Please change the Color of the lighter part of Zammad in a way that you also could see a difference between Text and Background even you have a cheap Monitor.
At moment some people try to change Monitor settings, but we do not get a color setting which is not a strain on the eyes
Hey @Mannshoch,
have a look at this if you want to change the appearance of your zammad system:
I doubt they’ll change the default (i wouldn’t).
Still, making the primary colours customizable via frontend would be a neat feature.
cheers
Our Admin avoid modifying any web-application if it’s not possible to do it from inside the back-end. And because we may not the only one with this Problem, I write it down here.
I would also argue that some colors in Zammad should be changed; some parts have horrible contrast and therefore are very hard to read. There is an online color contrast checker which might be helpful: WebAIM: Contrast Checker
To quote from that site:
WCAG 2 level AA requires a contrast ratio of at least 4.5:1 for normal text and 3:1 for large text, and a contrast ratio of at least 3:1 for graphics and user interface components (such as form input borders).
Some things in Zammad that I find hard to read:
The grey help texts:
#aabdc5on#f6f7f8- contrast ratio 1.81:1 -
Unselected navigation entries:
#575b61on#25262d- contrast ratio 2.2:1 -
Unselected tabs in the navigation:
#808080on#2c2d36- contrast ratio 3.46:1 -
Unselected tabs in the main area:
#b3b3b3on#ffffff- contrast ratio 2.09:1 -
UI labels when creating a new ticket:
a5b8c0on#ffffff- contrast ratio 2.05:1 -
Ticket count badges for overviews
inactive:
#d0d2d3on#ffffff- contrast ratio 1.51:1
active:#96969bon#2c2d36- contrast ratio 4.64:1 [ok, that one is actually acceptable ^^] -
UI labels on the right side in the ticket zoom
labels:
#aabdc5on#ffffff- contrast ratio 1.94:1
add tag/link:#c7d5dbon#ffffff- contrast ratio 1.5:1
I went ahead and fiddled with the CSS; here’s a higher contrast proof of concept: Comparing zammad:develop...martinvonwittich:improved-contrast · zammad/zammad · GitHub
Before/after screenshots:
dashboard
email settings
overview
new ticket
ticket zoom
I’m not really happy with the navigation yet. Maybe someone with actual design experience can come up with a better solution? ![]()
