Permit UserID modification in UI
I know there’s a way to do this via the Rails Console. I am requesting that it be made a field that can be modified in the user config of the UI.
User IDs are database incremental IDs. Changing those IDs manually would potentially cause trouble in the database layer.
Ahh, I assumed userID was what the Login ID field was. I’d like to assign usernames to login with (firstName+lastNameInitial) rather than people using their email addresses.
I see, I’ll move this to “Technical Assistance” then.
I’d like to point you to this feature request that I found with a very quick and rough search:
Hearts can also be given to locked threads. :slight_smile:
