Installing via Plesk and Fixing Error "CSRF token verification failed"
Hey everyone, hope all is well! I just wanted to share here the way that I was able to properly install of Zammad on a server running Plesk after running into the CSRF error. My problem was actually the same one described here ( CSRF token verification failed and Session invalid ) where I could install everything, set it up, and then after the first time I logged out it would not allow me to log back in and I’d get that CSRF error. In my troubleshooting, I also ran across several other topics:
I installed Zammad 6.5.0 on a Digital Ocean droplet running Plesk 18.0.62 on Ubuntu 22.04. The installation method was the using Zammad’s Docker compose repository and deploying with portainer.
Plesk has a Docker extension, and within that docker extension is a useful shortcut to install Portainer through the Plesk interface. I used that to install Portainer. After the initial install I could not access it through the normal port, and eventually I found out that if I returned to that same page, the button to ‘Install Portainer’ actually changed to a button to ‘Open Portainer’ and I could access it that way.
Once that was done, I installed Zammad using their instructions (linked above) with absolutely no deviations. I then used Plesk’s method for setting up a reverse proxy to Docker which uses nginx as a reverse proxy. Once that was done, I was able to access the installation and set it up completely.
This is where the trouble came. I set everything up, logged out to set up some API keys for other users I had made, and all of a sudden I could not log back in. I received the CSRF error. Oddly, it seemed like websockets were working absolutely fine even though other topics on CSRF led me to believe they’d be related. And, nothing that I read in any of the topics I linked above were helping.
By inspecting my browser panel I noticed one major difference between it and the install in my dev environment, which was that I was not able to keep a session cookie after logging out. I would never receive another one. I tried reinstalling several times, and installing different versions, but no luck.
It was actually the first topic I linked that helped start to lead me down the right path, and just some lucky tinkering. I started to inspect the vhost configuration for my domain to see how it set up the reverse proxy, this is what it generated:
location ~ ^/.* {
  proxy_pass http://0.0.0.0:8080;
  proxy_set_header Host              $host;
  proxy_set_header X-Real-IP         $remote_addr;
  proxy_set_header X-Forwarded-For   $proxy_add_x_forwarded_for;
  proxy_set_header Connection "upgrade";
  proxy_http_version 1.1;
After much testing, I found the following to work:
location / {
	proxy_set_header X-Forwarded-Ssl on;
	proxy_pass http://127.0.0.1:8080;
The main differences here were:
  • The order of items. I copied what I found in Zammad’s own configuration files. I’m not sure if this mattered.
  • The first line, location ~ ^/.* { vs location / {. That pattern in the location block opening. As I changed this, some things would stop and start working. It might not have ultimately been the cause of the problem but I do think this was important to have this way.
  • The proxy_pass setting being proxy_pass http://0.0.0.0:8080; vs proxy_pass http://127.0.0.1:8080;. This is another one I’m not sure mattered.
  • The addition of the line proxy_set_header X-Forwarded-Ssl on;. This, I think was the most important thing. You might be able to get it to work with just adding that line.
I couldn’t find any way to change that configuration that would be created by using Plesk’s built-in Docker Proxy Rules interface. So, I ended up having to remove that setting entirely. Then, under ‘Hosting and DNS’ for the domain, I went into ‘Apache & Nginx Settings’ and unchecked “Proxy Mode” (proxies nginx to Apache), and added the block listed above under ‘Additional nginx directives’. It may not have mattered, but I also turned off PHP for the domain entirely and changed changed a few other settings that I thought were unnecessary for such a situation.
I hope this helps anyone that may run into the same problems! I’m very excited to use Zammad; it’s for my ministry, and I’ve had trouble using other open-source options in the past. This seems like such a good project; thank you developers and everyone working on it!
Thank you!
I was going crazy until I found your post,
I did not change the whole block, I just added
And changed
To
proxy_set_header X-Forwarded-Proto https;`
In case anyone else stumbles on this, The location for the conf file is
/var/www/vhosts/system/example.com/conf/nginx.con
My current block is like this
        location ~ ^/.* {
This keeps getting reset every so often, Anyone know how to set these settings consistently?
You are using plesk. It is a all in one management solution for easy web services. That has downsides though.
I can‘t repeat myself often enough in this context on this board: Don‘t install Zammad ob such a full managed system.
I get it,
All good.
I understand it’s a “plesk” problem and not zammad, was just curious if anyone figured it out.
Even their official sources seem to be more frustrating than helpful.
https://support.plesk.com/hc/en-us/articles/12377710335767-How-to-modify-domain-s-configurations-in-Plesk-permanently
@netzih
Yes, editing this file directly will not work. I did the following:
My install through Plesk has been working fine after ironing out all of the configuration issues.
