A condition should be fulfilled if one of several words is contained.
I can’t find a way to search multiple words in a text. I tried using comma, semicolon and space as separators, but then a single search term is no longer found.
Sorry, at the moment regex is not possible within Triggers.
If you happen to have this text within incoming mails already, you could use filters which support regex.
It does not only concern mails, but also notes that are created internally. So thank you for your help… I’ll treat you to your evening off and make a feature request out of this problem, too.
