Title: Add conditions to the web notification (Zammad bird)
The web notifications shown in the Zammad bird are valid for all roles/users that have permissions on certain groups.
This behavior can bring to notification spam when an agent is part of a group but can only see articles (tickets) filtered by their organization membership (as in, customer and agent are part of the same organization, primary or secondary).
In our setup it is required to set up 450 roles to make sure that the agents only get notification for the organizations they are a part of.
As explained here Export/Import Overviews using the rails console - #3 by skip
There is no way to add conditions to the web notification system. (Unless someone knows a workaround/hack)
Be able to get only notification for different conditions, like e.g. is member of current user organization
Your Zammad environment:
Average concurrent agent count: 25
Average tickets a day: 20
What roles/people are involved: IT technicians, managers, customers
Most is explained here:
Usually, notifications can be configured on a “per-group-basis”. When I want agents to be able to select what tickets they want to have notifications for, I divide the tickets into different groups. Then every agent can configure that themself.
That is absolutely valid, the issue in our use case is that a (zammad) group is a school district, where two or more schools can be part of one district. An agent can be responsible for a district, only for a single or subset of the schools within a district, additionally to that every agent can have access to a mixed subset of up to 30 schools (main tech and backup tech).
To make this work I have:
a) created a group for every district (or sometimes school)
b) created a role for every school and given that role access to the group (~450 roles)
Only this way I was be sure that agents are not spammed by notifications for groups they should not have access to.
The overviews are set to only show tickets from the organization(s) the agent is member of (secondary organizations). Which means that this way I can also make sure that if an agent has to manage a single school within a district, they do not see the tickets from other schools within that district.
To further filter the notifications by organization would further make this situation cleaner.
This is because even though it is all one big public organization, every school is managed as it’s own entity/site/organization on a support level (one tech, one school), and you can imagine how long it would take to change that to a 1st level/2nd level general support system where multiple agents work on all the schools at an organizational level
