Zammad-android client
After my issue: Integrating zammad into our android app · Issue #757 · zammad/zammad · GitHub I was able to successfully integrate Zammad in our company app to provide a management backend to our actions: in the office we use the desktop web-based interface for Zammad, while when we are away, out of office, we can use our app.
I recently realized that many people are requesting a mobile port of zammad:
Android App · Issue #351 · zammad/zammad · GitHub
Support for Tablets/Mobile (Responsive) · Issue #223 · zammad/zammad · GitHub
So I decided to separate the Zammad code in a separate library (even in the sake of modularizing the codebase), and publish it on github:
It’s a modern client written in Kotlin, for android. but it can be eventually cross-compiled for a lot of things.
I’m willing to maintaining it in the future.
I hope it will be usefull to you if you need a mobile interface at all cost.
Luca
PS: It would be real nice if anyone could update the documentation with all the endpoints, and maybe even the attributes type, nullability for all the models. I would make mapping a lot easier.
Hi @KirkBushman,
You might want to take a peek here, and it will give them a thread.
Thanks, I’ll give my 2 cents.
Really great work @KirkBushman ! I can see a lot of use cases for this.
We will do this but in the meantime you can have a look at the .NET client which already has this: Zammad.Client/src/Zammad.Client/Resources at master · Asesjix/Zammad.Client · GitHub
Let me know if you miss something.
@MrGeneration - can you please add this to the list of clients/libs in the documentation? We have to point out that this is not an app but a API client.
Will do, thanks in the meanwhile.
Yes it is a client library with a sample app at most, not a fully featured app.
Done, hope that’s good enough :slight_smile:
I’ll see to find some spare time to run through the API docs, bear with me.
Thank you, happy to help if needs be :slight_smile:
