Zammad Very Slow
#1
  • Used Zammad version: zammad-2.9.0
  • Used Zammad installation source: RPM
  • Operating system: Centos7
Fast response .
The zammad system is very slow 4 weeks before and employees can’t work as fast as possible.
I have executed the command “htop” in the Zammad host and seems like these 2 process are using a lot of CPU:
Please any suggestions?
#2
Please provide us info:
zammad run rails r ‘p Delayed::Job.count’
zammad run rails r ‘p Delayed::Job.first’
zammad run rails r ‘p Delayed::Job.last’
#3
Hello @atimias
0
nil
#<Delayed::Backend::ActiveRecord::Job id: 2946110, priority: 0, attempts: 0, handler: “— !ruby/object:ActiveJob::QueueAdapters::Delayed…”, last_error: nil, run_at: “2019-04-10 12:56:44”, locked_at: nil, failed_at: nil, locked_by: nil, queue: “default”, created_at: “2019-04-10 12:56:44”, updated_at: “2019-04-10 12:56:44”>
#4
Are logs showing anything interesting?
#5
production.log
, [2019-04-10T16:09:15.868577 #21092-70210171752840] INFO – : Parameters: {“customer_id”=>“3894”, “"=>“1554886430068”}
I, [2019-04-10T16:09:15.978852 #21092-70210032932800] INFO – : Started GET "/api/v1/ticket_customer?customer_id=389&
=155488069” for ****** at 2019-04-10 16:09:15 +0200
I, [2019-04-10T16:09:16.002424 #21092-70210032932800] INFO – : Processing by TicketsController#ticket_customer as JSON
I, [2019-04-10T16:09:16.003481 #21092-70210032932800] INFO – : Parameters: {“customer_id”=>“389”, “"=>“1554886439”}
I, [2019-04-10T16:09:16.013963 #21092-47156859389800] INFO – : Started GET "/api/v1/ticket_customer?customer_id=389&
=155480070” for ****** at 2019-04-10 16:09:16 +0200
I, [2019-04-10T16:09:16.046178 #21092-47156859389800] INFO – : Processing by TicketsController#ticket_customer as JSON
I, [2019-04-10T16:09:16.046647 #21092-47156859389800] INFO – : Parameters: {“customer_id”=>“389”, “_”=>“15548860070”}
I, [2019-04-10T16:09:16.160368 #21092-70210171752840] INFO – : Completed 200 OK in 291ms (Views: 73.5ms | ActiveRecord: 19.6ms)
I, [2019-04-10T16:09:16.542856 #21092-70210032932800] INFO – : Completed 200 OK in 539ms (Views: 94.6ms | ActiveRecord: 62.4ms)
I, [2019-04-10T16:09:16.950939 #21092-47156859389800] INFO – : Completed 200 OK in 904ms (Views: 392.0ms | ActiveRecord: 131.5ms)
I, [2019-04-10T16:09:21.939099 #21094-47000454754180] INFO – : Running job thread for ‘Execute jobs’ (Job.run) status is: sleep
I, [2019-04-10T16:09:22.815921 #21094-69930862307100] INFO – : execute Channel.fetch (try_count 0)…
I, [2019-04-10T16:09:22.831396 #21094-69930862307100] INFO – : fetching imap ()
I, [2019-04-10T16:09:23.195378 #21094-69930862307100] INFO – : - no message
I, [2019-04-10T16:09:23.195932 #21094-69930862307100] INFO – : done
E, [2019-04-10T16:09:31.534623 #21094-69930862307100] ERROR – : Can’t use Channel::Driver::Imap: #<Net::IMAP::NoResponseError: Authentication failed.>
E, [2019-04-10T16:09:31.534994 #21094-69930862307100] ERROR – : Authentication failed. (Net::IMAP::NoResponseError)
/opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/net/imap.rb:1194:in get_tagged_response' /opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/net/imap.rb:1248:inblock in send_command’
/opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/monitor.rb:214:in mon_synchronize' /opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/net/imap.rb:1230:insend_command’
/opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/net/imap.rb:434:in login' /opt/zammad/app/models/channel/driver/imap.rb:110:inblock in fetch’
/opt/zammad/app/models/channel/driver/imap.rb:381:in block in timeout' /opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/timeout.rb:93:inblock in timeout’
/opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/timeout.rb:33:in block in catch' /opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/timeout.rb:33:incatch’
/opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/timeout.rb:33:in catch' /opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/timeout.rb:108:intimeout’
/opt/zammad/app/models/channel/driver/imap.rb:380:in timeout' /opt/zammad/app/models/channel/driver/imap.rb:109:infetch’
/opt/zammad/app/models/channel.rb:56:in fetch' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/relation/delegation.rb:39:ineach’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/relation/delegation.rb:39:in each' /opt/zammad/app/models/channel.rb:30:infetch’
(eval):1:in _start_job' /opt/zammad/app/models/scheduler.rb:286:ineval’
/opt/zammad/app/models/scheduler.rb:286:in _start_job' /opt/zammad/app/models/scheduler.rb:239:inblock (2 levels) in start_job’
/opt/zammad/app/models/scheduler.rb:237:in loop' /opt/zammad/app/models/scheduler.rb:237:inblock in start_job’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in block in create_with_logging_context' I, [2019-04-10T16:09:31.778880 #21094-69930862307100] INFO -- : fetching imap () E, [2019-04-10T16:09:34.338303 #21094-69931131225380] ERROR -- : Email address is already used for other user. (Exceptions::UnprocessableEntity) /opt/zammad/app/models/user.rb:1036:inensure_uniq_email’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.2/lib/active_support/callbacks.rb:413:in block in make_lambda' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.2/lib/active_support/callbacks.rb:197:inblock (2 levels) in halting’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.2/lib/active_support/callbacks.rb:601:in block (2 levels) in default_terminator' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.2/lib/active_support/callbacks.rb:600:incatch’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.2/lib/active_support/callbacks.rb:600:in block in default_terminator' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.2/lib/active_support/callbacks.rb:198:inblock in halting’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.2/lib/active_support/callbacks.rb:507:in block in invoke_before' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.2/lib/active_support/callbacks.rb:507:ineach’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.2/lib/active_support/callbacks.rb:507:in invoke_before' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.2/lib/active_support/callbacks.rb:130:inrun_callbacks’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.2/lib/active_support/callbacks.rb:827:in _run_validation_callbacks' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activemodel-5.1.6.2/lib/active_model/validations/callbacks.rb:114:inrun_validations!’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activemodel-5.1.6.2/lib/active_model/validations.rb:335:in valid?' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/validations.rb:65:invalid?’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/validations.rb:82:in perform_validations' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/validations.rb:50:insave!’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/attribute_methods/dirty.rb:43:in save!' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/transactions.rb:313:inblock in save!’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/transactions.rb:384:in block in with_transaction_returning_status' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/connection_adapters/abstract/database_statements.rb:235:inblock in transaction’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/connection_adapters/abstract/transaction.rb:194:in block in within_new_transaction' /opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/monitor.rb:214:inmon_synchronize’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/connection_adapters/abstract/transaction.rb:191:in within_new_transaction' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/connection_adapters/abstract/database_statements.rb:235:intransaction’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/transactions.rb:210:in transaction' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/transactions.rb:381:inwith_transaction_returning_status’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/transactions.rb:313:in save!' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/suppressor.rb:46:insave!’
/opt/zammad/lib/sequencer/unit/import/common/model/save.rb:21:in process' /opt/zammad/lib/sequencer/unit/import/common/model/mixin/skip/action.rb:47:inprocess’
/opt/zammad/lib/sequencer/unit/import/common/model/mixin/without_callback.rb:28:in block in process' /opt/zammad/lib/core_ext/activesupport/lib/active_support/callbacks.rb:27:inwithout_callback’
/opt/zammad/lib/sequencer/unit/import/common/model/mixin/without_callback.rb:41:in block (2 levels) in process' /opt/zammad/lib/core_ext/activesupport/lib/active_support/callbacks.rb:27:inwithout_callback’
/opt/zammad/lib/sequencer/unit/import/common/model/mixin/without_callback.rb:41:in block (2 levels) in process' /opt/zammad/lib/sequencer/unit/import/common/model/mixin/without_callback.rb:47:inprocess’
/opt/zammad/lib/sequencer/unit/base.rb:202:in process' /opt/zammad/lib/sequencer.rb:77:inblock (4 levels) in process’
/opt/zammad/lib/mixin/start_finish_logger.rb:7:in log_start_finish' /opt/zammad/lib/sequencer.rb:76:inblock (3 levels) in process’
/opt/zammad/lib/sequencer/state.rb:150:in process' /opt/zammad/lib/sequencer.rb:74:inblock (2 levels) in process’
/opt/zammad/lib/sequencer/units.rb:29:in block in each' /opt/zammad/lib/sequencer/units.rb:28:ineach’
/opt/zammad/lib/sequencer/units.rb:28:in each' /opt/zammad/lib/sequencer.rb:72:ineach_with_index’
/opt/zammad/lib/sequencer.rb:72:in block in process' /opt/zammad/lib/mixin/start_finish_logger.rb:7:inlog_start_finish’
/opt/zammad/lib/sequencer.rb:70:in process' /opt/zammad/lib/sequencer.rb:25:inprocess’
/opt/zammad/lib/sequencer/unit/import/common/sub_sequence/mixin/base.rb:34:in sequence_resource' /opt/zammad/lib/sequencer/unit/import/ldap/users/sub_sequence.rb:17:inblock in process’
/opt/zammad/lib/ldap.rb:79:in block in search' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/net-ldap-0.16.1/lib/net/ldap.rb:786:inblock (3 levels) in search’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/net-ldap-0.16.1/lib/net/ldap/connection.rb:445:in block (2 levels) in search' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/net-ldap-0.16.1/lib/net/ldap/connection.rb:399:inloop’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/net-ldap-0.16.1/lib/net/ldap/connection.rb:399:in block in search' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/net-ldap-0.16.1/lib/net/ldap/instrumentation.rb:19:ininstrument’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/net-ldap-0.16.1/lib/net/ldap/connection.rb:388:in search' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/net-ldap-0.16.1/lib/net/ldap.rb:784:inblock (2 levels) in search’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/net-ldap-0.16.1/lib/net/ldap.rb:1303:in use_connection' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/net-ldap-0.16.1/lib/net/ldap.rb:783:inblock in search’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/net-ldap-0.16.1/lib/net/ldap/instrumentation.rb:19:in instrument' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/net-ldap-0.16.1/lib/net/ldap.rb:782:insearch’
/opt/zammad/lib/ldap.rb:72:in search' /opt/zammad/lib/sequencer/unit/import/ldap/users/sub_sequence.rb:15:inprocess’
/opt/zammad/lib/import/mixin/sequence.rb:15:in process' /opt/zammad/lib/import/integration_base.rb:99:instart’
/opt/zammad/app/models/import_job.rb:24:in start' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/relation/delegation.rb:39:ineach’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/relation/delegation.rb:39:in each' /opt/zammad/app/models/import_job.rb:105:instart’
/opt/zammad/app/models/import_job.rb:95:in start_registered' (eval):1:in_start_job’
/opt/zammad/app/models/scheduler.rb:286:in eval' /opt/zammad/app/models/scheduler.rb:286:in_start_job’
/opt/zammad/app/models/scheduler.rb:258:in block in start_job' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:inblock in create_with_logging_context’
I, [2019-04-10T16:09:37.237775 #21092-47156864900580] INFO – : Completed 200 OK in 26183ms (Views: 2.8ms | ActiveRecord: 43.3ms)
I, [2019-04-10T16:09:37.403793 #21092-70210000225360] INFO – : Completed 200 OK in 26261ms (Views: 0.9ms | ActiveRecord: 23.0ms)
I, [2019-04-10T16:09:37.407813 #21092-47156866049940] INFO – : Completed 200 OK in 26255ms (Views: 0.4ms | ActiveRecord: 30.2ms)
I, [2019-04-10T16:09:37.465825 #21094-69930862307100] INFO – : - no message
I, [2019-04-10T16:09:37.489265 #21094-69930862307100] INFO – : done
I, [2019-04-10T16:09:37.490214 #21092-70210369432960] INFO – : Completed 200 OK in 26360ms (Views: 0.6ms | ActiveRecord: 41.3ms)
I, [2019-04-10T16:09:37.574398 #21092-47156854363840] INFO – : Started POST “/api/v1/message_receive” for ****** at 2019-04-10 16:09:37 +0200
I, [2019-04-10T16:09:37.589423 #21092-47156854363840] INFO – : Processing by LongPollingController#message_receive as JSON
I, [2019-04-10T16:09:37.589993 #21092-47156854363840] INFO – : Parameters: {“client_id”=>“"}
I, [2019-04-10T16:09:37.633461 #21092-70210672078180] INFO – : Started POST “/api/v1/message_receive” for ****** at 2019-04-10 16:09:37 +0200
I, [2019-04-10T16:09:37.648996 #21092-70210672078180] INFO – : Processing by LongPollingController#message_receive as JSON
I, [2019-04-10T16:09:37.649306 #21092-70210672078180] INFO – : Parameters: {“client_id”=>"
I, [2019-04-10T16:09:37.719855 #21092-47156859437780] INFO – : Started POST “/api/v1/message_receive” for ****** at 2019-04-10 16:09:37 +0200
I, [2019-04-10T16:09:37.734885 #21092-47156859437780] INFO – : Processing by LongPollingController#message_receive as JSON
I, [2019-04-10T16:09:37.737354 #21092-70210402771820] INFO – : Completed 200 OK in 26227ms (Views: 0.4ms | ActiveRecord: 24.2ms)
I, [2019-04-10T16:09:37.737695 #21092-47156859437780] INFO – : Parameters: {“client_id”=>“"}
I, [2019-04-10T16:09:37.914216 #21092-70210636229400] INFO – : Started POST “/api/v1/message_receive” for ****** at 2019-04-10 16:09:37 +0200
I, [2019-04-10T16:09:37.928051 #21092-70210636229400] INFO – : Processing by LongPollingController#message_receive as JSON
I, [2019-04-10T16:09:37.928348 #21092-70210636229400] INFO – : Parameters: {“client_id”=>"
I, [2019-04-10T16:09:38.075834 #21092-70209704478560] INFO – : Started POST “/api/v1/message_receive” for ****** at 2019-04-10 16:09:38 +0200
I, [2019-04-10T16:09:38.100347 #21092-70209704478560] INFO – : Processing by LongPollingController#message_receive as JSON
I, [2019-04-10T16:09:38.100793 #21092-70209704478560] INFO – : Parameters: {“client_id”=>“"}
I, [2019-04-10T16:09:38.428338 #21092-47156829954160] INFO – : Completed 200 OK in 26052ms (Views: 1.0ms | ActiveRecord: 5.8ms)
I, [2019-04-10T16:09:38.494953 #21092-47156847462900] INFO – : Completed 200 OK in 26002ms (Views: 1.2ms | ActiveRecord: 18.8ms)
I, [2019-04-10T16:09:38.675715 #21092-70210672078180] INFO – : Completed 200 OK in 1026ms (Views: 0.9ms | ActiveRecord: 5.1ms)
I, [2019-04-10T16:09:38.692150 #21092-47156816516920] INFO – : Started POST “/api/v1/message_receive” for ****** at 2019-04-10 16:09:38 +0200
I, [2019-04-10T16:09:38.734236 #21092-47156816516920] INFO – : Processing by LongPollingController#message_receive as JSON
I, [2019-04-10T16:09:38.734665 #21092-47156816516920] INFO – : Parameters: {“client_id”=>"
I, [2019-04-10T16:09:38.752170 #21094-69931131225380] INFO – : Enqueued SearchIndexJob (Job ID: f1691c-eb09-4ba-b12-08fb128c) to DelayedJob(default) with arguments: “User”, 4144
I, [2019-04-10T16:09:38.755240 #21092-70210132773480] INFO – : Completed 200 OK in 26082ms (Views: 0.5ms | ActiveRecord: 13.5ms)
I, [2019-04-10T16:09:38.757742 #21092-70210032935700] INFO – : Started POST “/api/v1/message_receive” for ****** at 2019-04-10 16:09:38 +0200
I, [2019-04-10T16:09:38.793891 #21092-47156859437780] INFO – : Completed 200 OK in 1053ms (Views: 0.6ms | ActiveRecord: 6.4ms)
I, [2019-04-10T16:09:38.807939 #21092-70210032935700] INFO – : Processing by LongPollingController#message_receive as JSON
I, [2019-04-10T16:09:38.808446 #21092-70210032935700] INFO – : Parameters: {“client_id”=>""}
I, [2019-04-10T16:09:38.904472 #21092-47156866210240] INFO – : Completed 200 OK in 26124ms (Views: 0.6ms | ActiveRecord: 58.3ms)
I, [2019-04-10T16:09:39.003376 #21094-47000521192020] INFO – : 2019-04-10T16:09:39+0200: [Worker(host:
** pid:21094)] Job ActiveJob::QueueAdapters::DelayedJobAdapter::JobWrapper (id=2946736) (queue=default) RUNNING
I, [2019-04-10T16:09:39.312725 #21092-70210171752840] INFO – : Started POST “/api/v1/message_receive” for ****** at 2019-04-10 16:09:39 +0200
I, [2019-04-10T16:09:39.327327 #21092-70210032932800] INFO – : Started POST “/api/v1/message_receive” for ****** at 2019-04-10 16:09:39 +0200
I, [2019-04-10T16:09:39.342974 #21092-47156859389800] INFO – : Started POST “/api/v1/message_receive” for ****** at 2019-04-10 16:09:39 +0200
I, [2019-04-10T16:09:39.352067 #21092-70210032932800] INFO – : Processing by LongPollingController#message_receive as JSON
I, [2019-04-10T16:09:39.361137 #21092-70210171752840] INFO – : Processing by LongPollingController#message_receive as JSON
I, [2019-04-10T16:09:39.376324 #21092-70210032932800] INFO – : Parameters: {“client_id”=>“"}
I, [2019-04-10T16:09:39.383771 #21092-70209704478560] INFO – : Completed 200 OK in 1282ms (Views: 0.8ms | ActiveRecord: 22.0ms)
I, [2019-04-10T16:09:39.394113 #21092-47156859389800] INFO – : Processing by LongPollingController#message_receive as JSON
I, [2019-04-10T16:09:39.417603 #21094-47000521192020] INFO – : Performing SearchIndexJob (Job ID: f16ee91c-eb09-4ba-b12-08fb128c) from DelayedJob(default) with arguments: “User”, 4144
I, [2019-04-10T16:09:39.394652 #21092-70210171752840] INFO – : Parameters: {“client_id”=>"
#6
Beside the failing mail login on IMAP, I’d be interested what your hardware specifications are and how many agents you have concurrent.
#7
Hello @MrGeneration
Hardware information: 2x4 CPU Cores and 16GB RAM.
And sorry what do you mean about “agents you have concurrent.”, and how can i check them?
Thank you in advance.
#8
I don’t think we have a tool that shows how many agents are online at a time.
What I mean with concurrent agents is the number of agents being online and workin in zammad at the same time.
CPU doesn’t look to bad (I mean if you’re not working with IDE drives :stuck_out_tongue: )
#9
Please, think to add one in the future zammad versions :laughing:
For the agents, 18 are working in zammad at the same time.
by the way, i have found this command her High Latency , Timeouts, tickets twice
zammad config:set WEB_CONCURRENCY=4
systemctl restart zammad
Is it useful in my case ?
#10
For me this helped:
After the restart the Delay in our System was away. In first step i set 2 Server processes. If needed i will try a higher Number :wink:
