I don’t know if this is something that is supposed to be possible or not.
Go to object “format” dropdown and switch object from single selection to multi selection.
Other object types unavailable.
Upgraded from 5.0.3 and wanted to use the new multi-select option for certain objects for more detailed data, but don’t want to lose historical data in current single select objects. Want to convert the single select to multi select.
