I am having problems migrating a Zammad installation from Debian to CentOS (MySQL). The procedure throws errors and login doesn work after the migration.
Infos
- Used Zammad version: 3.4.0-1592470089.65376a81.jessie and 3.4.0-1596781606.1adc98bf.centos7
- Used Zammad installation source: deb and rpm via repositories
- Operating system: Debian 8 and CentOS 7.8
- Browser + version: not relevant
Migration procedure
- Old server (Debian):
- Created backup on the old server (services zammad and nginx being stopped)
- New server (CentOS):
- Installed Elasticsearch and MariaDB, established same MariaDB user as on old server and created (empty) “zammad” database (important, otherwise restore fails)
- Installed zammad from repo
- Copied from old server: backups,
/opt/zammad/contrib/backup/configand/opt/zammad/config/database.yml - ran
/opt/zammad/contrib/backup/zammad_restore.sh
Problems
Service doesn’t start up correctly
Zammad then doesn’t start up correctly (no ruby process on port 3000) and I find error message of type
zammad-zyx.service: bundler: failed to load command: script/xyzand zammad-xyz.service: LoadError: library not found for class Digest::SHA1 -- digest/sha1
in /var/log/messages. See a hopefully helpful extract here (shortened, as I am not allowed to post so much text
Aug 23 14:29:01 odcf-vm118 zammad-web-1.service: bundler: failed to load command: script/rails (script/rails)
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: bundler: failed to load command: script/scheduler.rb (script/scheduler.rb)
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: LoadError: library not found for class Digest::SHA1 -- digest/sha1
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/ruby-2.6.5/lib/ruby/2.6.0/digest.rb:16:in `const_missing'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/ruby-2.6.5/lib/ruby/2.6.0/digest.rb:100:in `block in Digest'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/ruby-2.6.5/lib/ruby/2.6.0/digest.rb:98:in `synchronize'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/ruby-2.6.5/lib/ruby/2.6.0/digest.rb:98:in `Digest'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/shared_helpers.rb:225:in `digest'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/source/git.rb:287:in `uri_hash'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/source/git.rb:321:in `git_scope'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/source/git.rb:216:in `cache_path'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/source/git.rb:299:in `git_proxy'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/source/git.rb:225:in `revision'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/source/git.rb:76:in `to_s'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/source_list.rb:85:in `each'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/source_list.rb:85:in `sort_by'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/source_list.rb:85:in `lock_sources'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/source_list.rb:104:in `replace_sources!'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/definition.rb:674:in `converge_sources'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/definition.rb:120:in `initialize'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/dsl.rb:234:in `new'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/dsl.rb:234:in `to_definition'
Aug 23 14:29:01 odcf-vm118 zammad-websocket-1.service: bundler: failed to load command: script/websocket-server.rb (script/websocket-server.rb)
Aug 23 14:29:01 odcf-vm118 zammad-websocket-1.service: LoadError: library not found for class Digest::SHA1 -- digest/sha1
Aug 23 14:29:01 odcf-vm118 zammad-websocket-1.service: /opt/zammad/vendor/ruby-2.6.5/lib/ruby/2.6.0/digest.rb:16:in `const_missing'
Aug 23 14:29:01 odcf-vm118 zammad-web-1.service: LoadError: library not found for class Digest::SHA1 -- digest/sha1
Aug 23 14:29:01 odcf-vm118 zammad-web-1.service: /opt/zammad/vendor/ruby-2.6.5/lib/ruby/2.6.0/digest.rb:16:in `const_missing'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/dsl.rb:13:in `evaluate'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/definition.rb:34:in `build'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler.rb:135:in `definition'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler.rb:101:in `setup'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/setup.rb:20:in `<top (required)>'
Aug 23 14:29:01 odcf-vm118 zammad-worker-1.service: /opt/zammad/vendor/ruby-2.6.5/lib/ruby/2.6.0/rubygems/core_ext/kernel_require.rb:54:in `require'
Aug 23 14:29:01 odcf-vm118 zammad-websocket-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/dsl.rb:13:in `evaluate'
Aug 23 14:29:01 odcf-vm118 zammad-websocket-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/definition.rb:34:in `build'
Aug 23 14:29:01 odcf-vm118 zammad-websocket-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler.rb:135:in `definition'
Aug 23 14:29:01 odcf-vm118 zammad-websocket-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler.rb:101:in `setup'
Aug 23 14:29:01 odcf-vm118 zammad-websocket-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/setup.rb:20:in `<top (required)>'
Aug 23 14:29:01 odcf-vm118 zammad-websocket-1.service: /opt/zammad/vendor/ruby-2.6.5/lib/ruby/2.6.0/rubygems/core_ext/kernel_require.rb:54:in `require'
Aug 23 14:29:01 odcf-vm118 zammad-web-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/definition.rb:34:in `build'
Aug 23 14:29:01 odcf-vm118 zammad-web-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler.rb:135:in `definition'
Aug 23 14:29:01 odcf-vm118 zammad-web-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler.rb:101:in `setup'
Aug 23 14:29:01 odcf-vm118 zammad-web-1.service: /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/setup.rb:20:in `<top (required)>'
Aug 23 14:29:01 odcf-vm118 zammad-web-1.service: /opt/zammad/vendor/ruby-2.6.5/lib/ruby/2.6.0/rubygems/core_ext/kernel_require.rb:54:in `require'
Aug 23 14:29:01 odcf-vm118 systemd: Unit zammad-web-1.service entered failed state.
Reinstallation fails, too
Since the migration documentation on https://docs.zammad.org/en/latest/appendix/backup-and-restore.html states, that sometimes a reinstallation of Zammad is required, I removed and reinstalled it (yum remove zammad; yum install zammad).
During the (re)installation I get various errors regarding an already existing table “smime_certificates” (also shortened due to post size restriction):
yum install zammad
Running transaction
Installing : zammad-3.4.0-1596781606.1adc98bf.centos7.x86_64 1/1
# (Re)creating init scripts
Nothing to do.
Nothing to do.
Nothing to do.
# Enabling Zammad on boot
# Stopping Zammad
rake aborted!
StandardError: An error has occurred, all later migrations canceled:
Mysql2::Error: Table 'smime_certificates' already exists: CREATE TABLE `smime_certificates` (`id` bigint NOT NULL AUTO_INCREMENT PRIMARY KEY, `subject` varchar(500) NOT NULL, `doc_hash` varchar(250) NOT NULL, `fingerprint` varchar(250) NOT NULL, `modulus` varchar(1024) NOT NULL, `not_before_at` datetime, `not_after_at` datetime, `raw` mediumblob NOT NULL, `private_key` mediumblob, `private_key_secret` varchar(500), `created_at` datetime(3) NOT NULL, `updated_at` datetime(3) NOT NULL)
Caused by:
ActiveRecord::StatementInvalid: Mysql2::Error: Table 'smime_certificates' already exists: CREATE TABLE `smime_certificates` (`id` bigint NOT NULL AUTO_INCREMENT PRIMARY KEY, `subject` varchar(500) NOT NULL, `doc_hash` varchar(250) NOT NULL, `fingerprint` varchar(250) NOT NULL, `modulus` varchar(1024) NOT NULL, `not_before_at` datetime, `not_after_at` datetime, `raw` mediumblob NOT NULL, `private_key` mediumblob, `private_key_secret` varchar(500), `created_at` datetime(3) NOT NULL, `updated_at` datetime(3) NOT NULL)
Caused by:
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/mysql2-0.4.10/lib/mysql2/client.rb:120:in `_query'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/mysql2-0.4.10/lib/mysql2/client.rb:120:in `block in query'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/mysql2-0.4.10/lib/mysql2/client.rb:119:in `handle_interrupt'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/mysql2-0.4.10/lib/mysql2/client.rb:119:in `query'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/connection_adapters/abstract_mysql_adapter.rb:187:in `block (2 levels) in execute'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.3/lib/active_support/dependencies/interlock.rb:48:in `block in permit_concurrent_loads'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.3/lib/active_support/concurrency/share_lock.rb:187:in `yield_shares'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.3/lib/active_support/dependencies/interlock.rb:47:in `permit_concurrent_loads'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/connection_adapters/abstract_mysql_adapter.rb:186:in `block in execute'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/connection_adapters/abstract_adapter.rb:581:in `block (2 levels) in log'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/connection_adapters/abstract_adapter.rb:580:in `block in log'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.3/lib/active_support/notifications/instrumenter.rb:23:in `instrument'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/connection_adapters/abstract_adapter.rb:571:in `log'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/connection_adapters/abstract_mysql_adapter.rb:185:in `execute'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/connection_adapters/mysql/database_statements.rb:28:in `execute'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/connection_adapters/abstract/schema_statements.rb:311:in `create_table'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/migration.rb:871:in `block in method_missing'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/migration.rb:840:in `block in say_with_time'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/migration.rb:840:in `say_with_time'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/migration.rb:860:in `method_missing'
/opt/zammad/db/migrate/20200121000001_smime_support.rb:57:in `up'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/migration.rb:817:in `exec_migration'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/migration.rb:798:in `block (2 levels) in migrate'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/migration.rb:797:in `block in migrate'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/connection_adapters/abstract/connection_pool.rb:416:in `with_connection'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/migration.rb:796:in `migrate'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/migration.rb:977:in `migrate'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/migration.rb:1292:in `block in execute_migration_in_transaction'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/migration.rb:1345:in `ddl_transaction'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/migration.rb:1291:in `execute_migration_in_transaction'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/migration.rb:1263:in `block in migrate_without_lock'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/migration.rb:1262:in `each'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/migration.rb:1262:in `migrate_without_lock'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/migration.rb:1210:in `block in migrate'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/migration.rb:1363:in `with_advisory_lock'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/migration.rb:1210:in `migrate'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/migration.rb:1036:in `up'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/migration.rb:1011:in `migrate'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/tasks/database_tasks.rb:172:in `migrate'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.3/lib/active_record/railties/databases.rake:60:in `block (2 levels) in <main>'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/exe/rake:27:in `<top (required)>'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:74:in `load'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:74:in `kernel_load'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:28:in `run'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:463:in `exec'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/invocation.rb:126:in `invoke_command'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor.rb:387:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:27:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/base.rb:466:in `start'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:18:in `start'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/exe/bundle:30:in `block in <top (required)>'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/friendly_errors.rb:124:in `with_friendly_errors'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/exe/bundle:22:in `<top (required)>'
Tasks: TOP => db:migrate
== 20200121000001 SMIMESupport: migrating =====================================
-- create_table(:smime_certificates)
# Updating translations...
-> removing [ingest-attachment]...
-> Installing ingest-attachment
-> Failed installing ingest-attachment
-> Rolling back ingest-attachment
-> Rolled back ingest-attachment
Exception in thread "main" java.net.ConnectException: Connection timed out
at java.base/sun.nio.ch.Net.connect0(Native Method)
at java.base/sun.nio.ch.Net.connect(Net.java:503)
at java.base/sun.nio.ch.Net.connect(Net.java:492)
at java.base/sun.nio.ch.NioSocketImpl.connect(NioSocketImpl.java:588)
at java.base/java.net.SocksSocketImpl.connect(SocksSocketImpl.java:333)
at java.base/java.net.Socket.connect(Socket.java:648)
at java.base/sun.security.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:290)
at java.base/sun.security.ssl.BaseSSLSocketImpl.connect(BaseSSLSocketImpl.java:173)
at java.base/sun.net.NetworkClient.doConnect(NetworkClient.java:182)
at java.base/sun.net.www.http.HttpClient.openServer(HttpClient.java:474)
at java.base/sun.net.www.http.HttpClient.openServer(HttpClient.java:569)
at java.base/sun.net.www.protocol.https.HttpsClient.<init>(HttpsClient.java:265)
at java.base/sun.net.www.protocol.https.HttpsClient.New(HttpsClient.java:372)
at java.base/sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(AbstractDelegateHttpsURLConnection.java:177)
at java.base/sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1194)
at java.base/sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1082)
at java.base/sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:163)
at java.base/sun.net.www.protocol.https.HttpsURLConnectionImpl.connect(HttpsURLConnectionImpl.java:142)
at org.elasticsearch.plugins.InstallPluginCommand.urlExists(InstallPluginCommand.java:418)
at org.elasticsearch.plugins.InstallPluginCommand.getElasticUrl(InstallPluginCommand.java:374)
at org.elasticsearch.plugins.InstallPluginCommand.download(InstallPluginCommand.java:305)
at org.elasticsearch.plugins.InstallPluginCommand.execute(InstallPluginCommand.java:251)
at org.elasticsearch.plugins.InstallPluginCommand.execute(InstallPluginCommand.java:224)
at org.elasticsearch.cli.EnvironmentAwareCommand.execute(EnvironmentAwareCommand.java:86)
at org.elasticsearch.cli.Command.mainWithoutErrorHandling(Command.java:127)
at org.elasticsearch.cli.MultiCommand.execute(MultiCommand.java:91)
at org.elasticsearch.cli.Command.main(Command.java:90)
at org.elasticsearch.plugins.PluginCli.main(PluginCli.java:47)
# Starting Zammad
# Restarting webserver nginx
/etc/nginx/conf.d/zammad.conf and restart nginx process.
Remember to enable selinux and firewall rules!
Use the following commands:
setsebool httpd_can_network_connect on -P
firewall-cmd --zone=public --add-service=http --permanent
firewall-cmd --zone=public --add-service=https --permanent
firewall-cmd --reload
Verifying : zammad-3.4.0-1596781606.1adc98bf.centos7.x86_64 1/1
Installed:
zammad.x86_64 0:3.4.0-1596781606.1adc98bf.centos7
Complete!
This time the zammad service starts and the webpage then shows up, but I cannot log in (“CSRF Token verification failed” even though all cookes have been cleared).
Any help is highly appreciated.
Frank
