Getting Welcome to Nginx using subdomain
  • Used Zammad version: Zammad V6.0
  • Operating system: Ubuntu 20.04 LXC container
  • Browser + version: Brave and or Edge
I am wanting to try and get Zammad up and running and so far it does but only on LAN and on http connection. I want to use my Nginx Proxy Manager on a different VM (same physical host) but the issue i am facing right now is that when i enter my subdomain which i have also entered in the zammad.conf in /etc/nginx/sites-enabled i get the “Welcome to Nginx”. When i have the subdomain in the zammad.conf i also get the same page on the lan but if i enter the servers actual ip i get the zammad interface on the lan side and still the “Welcome to Nginx” on the WAN.
I have included my zammad.conf in the post.
upstream zammad-railsserver {
    server 127.0.0.1:3000;
upstream zammad-websocket {
    server 127.0.0.1:6042;
server {
    listen 80;
    listen [::]:80;
    server_name 192.168.1.249;
    server_tokens off;
    root /opt/zammad/public;
    error_log  /var/log/nginx/zammad.error.log;
    client_max_body_size 50M;
        expires max;
    # legacy web socket server
    location /ws {
        proxy_http_version 1.1;
        proxy_read_timeout 86400;
    # action cable
    location /cable {
    location / {
        # Change this line in an SSO setup
        proxy_read_timeout 300;
        gzip on;
        gzip_proxied any;
Turns out it was due to it being hosted in an LXC container so for anyone wanting to do that aswell, just don´t because it will not work.
