I just saw that zammad was upgraded during the night and it crashed my installation.
Everytime i tried to log into Zammad i got this error:
Mysql2::Error: Unknown column 'statsstores.statsstorabletype' in 'where clause': SELECT
stats</u>stores.* FROMstats<u>storesWHEREstats</u>stores.stats<u>storable</u>type= 'User' ANDstats<u>stores.stats</u>storable<u>id= 3 ANDstats</u>stores.key= 'dashboard' LIMIT 1
After i reinstalled the 3.5 version everything worked again.
- Used Zammad version: 3.6
- Used Zammad installation source: source
Mysql2::Error: Unknown column 'statsstores.statsstorabletype' in 'where clause': SELECT stats</u>stores.* FROM stats<u>stores WHERE stats</u>stores.stats<u>storable</u>type = 'User' AND stats<u>stores.stats</u>storable<u>id = 3 AND stats</u>stores.key = 'dashboard' LIMIT 1
root@XXXXXXXXXXXXX:~# apt-get install zammad Reading package lists... Done Building dependency tree Reading state information... Done The following NEW packages will be installed: zammad 0 upgraded, 1 newly installed, 0 to remove and 3 not upgraded. Need to get 258 MB of archives. After this operation, 710 MB of additional disk space will be used. Get:1 https://dl.packager.io/srv/deb/zammad/zammad/stable/ubuntu 18.04/main amd64 zammad amd64 3.6.0-1605492102.99dfd900.bionic [258 MB] Fetched 258 MB in 5s (48.8 MB/s) Selecting previously unselected package zammad. (Reading database ... 116514 files and directories currently installed.) Preparing to unpack .../zammad_3.6.0-1605492102.99dfd900.bionic_amd64.deb ... Unpacking zammad (3.6.0-1605492102.99dfd900.bionic) ... Setting up zammad (3.6.0-1605492102.99dfd900.bionic) ... # (Re)creating init scripts Nothing to do. Nothing to do. Nothing to do. # Enabling Zammad on boot # Stopping Zammad # database.yml found. Updating db... == 20200121000001 SMIMESupport: migrating ===================================== -- create_table(:smime_certificates) rake aborted! StandardError: An error has occurred, all later migrations canceled: Mysql2::Error: Table 'smime_certificates' already exists: CREATE TABLE `smime_certificates` (`id` bigint NOT NULL AUTO_INCREMENT PRIMARY KEY, `subject` varchar(500) NOT NULL, `doc_hash` varchar(250) NOT NULL, `fingerprint` varchar(250) NOT NULL, `modulus` varchar(1024) NOT NULL, `not_before_at` datetime, `not_after_at` datetime, `raw` mediumblob NOT NULL, `private_key` mediumblob, `private_key_secret` varchar(500), `created_at` datetime(3) NOT NULL, `updated_at` datetime(3) NOT NULL) /opt/zammad/vendor/bundle/ruby/2.6.0/gems/mysql2-0.4.10/lib/mysql2/client.rb:120:in `_query' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/mysql2-0.4.10/lib/mysql2/client.rb:120:in `block in query' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/mysql2-0.4.10/lib/mysql2/client.rb:119:in `handle_interrupt' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/mysql2-0.4.10/lib/mysql2/client.rb:119:in `query' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract_mysql_adapter.rb:187:in `block (2 levels) in execute' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/dependencies/interlock.rb:48:in `block in permit_concurrent_loads' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/concurrency/share_lock.rb:187:in `yield_shares' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/dependencies/interlock.rb:47:in `permit_concurrent_loads' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract_mysql_adapter.rb:186:in `block in execute' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract_adapter.rb:581:in `block (2 levels) in log' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract_adapter.rb:580:in `block in log' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/notifications/instrumenter.rb:23:in `instrument' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract_adapter.rb:571:in `log' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract_mysql_adapter.rb:185:in `execute' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/mysql/database_statements.rb:28:in `execute' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract/schema_statements.rb:311:in `create_table' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:871:in `block in method_missing' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:840:in `block in say_with_time' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:840:in `say_with_time' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:860:in `method_missing' /opt/zammad/db/migrate/20200121000001_smime_support.rb:57:in `up' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:817:in `exec_migration' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:798:in `block (2 levels) in migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:797:in `block in migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract/connection_pool.rb:416:in `with_connection' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:796:in `migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:977:in `migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1292:in `block in execute_migration_in_transaction' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1345:in `ddl_transaction' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1291:in `execute_migration_in_transaction' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1263:in `block in migrate_without_lock' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1262:in `each' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1262:in `migrate_without_lock' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1210:in `block in migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1363:in `with_advisory_lock' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1210:in `migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1036:in `up' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1011:in `migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/tasks/database_tasks.rb:172:in `migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/railties/databases.rake:60:in `block (2 levels) in <main>' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/exe/rake:27:in `<top (required)>' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:74:in `load' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:74:in `kernel_load' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:28:in `run' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:463:in `exec' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/invocation.rb:126:in `invoke_command' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor.rb:387:in `dispatch' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:27:in `dispatch' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/base.rb:466:in `start' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:18:in `start' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/exe/bundle:30:in `block in <top (required)>' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/friendly_errors.rb:124:in `with_friendly_errors' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/exe/bundle:22:in `<top (required)>' /opt/zammad/bin/bundle:3:in `load' /opt/zammad/bin/bundle:3:in `<main>' Caused by: ActiveRecord::StatementInvalid: Mysql2::Error: Table 'smime_certificates' already exists: CREATE TABLE `smime_certificates` (`id` bigint NOT NULL AUTO_INCREMENT PRIMARY KEY, `subject` varchar(500) NOT NULL, `doc_hash` varchar(250) NOT NULL, `fingerprint` varchar(250) NOT NULL, `modulus` varchar(1024) NOT NULL, `not_before_at` datetime, `not_after_at` datetime, `raw` mediumblob NOT NULL, `private_key` mediumblob, `private_key_secret` varchar(500), `created_at` datetime(3) NOT NULL, `updated_at` datetime(3) NOT NULL) /opt/zammad/vendor/bundle/ruby/2.6.0/gems/mysql2-0.4.10/lib/mysql2/client.rb:120:in `_query' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/mysql2-0.4.10/lib/mysql2/client.rb:120:in `block in query' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/mysql2-0.4.10/lib/mysql2/client.rb:119:in `handle_interrupt' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/mysql2-0.4.10/lib/mysql2/client.rb:119:in `query' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract_mysql_adapter.rb:187:in `block (2 levels) in execute' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/dependencies/interlock.rb:48:in `block in permit_concurrent_loads' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/concurrency/share_lock.rb:187:in `yield_shares' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/dependencies/interlock.rb:47:in `permit_concurrent_loads' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract_mysql_adapter.rb:186:in `block in execute' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract_adapter.rb:581:in `block (2 levels) in log' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract_adapter.rb:580:in `block in log' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/notifications/instrumenter.rb:23:in `instrument' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract_adapter.rb:571:in `log' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract_mysql_adapter.rb:185:in `execute' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/mysql/database_statements.rb:28:in `execute' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract/schema_statements.rb:311:in `create_table' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:871:in `block in method_missing' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:840:in `block in say_with_time' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:840:in `say_with_time' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:860:in `method_missing' /opt/zammad/db/migrate/20200121000001_smime_support.rb:57:in `up' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:817:in `exec_migration' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:798:in `block (2 levels) in migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:797:in `block in migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract/connection_pool.rb:416:in `with_connection' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:796:in `migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:977:in `migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1292:in `block in execute_migration_in_transaction' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1345:in `ddl_transaction' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1291:in `execute_migration_in_transaction' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1263:in `block in migrate_without_lock' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1262:in `each' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1262:in `migrate_without_lock' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1210:in `block in migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1363:in `with_advisory_lock' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1210:in `migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1036:in `up' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1011:in `migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/tasks/database_tasks.rb:172:in `migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/railties/databases.rake:60:in `block (2 levels) in <main>' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/exe/rake:27:in `<top (required)>' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:74:in `load' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:74:in `kernel_load' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:28:in `run' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:463:in `exec' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/invocation.rb:126:in `invoke_command' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor.rb:387:in `dispatch' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:27:in `dispatch' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/base.rb:466:in `start' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:18:in `start' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/exe/bundle:30:in `block in <top (required)>' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/friendly_errors.rb:124:in `with_friendly_errors' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/exe/bundle:22:in `<top (required)>' /opt/zammad/bin/bundle:3:in `load' /opt/zammad/bin/bundle:3:in `<main>' Caused by: Mysql2::Error: Table 'smime_certificates' already exists /opt/zammad/vendor/bundle/ruby/2.6.0/gems/mysql2-0.4.10/lib/mysql2/client.rb:120:in `_query' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/mysql2-0.4.10/lib/mysql2/client.rb:120:in `block in query' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/mysql2-0.4.10/lib/mysql2/client.rb:119:in `handle_interrupt' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/mysql2-0.4.10/lib/mysql2/client.rb:119:in `query' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract_mysql_adapter.rb:187:in `block (2 levels) in execute' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/dependencies/interlock.rb:48:in `block in permit_concurrent_loads' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/concurrency/share_lock.rb:187:in `yield_shares' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/dependencies/interlock.rb:47:in `permit_concurrent_loads' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract_mysql_adapter.rb:186:in `block in execute' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract_adapter.rb:581:in `block (2 levels) in log' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract_adapter.rb:580:in `block in log' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/notifications/instrumenter.rb:23:in `instrument' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract_adapter.rb:571:in `log' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract_mysql_adapter.rb:185:in `execute' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/mysql/database_statements.rb:28:in `execute' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract/schema_statements.rb:311:in `create_table' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:871:in `block in method_missing' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:840:in `block in say_with_time' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:840:in `say_with_time' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:860:in `method_missing' /opt/zammad/db/migrate/20200121000001_smime_support.rb:57:in `up' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:817:in `exec_migration' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:798:in `block (2 levels) in migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:797:in `block in migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract/connection_pool.rb:416:in `with_connection' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:796:in `migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:977:in `migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1292:in `block in execute_migration_in_transaction' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1345:in `ddl_transaction' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1291:in `execute_migration_in_transaction' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1263:in `block in migrate_without_lock' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1262:in `each' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1262:in `migrate_without_lock' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1210:in `block in migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1363:in `with_advisory_lock' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1210:in `migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1036:in `up' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/migration.rb:1011:in `migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/tasks/database_tasks.rb:172:in `migrate' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/railties/databases.rake:60:in `block (2 levels) in <main>' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/exe/rake:27:in `<top (required)>' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:74:in `load' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:74:in `kernel_load' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:28:in `run' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:463:in `exec' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/invocation.rb:126:in `invoke_command' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor.rb:387:in `dispatch' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:27:in `dispatch' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/base.rb:466:in `start' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:18:in `start' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/exe/bundle:30:in `block in <top (required)>' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/friendly_errors.rb:124:in `with_friendly_errors' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/exe/bundle:22:in `<top (required)>' /opt/zammad/bin/bundle:3:in `load' /opt/zammad/bin/bundle:3:in `<main>' Tasks: TOP => db:migrate (See full trace by running task with --trace) # Updating translations... # Configuring Elasticsearch... -> removing [ingest-attachment]... -> Installing ingest-attachment -> Downloading ingest-attachment from elastic [=================================================] 100% @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @ WARNING: plugin requires additional permissions @ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ * java.lang.RuntimePermission accessClassInPackage.sun.java2d.cmm.kcms * java.lang.RuntimePermission accessDeclaredMembers * java.lang.RuntimePermission getClassLoader * java.lang.reflect.ReflectPermission suppressAccessChecks * java.security.SecurityPermission createAccessControlContext * java.security.SecurityPermission insertProvider * java.security.SecurityPermission putProviderProperty.BC See http://docs.oracle.com/javase/8/docs/technotes/guides/security/permissions.html for descriptions of what these permissions allow and the associated risks. -> Installed ingest-attachment # Starting Zammad cp: cannot create regular file '/etc/nginx/sites-available/zammad.conf': No such file or directory ln: failed to create symbolic link '/etc/nginx/sites-enabled/zammad.conf': No such file or directory # Creating webserver bootstart Synchronizing state of nginx.service with SysV service script with /lib/systemd/systemd-sysv-install. Executing: /lib/systemd/systemd-sysv-install enable nginx # Restarting webserver nginx Job for nginx.service failed because the control process exited with error code. See "systemctl status nginx.service" and "journalctl -xe" for details. #################################################################################### Add your fully qualified domain name or public IP to servername directive of nginx, if this installation is done on a remote server. You have to change: /etc/nginx/sites-available/zammad.conf and restart nginx process. Otherwise just open http://localhost/ in your browser to start using Zammad. ####################################################################################
