CSRF token verification failed and Session invalid
  • Used Zammad version: 6.3.1-95
  • Browser + version: Chrome 126.0.6478.182 / Firefox 128.0.2
  • Log In → Log out → Log in → Log out → Log in …
  • Log in → Log out → CSRF token verification failed
Similar to that Issue:
Login User: CSRF token verification failed
  • Run docker-compose
  • Configure Zammad
  • Log in (already logged in after setup)
  • Log out
  • CSRF token verification failed
I’m using Zammad behind a reverse proxy. i had a look into your .examples/proxy and, as far as I understand it, it would spin up an additional Nginx, that acted as a reverse proxy. I already have one and I use Caddy, so that one points to Zammad’s default port 8080.
Because everything seems to work pretty well (until I log out), I don’t suspect, it’s the reverse proxy’s issue.
Another thing, that might be related, or not, is, that I can’t take over a session. Meaning: If I’m logged in in Chrome and I want to log in in Firefox, it stopps the session in Chrome, but tells me the session is invalid in Firefox … after flashing me with the dashboard …
BTW: I’m running version 6.2.0-1 the same way. The only difference: Caddy - the reverse proxy - is on the same mashine. There I don’t have that issue.
Just testet it again to ensure everything’s the same between the old and new version (except the lacation of the proxy) and am still getting the same behaviour.
Solution:
Set upstream headers in Caddy config.
reverse_proxy * 192.168.x.x:8080 {
	header_up Host {http.request.host}
	header_up X-Real-IP {http.request.remote}
	header_up X-Forwarded-For {http.request.remote}
	header_up X-Forwarded-Proto https
	header_up X-Forwarded-Ssl on
The solution worked for me too, thank you!
A related post, for the record: Setting Up Zammad with Caddy: Avoiding CSRF Token Errors - My Learnings | TilSeiffert . The header_up arguments are a bit leaner there.
