Zammad in LXC Works
I just wanted to create a post to update the solution from this post:
The above post states Zammad does not work in an LXC container. I have two separate installs in two separate LXC containers.
I was getting the same error (from this post) after installing a second Zammad in an LXC container using the script here:
I went into the LXC container…
cd /etc/nginx/sites-available
nano zammad.conf
Changed the container’s ip address:
server_name 192.168.100.106;
To my subdomain:
server_name support.domainname.com;
Saved and exited.
Then:
nginx -t
systemctl reload nginx
That’s it!
To be clear, at this point I already had the subdomain created at my domain’s host, with an A record pointing to my router, and then the router forwarding traffic to my proxy. The proxy was already set up and had SSL certificates installed.
I’d say this has nothing to do with LXC containers in general.
I also had no issuse with the helper scipt and running it in LXC. However - it all went to hell when I tried to follow instructions for setting up ssl… Did you get SSL working? How?
