- Used Zammad version: 4.1 > 5.0
- Used Zammad installation type: (source, package, docker-compose, …) package
- Operating system: Centos7
- Browser + version: Chrome last
We used ZAMMAD 4.1 with postgresql 9.2.
At the time of the upgrade there was a requirement of postgresql for version 9.6 and above so we upgraded to version 11.
We then upgraded ZAMMAD to YUM, during the upgrade no errors appeared, but now we are unable to connect to the system.
I, [2021-10-05T14:49:01.229072 #2664-174240] INFO -- : Started POST "/api/v1/signin" for at 2021-10-05 14:49:01 +0300
I, [2021-10-05T14:49:01.238015 #2664-174240] INFO -- : Processing by SessionsController#create as JSON
I, [2021-10-05T14:49:01.238135 #2664-174240] INFO -- : Parameters: {"username"=>****.com", "password"=>"[FILTERED]", "fingerprint"=>"-2086164141"}
E, [2021-10-05T14:49:01.249948 #2664-174240] ERROR -- : Failed to load Auth::Backend from Setting '{"adapter"=>"Auth::Ldap", "host"=>"localhost", "port"=>389, "bind_dn"=>"cn=Manager,dc=example,dc=org", "bind_pw"=>"example", "uid"=>"mail", "base"=>"dc=example,dc=org", "always_filter"=>"", "always_roles"=>["Admin", "Agent"], "always_groups"=>["Users"], "sync_params"=>{"firstname"=>"sn", "lastname"=>"givenName", "email"=>"mail", "login"=>"mail"}}'
E, [2021-10-05T14:49:01.250006 #2664-174240] ERROR -- : uninitialized constant Auth::Ldap (NameError)
lib/auth/backend.rb:26:in `block in instances'
lib/auth/backend.rb:25:in `each'
lib/auth/backend.rb:25:in `filter_map'
lib/auth/backend.rb:25:in `instances'
lib/auth/backend.rb:13:in `valid?'
lib/auth.rb:37:in `valid?'
app/controllers/sessions_controller.rb:219:in `authenticate_with_password'
app/controllers/sessions_controller.rb:10:in `create'
app/controllers/application_controller/has_download.rb:21:in `block (4 levels) in <module:HasDownload>'
app/controllers/application_controller/has_download.rb:20:in `block (3 levels) in <module:HasDownload>'
app/controllers/application_controller/has_download.rb:19:in `block (2 levels) in <module:HasDownload>'
I, [2021-10-05T14:49:02.255818 #2664-174240] INFO -- : Login failed. Have you double-checked your credentials and completed the email verification step? (Exceptions::NotAuthorized)
app/controllers/application_controller/authenticates.rb:169:in `raise_unified_login_error'
I, [2021-10-05T14:49:02.257113 #2664-174240] INFO -- : Completed 401 Unauthorized in 1019ms (Views: 0.3ms | ActiveRecord: 1.6ms | Allocations: 8030)
