I, [2019-10-02T15:07:16.140852 #1419-47371599474520]  INFO -- : Performed SearchIndexJob (Job ID: d11849be-405d-4b6e-beb3-290fef5bc0ab) from DelayedJob(default) in 36.56ms
I, [2019-10-02T15:07:16.143650 #1419-47371599474520]  INFO -- : 2019-10-02T15:07:16+0000: [Worker(host:ip-10-24-4-221 pid:1419)] Job SearchIndexJob [d11849be-405d-4b6e-beb3-290fef5bc0ab] from DelayedJob(default) with arguments: ["User", 10] (id=1582) (queue=default) COMPLETED after 0.0600
I, [2019-10-02T15:07:16.146299 #1419-47371599474520]  INFO -- : 2019-10-02T15:07:16+0000: [Worker(host:ip-10-24-4-221 pid:1419)] Job SearchIndexJob [b348013c-4bb1-4454-8f61-c452009bcded] from DelayedJob(default) with arguments: ["Ticket", 23] (id=1583) (queue=default) RUNNING
I, [2019-10-02T15:07:16.166853 #1419-47371599474520]  INFO -- : Performing SearchIndexJob (Job ID: b348013c-4bb1-4454-8f61-c452009bcded) from DelayedJob(default) with arguments: "Ticket", 23
I, [2019-10-02T15:07:16.192452 #1419-47371599474520]  INFO -- : # curl -X POST "https://vpc-zammad-support-es-7j4b7cwdhqaiq4l2dl6ce6w4by.ca-central-1.es.amazonaws.com/zammad_production_ticket/_doc/23?pipeline=zammad379394531441" \
I, [2019-10-02T15:07:16.376688 #1419-47371599474520]  INFO -- : # 200
I, [2019-10-02T15:07:16.376840 #1419-47371599474520]  INFO -- : Performed SearchIndexJob (Job ID: b348013c-4bb1-4454-8f61-c452009bcded) from DelayedJob(default) in 209.87ms
I, [2019-10-02T15:07:16.380036 #1419-47371599474520]  INFO -- : 2019-10-02T15:07:16+0000: [Worker(host:ip-10-24-4-221 pid:1419)] Job SearchIndexJob [b348013c-4bb1-4454-8f61-c452009bcded] from DelayedJob(default) with arguments: ["Ticket", 23] (id=1583) (queue=default) COMPLETED after 0.2337
I, [2019-10-02T15:07:16.382675 #1419-47371599474520]  INFO -- : 2019-10-02T15:07:16+0000: [Worker(host:ip-10-24-4-221 pid:1419)] Job SearchIndexJob [60d9477a-cb03-462a-8351-9e96be0db5f8] from DelayedJob(default) with arguments: ["User", 10] (id=1584) (queue=default) RUNNING
I, [2019-10-02T15:07:16.402553 #1419-47371599474520]  INFO -- : Performing SearchIndexJob (Job ID: 60d9477a-cb03-462a-8351-9e96be0db5f8) from DelayedJob(default) with arguments: "User", 10
I, [2019-10-02T15:07:16.408375 #1419-47371599474520]  INFO -- : # curl -X POST "https://vpc-zammad-support-es-7j4b7cwdhqaiq4l2dl6ce6w4by.ca-central-1.es.amazonaws.com/zammad_production_user/_doc/10?pipeline=zammad379394531441" \
I, [2019-10-02T15:07:16.431277 #1419-47371599474520]  INFO -- : # 200
I, [2019-10-02T15:07:16.431390 #1419-47371599474520]  INFO -- : Performed SearchIndexJob (Job ID: 60d9477a-cb03-462a-8351-9e96be0db5f8) from DelayedJob(default) in 28.73ms
I, [2019-10-02T15:07:16.434503 #1419-47371599474520]  INFO -- : 2019-10-02T15:07:16+0000: [Worker(host:ip-10-24-4-221 pid:1419)] Job SearchIndexJob [60d9477a-cb03-462a-8351-9e96be0db5f8] from DelayedJob(default) with arguments: ["User", 10] (id=1584) (queue=default) COMPLETED after 0.0517
I, [2019-10-02T15:07:16.437312 #1419-47371599474520]  INFO -- : 2019-10-02T15:07:16+0000: [Worker(host:ip-10-24-4-221 pid:1419)] Job Transaction::BackgroundJob (id=1585) RUNNING
I, [2019-10-02T15:07:16.464880 #1419-47371599474520]  INFO -- : 2019-10-02T15:07:16+0000: [Worker(host:ip-10-24-4-221 pid:1419)] Job Transaction::BackgroundJob (id=1585) COMPLETED after 0.0273
I, [2019-10-02T15:07:16.467655 #1419-47371599474520]  INFO -- : 2019-10-02T15:07:16+0000: [Worker(host:ip-10-24-4-221 pid:1419)] Job Transaction::BackgroundJob (id=1586) RUNNING
I, [2019-10-02T15:07:16.534316 #1419-47371599474520]  INFO -- : Send notification to: jalmillategui@cibernetica.net (from:Notification Master <noreply@cibernetica.net>/subject:[Ticket#61023] New Ticket (Prueba))
I, [2019-10-02T15:07:18.327257 #1419-47371599474520]  INFO -- : 2019-10-02T15:07:18+0000: [Worker(host:ip-10-24-4-221 pid:1419)] Job Transaction::BackgroundJob (id=1586) COMPLETED after 1.8595
I, [2019-10-02T15:07:18.330409 #1419-47371599474520]  INFO -- : 2019-10-02T15:07:18+0000: [Worker(host:ip-10-24-4-221 pid:1419)] Job TicketUserTicketCounterJob [42229bd7-c982-4035-9a8b-9139200b34b7] from DelayedJob(default) with arguments: [10, 10] (id=1587) (queue=default) RUNNING
I, [2019-10-02T15:07:18.350057 #1419-47371599474520]  INFO -- : Performing TicketUserTicketCounterJob (Job ID: 42229bd7-c982-4035-9a8b-9139200b34b7) from DelayedJob(default) with arguments: 10, 10
I, [2019-10-02T15:07:18.369803 #1419-47371599474520]  INFO -- : Enqueued SearchIndexJob (Job ID: e292728a-f7bf-4a27-ae29-107ded5704df) to DelayedJob(default) with arguments: "User", 10
I, [2019-10-02T15:07:18.373616 #1419-47371599474520]  INFO -- : Performed TicketUserTicketCounterJob (Job ID: 42229bd7-c982-4035-9a8b-9139200b34b7) from DelayedJob(default) in 23.46ms
I, [2019-10-02T15:07:18.376053 #1419-47371599474520]  INFO -- : 2019-10-02T15:07:18+0000: [Worker(host:ip-10-24-4-221 pid:1419)] Job TicketUserTicketCounterJob [42229bd7-c982-4035-9a8b-9139200b34b7] from DelayedJob(default) with arguments: [10, 10] (id=1587) (queue=default) COMPLETED after 0.0455
I, [2019-10-02T15:07:18.378858 #1419-47371599474520]  INFO -- : 2019-10-02T15:07:18+0000: [Worker(host:ip-10-24-4-221 pid:1419)] Job SearchIndexJob [e292728a-f7bf-4a27-ae29-107ded5704df] from DelayedJob(default) with arguments: ["User", 10] (id=1588) (queue=default) RUNNING
I, [2019-10-02T15:07:18.398790 #1419-47371599474520]  INFO -- : Performing SearchIndexJob (Job ID: e292728a-f7bf-4a27-ae29-107ded5704df) from DelayedJob(default) with arguments: "User", 10
I, [2019-10-02T15:07:18.407889 #1419-47371599474520]  INFO -- : # curl -X POST "https://vpc-zammad-support-es-7j4b7cwdhqaiq4l2dl6ce6w4by.ca-central-1.es.amazonaws.com/zammad_production_user/_doc/10?pipeline=zammad379394531441" \
I, [2019-10-02T15:07:18.429471 #1419-47371599474520]  INFO -- : # 200
I, [2019-10-02T15:07:18.429603 #1419-47371599474520]  INFO -- : Performed SearchIndexJob (Job ID: e292728a-f7bf-4a27-ae29-107ded5704df) from DelayedJob(default) in 30.69ms
I, [2019-10-02T15:07:18.432772 #1419-47371599474520]  INFO -- : 2019-10-02T15:07:18+0000: [Worker(host:ip-10-24-4-221 pid:1419)] Job SearchIndexJob [e292728a-f7bf-4a27-ae29-107ded5704df] from DelayedJob(default) with arguments: ["User", 10] (id=1588) (queue=default) COMPLETED after 0.0538
I, [2019-10-02T15:07:19.159782 #1031-46918501557560]  INFO -- : Started GET "/api/v1/online_notifications/?full=true&_=1570026671748" for 168.197.189.162 at 2019-10-02 15:07:19 +0000
I, [2019-10-02T15:07:19.164232 #1031-46918501557560]  INFO -- : Processing by OnlineNotificationsController#index as JSON
I, [2019-10-02T15:07:19.164280 #1031-46918501557560]  INFO -- :   Parameters: {"full"=>"true", "_"=>"1570026671748"}
I, [2019-10-02T15:07:19.205479 #1031-46918501557560]  INFO -- : Completed 200 OK in 41ms (Views: 7.2ms | ActiveRecord: 7.4ms)
I, [2019-10-02T15:07:40.863150 #1031-46918501557280]  INFO -- : Started GET "/api/v1/channels_email?_=1570026671749" for 168.197.189.162 at 2019-10-02 15:07:40 +0000
I, [2019-10-02T15:07:40.868053 #1031-46918501557280]  INFO -- : Processing by ChannelsEmailController#index as JSON
I, [2019-10-02T15:07:40.868108 #1031-46918501557280]  INFO -- :   Parameters: {"_"=>"1570026671749"}
I, [2019-10-02T15:07:40.904181 #1031-46918501557280]  INFO -- : Completed 200 OK in 36ms (Views: 4.8ms | ActiveRecord: 5.7ms)
I, [2019-10-02T15:07:45.804165 #1419-47371599431860]  INFO -- : execute Channel.fetch (try_count 0)...
I, [2019-10-02T15:07:45.805985 #1419-47371599431860]  INFO -- : fetching imap (imap.gmail.com/system@cibernetica.net port=993,ssl=true,starttls=false,folder=SupportChannels/AWS,keep_on_server=false)
I, [2019-10-02T15:07:46.117272 #1419-70258763838740]  INFO -- : execute Import::OTRS.diff_worker (try_count 0)...
I, [2019-10-02T15:07:47.336731 #1419-47371599431860]  INFO -- :  - no message
I, [2019-10-02T15:07:47.336797 #1419-47371599431860]  INFO -- : done
I, [2019-10-02T15:07:47.347980 #1419-47371599431860]  INFO -- : fetching imap (imap.gmail.com/system@cibernetica.net port=993,ssl=true,starttls=false,folder=SupportChannels/BYD,keep_on_server=false)
I, [2019-10-02T15:07:47.356458 #1419-47371518215620]  INFO -- : Scheduler running...
I, [2019-10-02T15:07:47.406744 #1419-47371518215620]  INFO -- : Running job thread for 'Process escalation tickets' (Ticket.process_escalation) status is: sleep
I, [2019-10-02T15:07:47.406888 #1419-47371518215620]  INFO -- : Running job thread for 'Generate Session data' (Sessions.jobs) status is: sleep
I, [2019-10-02T15:07:47.406996 #1419-47371518215620]  INFO -- : Running job thread for 'Check Channels' (Channel.fetch) status is: sleep
I, [2019-10-02T15:07:47.407050 #1419-47371518215620]  INFO -- : Running job thread for 'Import OTRS diff load' (Import::OTRS.diff_worker) status is: sleep
I, [2019-10-02T15:07:47.407093 #1419-47371518215620]  INFO -- : Running job thread for 'Check streams for Channel' (Channel.stream) status is: sleep
I, [2019-10-02T15:07:47.407315 #1419-47371518215620]  INFO -- : Running job thread for 'Execute jobs' (Job.run) status is: sleep
I, [2019-10-02T15:07:47.407696 #1419-70258695726860]  INFO -- : Started job thread for 'Delete old entries.' (RecentView.cleanup)...
I, [2019-10-02T15:07:47.412596 #1419-70258695726860]  INFO -- : execute RecentView.cleanup (try_count 0)...
I, [2019-10-02T15:07:47.416804 #1419-70258695726860]  INFO -- :  ...stopped thread for 'RecentView.cleanup'
I, [2019-10-02T15:07:49.450647 #1419-47371599431860]  INFO -- :  - no message
I, [2019-10-02T15:07:49.450710 #1419-47371599431860]  INFO -- : done
I, [2019-10-02T15:07:57.408282 #1419-47371599016420]  INFO -- : Started job thread for 'Sync calendars with ical feeds.' (Calendar.sync)...
I, [2019-10-02T15:07:57.413125 #1419-47371599016420]  INFO -- : execute Calendar.sync (try_count 0)...
I, [2019-10-02T15:07:57.770488 #1419-47371599016420]  INFO -- :  ...stopped thread for 'Calendar.sync'
Ah thanks for the further input, that helped!
We’re not sending automatic trigger based notifications to that mail, because it’s from a mailing list:
This is done by postmaster filters and shouldn’t be changed to ensure nothing “unexpected” happens.
I’m not sure why you’d want to reply to a mailing list, it should work if it’s not coming from a bulk message or list.
The two parts that are responsible in Zammad are the following ones:
and to be more precise to know which headers are involved:
Well here is the thing in our organization we use mailing list as the endpoint of our support emails, it looks like this:
Customer -----------> Mail list (Google Group with public access) -------> System email account
In fact all our customer email will pass thru a mail list, then arrive at our helpdesk system.
We are using the expert features to make it possible to use one account for multiple mail inboxes.
Hence why the eml has the precedence: List, how would we enable the auto response in this scenario?
Best Regards,
Javier
@anon29869905 is it possible to disable system postmaster_filters anyhow?
Perosnally I wouldn’t do so, but still?
Postmaster Filters are registered via Settings:
So you could remove the Settings (Setting.find_by(name: 'x').destroy!) - but this will lead to all kind of unexpected and undefined behavior. I advise strongly against it. This will lead to technical and support questions we can’t and won’t reproduce/answer.
Well… I just removed “list” from ‘precedence’.to_sym in the auto_response_check.rb
That makes the trigger work!
any possible side effect?
Best Regards,
Javier
yep, that change is not update save and needs to be done after every update.
Beside that, Zammad will now reply to any mailing list sending you mails, you might get upset list members or even excluded from the list.
Hi Mr. Generation,
What I may have failed to explain is that the mailing list is an inbound mailing… meaning it is used internally to redirect email to case system, and to the audit/archival solution.
When we reply, we reply to a customer mail address.
Best,
Javier
