I tailed the production.log and tried to reproduce the error and was able to catch where the status changed from new to closed and I’m honestly not sure why. I’ve included the clip of the log.
production.log
W, [2021-11-05T02:55:01.949757 #939775-179480] WARN -- : Scoped order is ignored, it's forced to be batch order.
I, [2021-11-05T02:55:02.470861 #939651-182460] INFO -- : execute Job.run (try_count 0)...
I, [2021-11-05T02:55:02.472321 #939651-182460] INFO -- : ended Job.run took: 0.083414632 seconds.
I, [2021-11-05T02:55:02.538544 #939775-179480] INFO -- : Completed 200 OK in 938ms (Views: 3.2ms | ActiveRecord: 577.8ms | Allocations: 145111)
I, [2021-11-05T02:55:02.690587 #939775-179480] INFO -- : Started GET "/api/v1/ticket_customer?customer_id=3362&_=1636080493460" for 71.226.94.214 at 2021-11-05 02:55:02 +0000
I, [2021-11-05T02:55:02.696603 #939775-179480] INFO -- : Processing by TicketsController#ticket_customer as JSON
I, [2021-11-05T02:55:02.696695 #939775-179480] INFO -- : Parameters: {"customer_id"=>"3362", "_"=>"1636080493460"}
I, [2021-11-05T02:55:02.724628 #939775-179480] INFO -- : Completed 200 OK in 28ms (Views: 1.5ms | ActiveRecord: 5.5ms | Allocations: 20097)
I, [2021-11-05T02:55:02.824062 #939762-173980] INFO -- : Started GET "/api/v1/users/image/3074b1e501fedb1205c322607e753ece" for 71.226.94.214 at 2021-11-05 02:55:02 +0000
I, [2021-11-05T02:55:02.827676 #939762-173980] INFO -- : Processing by UsersController#image as HTML
I, [2021-11-05T02:55:02.827722 #939762-173980] INFO -- : Parameters: {"hash"=>"3074b1e501fedb1205c322607e753ece"}
I, [2021-11-05T02:55:02.835915 #939762-173980] INFO -- : Rendering text template
I, [2021-11-05T02:55:02.835984 #939762-173980] INFO -- : Rendered text template (Duration: 0.0ms | Allocations: 1)
I, [2021-11-05T02:55:02.836055 #939762-173980] INFO -- : Sent data avatar (0.4ms)
I, [2021-11-05T02:55:02.836789 #939762-173980] INFO -- : Completed 200 OK in 9ms (Views: 0.3ms | ActiveRecord: 1.9ms | Allocations: 5579)
I, [2021-11-05T02:55:02.974220 #939762-173820] INFO -- : Started DELETE "/api/v1/upload_caches/080957716" for 71.226.94.214 at 2021-11-05 02:55:02 +0000
I, [2021-11-05T02:55:02.977575 #939762-173820] INFO -- : Processing by UploadCachesController#destroy as JSON
I, [2021-11-05T02:55:02.977620 #939762-173820] INFO -- : Parameters: {"id"=>"080957716"}
I, [2021-11-05T02:55:02.987065 #939762-173820] INFO -- : Completed 200 OK in 9ms (Views: 0.1ms | ActiveRecord: 1.8ms | Allocations: 6657)
I, [2021-11-05T02:55:03.125969 #939762-173820] INFO -- : Started POST "/api/v1/integration/smime" for 71.226.94.214 at 2021-11-05 02:55:03 +0000
I, [2021-11-05T02:55:03.132655 #939762-173820] INFO -- : Processing by Integration::SMIMEController#search as JSON
I, [2021-11-05T02:55:03.132757 #939762-173820] INFO -- : Parameters: {"ticket"=>{"group_id"=>"1", "owner_id"=>"1", "state_id"=>"1", "priority_id"=>"2", "pending_time"=>nil}, "article"=>{"body"=>"[FILTERED]", "type"=>"note", "internal"=>true, "form_id"=>"080957716", "subtype"=>"", "in_reply_to"=>"", "to"=>"", "cc"=>"", "subject"=>"", "attachments"=>[]}}
I, [2021-11-05T02:55:03.667814 #939651-173940] INFO -- : 2021-11-05T02:55:03+0000: [Worker(host:webhost005.XXXXthink.in pid:939651)] Job TicketUserTicketCounterJob [082ca1a9-78c1-435d-adcf-002c33e92337] from DelayedJob(default) with arguments: [3362, 3] (id=971513) (queue=default) RUNNINGorker(host:webhost005.XXXXthink.in pid:939651)] Job TicketUserTicketCounterJob [082ca1a9-78c1-435d-adcf-002c33e92337]
from DelayedJob(default) with arguments: [3362, 3] (id=971513) (queue=default) COMPLETED after 0.8636ost005.XXXXthink.in pid:939651)] Job TransactionJob [23b6f7a0-5ccd-428b-a196-e635ae62352e] from Delayed
Job(default) with arguments: [{"object"=>"Ticket", "object_id"=>10268, "user_id"=>3, "created_at"=>{"_aj_serialized"=>"ActiveJob::Serializers::TimeWithZoneSerializer", "value"=>"2021-11-05T02:55:01Z"}, "type"=>"update", "changes"=>{"group_id"=>[5, 1], "_aj_symbol_keys"=>[]}, "_aj_symbol_keys"=>["object", "object_id", "user_id", "created_at", "type", "changes"]}, {"interface_handle"=>"application_server", "_aj_symbol_keys"=>["interface_handle"]}] (id=971514) (queue=default) RUNNINGameters: {"key"=>"Ticket-10268", "client_id"=>"123", "callback"=>"TicketZoom", "state"=>{"ticket"=>{}, "article"=>{"form_id"=>"080957716"}}, "params
"=>{"ticket_id"=>10268, "overview_id"=>2, "shown"=>true}, "prio"=>3, "notify"=>false, "active"=>true, "attachments"=>[], "updated_at"=>"2021-11-05T02:53:45.513Z", "id"=>"39014"}8b-a196-e635ae62352e] from Delayed
Job(default) with arguments: [{"object"=>"Ticket", "object_id"=>10268, "user_id"=>3, "created_at"=>{"_aj_serialized"=>"ActiveJob::Serializers::TimeWithZoneSerializer", "value"=>"2021-11-05T02:55:01Z"}, "type"=>"update", "changes"=>{"group_id"=>[5, 1], "_aj_symbol_keys"=>[]}, "_aj_symbol_keys"=>["object", "object_id", "user_id", "created_at", "type", "changes"]}, {"interface_handle"=>"application_server", "_aj_symbol_keys"=>["interface_handle"]}] (id=971514) (queue=default) COMPLETED after 0.4268default) RUNNINGst:webhost005.XXXXthink.in pid:939651)] Job SearchIndexAssociationsJob [6cc66ff2-e277-49e1-a474-c4b259a0046f]
from DelayedJob(default) with arguments: ["Ticket", 10268] (id=971511) (queue=default) COMPLETED after 0.5800rogressivethink.in pid:939651)] Job SearchIndexJob [7cb56442-6546-4354-af71-c72cf389bf03] from Delayed
Job(default) with arguments: ["User", 3362] (id=971512) (queue=default) RUNNING000: [Worker(host:webhost005.XXXXthink.in pid:939651)] Job SearchIndexJob [7cb56442-6546-4354-af71-c72cf389bf03] from Delayed
Job(default) with arguments: ["User", 3362] (id=971512) (queue=default) COMPLETED after 0.4694..
I, [2021-11-05T02:55:10.563212 #939651-176660] INFO -- : fetching imap (mail.XXXX.net/info@XXXX.net port=993,ssl=true,starttls=false,folder=INBOX,keep_on_server=true,auth_type=LOGIN)
I, [2021-11-05T02:55:10.591326 #939651-176660] INFO -- : - no message
I, [2021-11-05T02:55:10.737388 #939651-176660] INFO -- : ended Channel.fetch took: 0.399124971 seconds.
I, [2021-11-05T02:55:12.206546 #939763-176120] INFO -- : Started PUT "/api/v1/taskbar/39014" for 71.226.94.214 at 2021-11-05 02:55:12 +0000
I, [2021-11-05T02:55:12.216655 #939763-176120] INFO -- : Processing by TaskbarController#update as JSON
I, [2021-11-05T02:55:12.216859 #939763-176120] INFO -- : Parameters: {"key"=>"Ticket-10268", "client_id"=>"123", "callback"=>"TicketZoom", "state"=>{"ticket"=>{}, "article"=>{"form_id"=>"080957716"}}, "params"=>{"ticket_id"=>10268, "overview_id"=>2, "shown"=>true}, "prio"=>3, "notify"=>false, "active"=>false, "attachments"=>[], "updated_at"=>"2021-11-05T02:53:45.513Z", "id"=>"39014"}
I, [2021-11-05T02:55:12.330019 #939763-176120] INFO -- : Completed 200 OK in 113ms (Views: 0.6ms | ActiveRecord: 91.8ms | Allocations: 13472)
I, [2021-11-05T02:55:12.516650 #939763-176120] INFO -- : Started PUT "/api/v1/taskbar/39015" for 71.226.94.214 at 2021-11-05 02:55:12 +0000
I, [2021-11-05T02:55:12.525268 #939763-176120] INFO -- : Processing by TaskbarController#update as JSON
I, [2021-11-05T02:55:12.525427 #939763-176120] INFO -- : Parameters: {"key"=>"Ticket-10269", "client_id"=>"123", "callback"=>"TicketZoom", "state"=>{"ticket"=>{}, "article"=>{"form_id"=>"080961099"}}, "params"=>{"ticket_id"=>10269, "overview_id"=>2, "shown"=>true}, "prio"=>4, "notify"=>false, "active"=>true, "attachments"=>[], "updated_at"=>"2021-11-05T02:54:53.556Z", "id"=>"39015"}
I, [2021-11-05T02:55:12.924244 #939763-176120] INFO -- : Completed 200 OK in 399ms (Views: 0.5ms | ActiveRecord: 375.8ms | Allocations: 13474)
I, [2021-11-05T02:55:14.292635 #939763-175980] INFO -- : Started PUT "/api/v1/taskbar/39015" for 71.226.94.214 at 2021-11-05 02:55:14 +0000
I, [2021-11-05T02:55:14.296177 #939763-175980] INFO -- : Processing by TaskbarController#update as JSON
I, [2021-11-05T02:55:14.296259 #939763-175980] INFO -- : Parameters: {"key"=>"Ticket-10269", "client_id"=>"123", "callback"=>"TicketZoom", "state"=>{"ticket"=>{}, "article"=>{"body"=>"[FILTERED]", "type"=>"email", "internal"=>false, "subtype"=>"reply", "in_reply_to"=>"<CAPZmVv+EQxe1G5V-GFeNOaxSe_MiOAmF=eqQbH6N6gf4-3-C5Q@mail.gmail.com>", "to"=>"XXXX@gmail.com", "from"=>"XXXX XXXX", "ticket_id"=>"10269", "content_type"=>"text/html", "sender_id"=>"1", "type_id"=>"1", "form_id"=>"080961099"}}, "params"=>{"ticket_id"=>10269, "overview_id"=>2, "shown"=>true}, "prio"=>4, "notify"=>false, "active"=>true, "attachments"=>[], "updated_at"=>"2021-11-05T02:54:53.556Z", "id"=>"39015"}
I, [2021-11-05T02:55:14.448220 #939763-175980] INFO -- : Completed 200 OK in 152ms (Views: 0.5ms | ActiveRecord: 133.0ms | Allocations: 14302)
I, [2021-11-05T02:55:22.443349 #939651-5220] INFO -- : Scheduler running...
I, [2021-11-05T02:55:22.448470 #939651-5220] INFO -- : Running job thread for 'Process escalation tickets' (Ticket.process_escalation) status is: sleep
I, [2021-11-05T02:55:22.448773 #939651-5220] INFO -- : Running job thread for 'Check Channels' (Channel.fetch) status is: sleep
I, [2021-11-05T02:55:22.448942 #939651-5220] INFO -- : Running job thread for 'Check streams for Channel' (Channel.stream) status is: sleep
I, [2021-11-05T02:55:22.449063 #939651-5220] INFO -- : Running job thread for 'Generate Session data' (Sessions.jobs) status is: sleep
I, [2021-11-05T02:55:22.877858 #939651-284300] INFO -- : execute DataPrivacyTaskJob.perform_now (try_count 0)...
I, [2021-11-05T02:55:22.885013 #939651-284300] INFO -- : ended DataPrivacyTaskJob.perform_now took: 0.434395409 seconds.
I, [2021-11-05T02:55:32.542448 #939651-284360] INFO -- : execute Chat.cleanup_close (try_count 0)...
I, [2021-11-05T02:55:32.544742 #939651-284360] INFO -- : ended Chat.cleanup_close took: 0.082583476 seconds.
I, [2021-11-05T02:55:40.850580 #939651-176660] INFO -- : execute Channel.fetch (try_count 0)...
I, [2021-11-05T02:55:40.851555 #939651-176660] INFO -- : fetching imap (mail.XXXX.net/info@XXXX.net port=993,ssl=true,starttls=false,folder=INBOX,keep_on_server=true,auth_type=LOGIN)
I, [2021-11-05T02:55:40.876340 #939651-176660] INFO -- : - no message
I, [2021-11-05T02:55:41.216182 #939651-176660] INFO -- : ended Channel.fetch took: 0.477083965 seconds.
I, [2021-11-05T02:55:42.471378 #939651-5220] INFO -- : Running job thread for 'Execute jobs' (Job.run) status is: sleep
I, [2021-11-05T02:56:08.070891 #939775-179640] INFO -- : Started PUT "/api/v1/taskbar/39015" for 71.226.94.214 at 2021-11-05 02:56:08 +0000
I, [2021-11-05T02:56:08.082301 #939775-179640] INFO -- : Processing by TaskbarController#update as JSON
I, [2021-11-05T02:56:08.082607 #939775-179640] INFO -- : Parameters: {"key"=>"Ticket-10269", "client_id"=>"123", "callback"=>"TicketZoom", "state"=>{"ticket"=>{}, "article"=>{"body"=>"[FILTERED]", "type"=>"email", "internal"=>false, "subtype"=>"reply", "in_reply_to"=>"<CAPZmVv+EQxe1G5V-GFeNOaxSe_MiOAmF=eqQbH6N6gf4-3-C5Q@mail.gmail.com>", "to"=>"XXXX@gmail.com", "from"=>"XXXX XXXX", "ticket_id"=>"10269", "content_type"=>"text/html", "sender_id"=>"1", "type_id"=>"1", "form_id"=>"080961099"}}, "params"=>{"ticket_id"=>10269, "overview_id"=>2, "shown"=>true}, "prio"=>4, "notify"=>false, "active"=>true, "attachments"=>[], "updated_at"=>"2021-11-05T02:54:53.556Z", "id"=>"39015"}
I, [2021-11-05T02:56:08.289183 #939775-179640] INFO -- : Completed 200 OK in 206ms (Views: 0.3ms | ActiveRecord: 123.5ms | Allocations: 14812)
I, [2021-11-05T02:56:08.315452 #939775-173440] INFO -- : Started PUT "/api/v1/tickets/10269?all=true" for 71.226.94.214 at 2021-11-05 02:56:08 +0000
I, [2021-11-05T02:56:08.322175 #939775-173440] INFO -- : Processing by TicketsController#update as JSON
I, [2021-11-05T02:56:08.322254 #939775-173440] INFO -- : Parameters: {"number"=>"9110268", "title"=>"testing again", "group_id"=>"1", "owner_id"=>1, "customer_id"=>3, "state_id"=>"1", "priority_id"=>"2", "article"=>{"from"=>"XXXX XXXX", "to"=>"XXXX@gmail.com", "cc"=>"", "subject"=>"", "body"=>"[FILTERED]", "content_type"=>"text/html", "ticket_id"=>10269, "type_id"=>1, "sender_id"=>1, "internal"=>false, "in_reply_to"=>"<CAPZmVv+EQxe1G5V-GFeNOaxSe_MiOAmF=eqQbH6N6gf4-3-C5Q@mail.gmail.com>", "form_id"=>"080961099", "subtype"=>"reply"}, "updated_at"=>"2021-11-05T02:54:08.688Z", "preferences"=>{"channel_id"=>3}, "pending_time"=>nil, "id"=>"10269", "all"=>"true"}
W, [2021-11-05T02:56:08.571513 #939775-173440] WARN -- : Scoped order is ignored, it's forced to be batch order.
I, [2021-11-05T02:56:09.077887 #939775-173440] INFO -- : Completed 200 OK in 755ms (Views: 3.4ms | ActiveRecord: 423.6ms | Allocations: 190515)
I, [2021-11-05T02:56:09.404254 #939775-179560] INFO -- : Started GET "/api/v1/users/image/3074b1e501fedb1205c322607e753ece" for 71.226.94.214 at 2021-11-05 02:56:09 +0000
I, [2021-11-05T02:56:09.411523 #939775-181260] INFO -- : Started DELETE "/api/v1/upload_caches/080990915" for 71.226.94.214 at 2021-11-05 02:56:09 +0000
I, [2021-11-05T02:56:09.415417 #939775-179560] INFO -- : Processing by UsersController#image as HTML
I, [2021-11-05T02:56:09.415478 #939775-179560] INFO -- : Parameters: {"hash"=>"3074b1e501fedb1205c322607e753ece"}
I, [2021-11-05T02:56:09.417017 #939775-181260] INFO -- : Processing by UploadCachesController#destroy as JSON
I, [2021-11-05T02:56:09.417108 #939775-181260] INFO -- : Parameters: {"id"=>"080990915"}
I, [2021-11-05T02:56:09.431134 #939775-181260] INFO -- : Completed 200 OK in 14ms (Views: 0.1ms | ActiveRecord: 4.4ms | Allocations: 11056)
I, [2021-11-05T02:56:09.433029 #939775-179560] INFO -- : Rendering text template
I, [2021-11-05T02:56:09.433236 #939775-179560] INFO -- : Rendered text template (Duration: 0.0ms | Allocations: 1)
I, [2021-11-05T02:56:09.433336 #939775-179560] INFO -- : Sent data avatar (0.6ms)
I, [2021-11-05T02:56:09.435432 #939775-179560] INFO -- : Completed 200 OK in 20ms (Views: 0.5ms | ActiveRecord: 8.5ms | Allocations: 14213)
I, [2021-11-05T02:56:09.705602 #939775-179480] INFO -- : Started GET "/api/v1/tickets/10269?full=true&_=1636080493461" for 71.226.94.214 at 2021-11-05 02:56:09 +0000
I, [2021-11-05T02:56:09.713988 #939775-179480] INFO -- : Processing by TicketsController#show as JSON
I, [2021-11-05T02:56:09.714035 #939775-179480] INFO -- : Parameters: {"full"=>"true", "_"=>"1636080493461", "id"=>"10269"}
I, [2021-11-05T02:56:09.731473 #939775-179480] INFO -- : Completed 200 OK in 17ms (Views: 1.4ms | ActiveRecord: 3.6ms | Allocations: 16735)
I, [2021-11-05T02:56:09.804928 #939775-179480] INFO -- : Started GET "/api/v1/users/3?full=true&_=1636080493462" for 71.226.94.214 at 2021-11-05 02:56:09 +0000
I, [2021-11-05T02:56:09.810397 #939775-179480] INFO -- : Processing by UsersController#show as JSON
I, [2021-11-05T02:56:09.810456 #939775-179480] INFO -- : Parameters: {"full"=>"true", "_"=>"1636080493462", "id"=>"3"}
I, [2021-11-05T02:56:09.826185 #939775-179480] INFO -- : Completed 200 OK in 16ms (Views: 1.3ms | ActiveRecord: 2.7ms | Allocations: 15477)
I, [2021-11-05T02:56:09.840523 #939775-179640] INFO -- : Started POST "/api/v1/integration/smime" for 71.226.94.214 at 2021-11-05 02:56:09 +0000
I, [2021-11-05T02:56:09.840722 #939750-173440] INFO -- : Started GET "/api/v1/ticket_customer?customer_id=3&_=1636080493463" for 71.226.94.214 at 2021-11-05 02:56:09 +0000
I, [2021-11-05T02:56:09.844862 #939775-179640] INFO -- : Processing by Integration::SMIMEController#search as JSON
I, [2021-11-05T02:56:09.844943 #939775-179640] INFO -- : Parameters: {"ticket"=>{"group_id"=>"1", "owner_id"=>"", "state_id"=>"4", "priority_id"=>"2"}, "article"=>{"body"=>"[FILTERED]", "type"=>"note", "internal"=>true, "form_id"=>"080990915", "subtype"=>"", "in_reply_to"=>"", "to"=>"", "cc"=>"", "subject"=>"", "attachments"=>[]}}
I, [2021-11-05T02:56:09.845143 #939750-173440] INFO -- : Processing by TicketsController#ticket_customer as JSON
I, [2021-11-05T02:56:09.845203 #939750-173440] INFO -- : Parameters: {"customer_id"=>"3", "_"=>"1636080493463"}
I, [2021-11-05T02:56:09.858143 #939775-179640] INFO -- : Completed 200 OK in 13ms (Views: 0.2ms | ActiveRecord: 3.6ms | Allocations: 7735)
I, [2021-11-05T02:56:09.866087 #939762-173440] INFO -- : Started GET "/api/v1/ticket_customer?customer_id=3&_=1636080493464" for 71.226.94.214 at 2021-11-05 02:56:09 +0000
I, [2021-11-05T02:56:09.869118 #939762-173440] INFO -- : Processing by TicketsController#ticket_customer as JSON
I, [2021-11-05T02:56:09.869165 #939762-173440] INFO -- : Parameters: {"customer_id"=>"3", "_"=>"1636080493464"}
I, [2021-11-05T02:56:09.871794 #939750-173440] INFO -- : Completed 200 OK in 27ms (Views: 3.4ms | ActiveRecord: 4.8ms | Allocations: 27744)
I, [2021-11-05T02:56:09.894084 #939762-173440] INFO -- : Completed 200 OK in 25ms (Views: 3.6ms | ActiveRecord: 4.5ms | Allocations: 27740)
I, [2021-11-05T02:56:10.099889 #939762-175480] INFO -- : Started GET "/api/v1/tickets/10269?all=true&_=1636080493465" for 71.226.94.214 at 2021-11-05 02:56:10 +0000
I, [2021-11-05T02:56:10.110697 #939762-175480] INFO -- : Processing by TicketsController#show as JSON
I, [2021-11-05T02:56:10.110742 #939762-175480] INFO -- : Parameters: {"all"=>"true", "_"=>"1636080493465", "id"=>"10269"}
I, [2021-11-05T02:56:10.227848 #939762-175480] INFO -- : Completed 200 OK in 117ms (Views: 7.2ms | ActiveRecord: 9.8ms | Allocations: 86129)
I, [2021-11-05T02:56:10.717167 #939762-175480] INFO -- : Started GET "/api/v1/users/image/3074b1e501fedb1205c322607e753ece" for 71.226.94.214 at 2021-11-05 02:56:10 +0000
I, [2021-11-05T02:56:10.721893 #939762-175480] INFO -- : Processing by UsersController#image as HTML
I, [2021-11-05T02:56:10.721948 #939762-175480] INFO -- : Parameters: {"hash"=>"3074b1e501fedb1205c322607e753ece"}
I, [2021-11-05T02:56:10.733714 #939762-175480] INFO -- : Rendering text template
I, [2021-11-05T02:56:10.733788 #939762-175480] INFO -- : Rendered text template (Duration: 0.0ms | Allocations: 1)
I, [2021-11-05T02:56:10.733867 #939762-175480] INFO -- : Sent data avatar (0.4ms)
I, [2021-11-05T02:56:10.734696 #939762-175480] INFO -- : Completed 200 OK in 13ms (Views: 0.3ms | ActiveRecord: 2.5ms | Allocations: 5578)
I, [2021-11-05T02:56:10.752243 #939651-173940] INFO -- : 2021-11-05T02:56:10+0000: [Worker(host:webhost005.XXXXthink.in pid:939651)] Job TicketArticleCommunicateEmailJob [57b1ca16-6118-4057-9d9d-cb2fd2b1db7b] from DelayedJob(default) with arguments: [33166] (id=971517) (queue=default) RUNNING
I, [2021-11-05T02:56:11.055893 #939762-173980] INFO -- : Started POST "/api/v1/integration/smime" for 71.226.94.214 at 2021-11-05 02:56:11 +0000
I, [2021-11-05T02:56:11.059063 #939762-173980] INFO -- : Processing by Integration::SMIMEController#search as JSON
I, [2021-11-05T02:56:11.059106 #939762-173980] INFO -- : Parameters: {"ticket"=>{"group_id"=>"1", "owner_id"=>"", "state_id"=>"4", "priority_id"=>"2"}, "article"=>{"body"=>"[FILTERED]", "type"=>"note", "internal"=>true, "form_id"=>"080990915", "subtype"=>"", "in_reply_to"=>"", "to"=>"", "cc"=>"", "subject"=>"", "attachments"=>[]}}
I, [2021-11-05T02:56:11.070161 #939762-173980] INFO -- : Completed 200 OK in 11ms (Views: 0.1ms | ActiveRecord: 2.1ms | Allocations: 7736)
I, [2021-11-05T02:56:11.513655 #939651-176660] INFO -- : execute Channel.fetch (try_count 0)...
I, [2021-11-05T02:56:11.515316 #939651-176660] INFO -- : fetching imap (mail.XXXX.net/info@XXXX.net port=993,ssl=true,starttls=false,folder=INBOX,keep_on_server=true,auth_type=LOGIN)
I, [2021-11-05T02:56:11.545626 #939651-176660] INFO -- : - no message
I, [2021-11-05T02:56:11.950438 #939651-176660] INFO -- : ended Channel.fetch took: 0.728739687 seconds.
I, [2021-11-05T02:56:12.044902 #939762-173820] INFO -- : Started GET "/api/v1/ticket_articles/33166?full=true&_=1636080493466" for 71.226.94.214 at 2021-11-05 02:56:12 +0000
I, [2021-11-05T02:56:12.051427 #939762-173820] INFO -- : Processing by TicketArticlesController#show as JSON
I, [2021-11-05T02:56:12.051518 #939762-173820] INFO -- : Parameters: {"full"=>"true", "_"=>"1636080493466", "id"=>"33166"}
I, [2021-11-05T02:56:12.073695 #939762-173820] INFO -- : Completed 200 OK in 22ms (Views: 1.7ms | ActiveRecord: 3.8ms | Allocations: 18782)
I, [2021-11-05T02:56:12.458743 #939651-173940] INFO -- : Send email to: 'XXXX@gmail.com' (from "XXXX XXXX via XXXX.net" <info@XXXX.net>)
I, [2021-11-05T02:56:12.894541 #939651-173940] INFO -- : 2021-11-05T02:56:12+0000: [Worker(host:webhost005.XXXXthink.in pid:939651)] Job TicketArticleCommunicateEmailJob [57b1ca16-6118-4057-9d9d-cb2fd2b1db7b] from DelayedJob(default) with arguments: [33166] (id=971517) (queue=default) COMPLETED after 2.1421
I, [2021-11-05T02:56:12.969984 #939762-174740] INFO -- : Started PUT "/api/v1/taskbar/39015" for 71.226.94.214 at 2021-11-05 02:56:12 +0000
I, [2021-11-05T02:56:12.981239 #939762-174740] INFO -- : Processing by TaskbarController#update as JSON
I, [2021-11-05T02:56:12.981300 #939762-174740] INFO -- : Parameters: {"key"=>"Ticket-10269", "client_id"=>"123", "callback"=>"TicketZoom", "state"=>{"ticket"=>{"state_id"=>"4"}, "article"=>{"form_id"=>"080990915"}}, "params"=>{"ticket_id"=>10269, "overview_id"=>2, "shown"=>true}, "prio"=>4, "notify"=>false, "active"=>true, "attachments"=>[], "updated_at"=>"2021-11-05T02:54:53.556Z", "id"=>"39015"}
I, [2021-11-05T02:56:13.135181 #939651-173940] INFO -- : 2021-11-05T02:56:13+0000: [Worker(host:webhost005.XXXXthink.in pid:939651)] Job TicketUserTicketCounterJob [9bcf44c3-9df7-4b72-aaef-37ef907c14d9] from DelayedJob(default) with arguments: [3, 3] (id=971518) (queue=default) RUNNING
I, [2021-11-05T02:56:13.170256 #939762-174740] INFO -- : Completed 200 OK in 189ms (Views: 0.3ms | ActiveRecord: 171.7ms | Allocations: 14242)
I, [2021-11-05T02:56:13.624061 #939651-173940] INFO -- : 2021-11-05T02:56:13+0000: [Worker(host:webhost005.XXXXthink.in pid:939651)] Job TicketUserTicketCounterJob [9bcf44c3-9df7-4b72-aaef-37ef907c14d9] from DelayedJob(default) with arguments: [3, 3] (id=971518) (queue=default) COMPLETED after 0.4886
I, [2021-11-05T02:56:13.688309 #939651-173940] INFO -- : 2021-11-05T02:56:13+0000: [Worker(host:webhost005.XXXXthink.in pid:939651)] Job TransactionJob [3e48e733-18ed-43da-b02a-adabd2d00f71] from DelayedJob(default) with arguments: [{"object"=>"Ticket", "object_id"=>10269, "user_id"=>3, "created_at"=>{"_aj_serialized"=>"ActiveJob::Serializers::TimeWithZoneSerializer", "value"=>"2021-11-05T02:56:08Z"}, "type"=>"update", "changes"=>{"last_contact_agent_at"=>[{"_aj_serialized"=>"ActiveJob::Serializers::TimeWithZoneSerializer", "value"=>"2021-11-05T02:54:08Z"}, {"_aj_serialized"=>"ActiveJob::Serializers::TimeWithZoneSerializer", "value"=>"2021-11-05T02:56:08Z"}], "last_contact_at"=>[{"_aj_serialized"=>"ActiveJob::Serializers::TimeWithZoneSerializer", "value"=>"2021-11-05T02:54:08Z"}, {"_aj_serialized"=>"ActiveJob::Serializers::TimeWithZoneSerializer", "value"=>"2021-11-05T02:56:08Z"}], "last_owner_update_at"=>[{"_aj_serialized"=>"ActiveJob::Serializers::TimeWithZoneSerializer", "value"=>"2021-11-05T02:54:08Z"}, {"_aj_serialized"=>"ActiveJob::Serializers::TimeWithZoneSerializer", "value"=>"2021-11-05T02:56:08Z"}], "state_id"=>[1, 2], "_aj_symbol_keys"=>[]}, "article_id"=>33166, "_aj_symbol_keys"=>["object", "object_id", "user_id", "created_at", "type", "changes", "article_id"]}, {"interface_handle"=>"application_server", "_aj_symbol_keys"=>["interface_handle"]}] (id=971519) (queue=default) RUNNING
I, [2021-11-05T02:56:13.989035 #939651-173940] INFO -- : 2021-11-05T02:56:13+0000: [Worker(host:webhost005.XXXXthink.in pid:939651)] Job TransactionJob [3e48e733-18ed-43da-b02a-adabd2d00f71] from DelayedJob(default) with arguments: [{"object"=>"Ticket", "object_id"=>10269, "user_id"=>3, "created_at"=>{"_aj_serialized"=>"ActiveJob::Serializers::TimeWithZoneSerializer", "value"=>"2021-11-05T02:56:08Z"}, "type"=>"update", "changes"=>{"last_contact_agent_at"=>[{"_aj_serialized"=>"ActiveJob::Serializers::TimeWithZoneSerializer", "value"=>"2021-11-05T02:54:08Z"}, {"_aj_serialized"=>"ActiveJob::Serializers::TimeWithZoneSerializer", "value"=>"2021-11-05T02:56:08Z"}], "last_contact_at"=>[{"_aj_serialized"=>"ActiveJob::Serializers::TimeWithZoneSerializer", "value"=>"2021-11-05T02:54:08Z"}, {"_aj_serialized"=>"ActiveJob::Serializers::TimeWithZoneSerializer", "value"=>"2021-11-05T02:56:08Z"}], "last_owner_update_at"=>[{"_aj_serialized"=>"ActiveJob::Serializers::TimeWithZoneSerializer", "value"=>"2021-11-05T02:54:08Z"}, {"_aj_serialized"=>"ActiveJob::Serializers::TimeWithZoneSerializer", "value"=>"2021-11-05T02:56:08Z"}], "state_id"=>[1, 2], "_aj_symbol_keys"=>[]}, "article_id"=>33166, "_aj_symbol_keys"=>["object", "object_id", "user_id", "created_at", "type", "changes", "article_id"]}, {"interface_handle"=>"application_server", "_aj_symbol_keys"=>["interface_handle"]}] (id=971519) (queue=default) COMPLETED after 0.3005
I, [2021-11-05T02:56:14.083581 #939651-173940] INFO -- : 2021-11-05T02:56:14+0000: [Worker(host:webhost005.XXXXthink.in pid:939651)] Job SearchIndexAssociationsJob [809f0878-4ce2-4735-934e-b9ca59cc28eb] from DelayedJob(default) with arguments: ["Ticket", 10269] (id=971515) (queue=default) RUNNING
I, [2021-11-05T02:56:14.553631 #939651-173940] INFO -- : 2021-11-05T02:56:14+0000: [Worker(host:webhost005.XXXXthink.in pid:939651)] Job SearchIndexAssociationsJob [809f0878-4ce2-4735-934e-b9ca59cc28eb] from DelayedJob(default) with arguments: ["Ticket", 10269] (id=971515) (queue=default) COMPLETED after 0.4698
I, [2021-11-05T02:56:14.614377 #939651-173940] INFO -- : 2021-11-05T02:56:14+0000: [Worker(host:webhost005.XXXXthink.in pid:939651)] Job SearchIndexJob [da1968c5-fabc-4c93-8d85-3f99dcb35b8f] from DelayedJob(default) with arguments: ["User", 3] (id=971516) (queue=default) RUNNING
I, [2021-11-05T02:56:15.095917 #939651-173940] INFO -- : 2021-11-05T02:56:15+0000: [Worker(host:webhost005.XXXXthink.in pid:939651)] Job SearchIndexJob [da1968c5-fabc-4c93-8d85-3f99dcb35b8f] from DelayedJob(default) with arguments: ["User", 3] (id=971516) (queue=default) COMPLETED after 0.4813
I, [2021-11-05T02:56:36.587368 #939762-173440] INFO -- : Started PUT "/api/v1/taskbar/39015" for 71.226.94.214 at 2021-11-05 02:56:36 +0000
I, [2021-11-05T02:56:36.600469 #939762-173440] INFO -- : Processing by TaskbarController#update as JSON
I, [2021-11-05T02:56:36.600715 #939762-173440] INFO -- : Parameters: {"key"=>"Ticket-10269", "client_id"=>"123", "callback"=>"TicketZoom", "state"=>{"ticket"=>{"state_id"=>"4"}, "article"=>{"form_id"=>"080990915"}}, "params"=>{"ticket_id"=>10269, "overview_id"=>2, "shown"=>true}, "prio"=>4, "notify"=>false, "active"=>false, "attachments"=>[], "updated_at"=>"2021-11-05T02:54:53.556Z", "id"=>"39015"}
I, [2021-11-05T02:56:36.921429 #939762-173440] INFO -- : Completed 200 OK in 320ms (Views: 0.4ms | ActiveRecord: 261.1ms | Allocations: 13574)
I, [2021-11-05T02:56:42.259555 #939651-176660] INFO -- : execute Channel.fetch (try_count 0)...
I, [2021-11-05T02:56:42.263627 #939651-176660] INFO -- : fetching imap (mail.XXXX.net/info@XXXX.net port=993,ssl=true,starttls=false,folder=INBOX,keep_on_server=true,auth_type=LOGIN)
I, [2021-11-05T02:56:42.292448 #939651-176660] INFO -- : - no message
I, [2021-11-05T02:56:42.419229 #939651-176660] INFO -- : ended Channel.fetch took: 0.466449869 seconds.
I, [2021-11-05T02:56:42.503296 #939651-5220] INFO -- : Scheduler running...
I, [2021-11-05T02:56:42.508154 #939651-5220] INFO -- : Running job thread for 'Process escalation tickets' (Ticket.process_escalation) status is: sleep
I, [2021-11-05T02:56:42.508444 #939651-5220] INFO -- : Running job thread for 'Check Channels' (Channel.fetch) status is: sleep
I, [2021-11-05T02:56:42.508569 #939651-5220] INFO -- : Running job thread for 'Check streams for Channel' (Channel.stream) status is: sleep
I, [2021-11-05T02:56:42.508676 #939651-5220] INFO -- : Running job thread for 'Generate Session data' (Sessions.jobs) status is: sleep
I, [2021-11-05T02:56:42.510091 #939651-5220] INFO -- : Running job thread for 'Execute jobs' (Job.run) status is: sleep
I, [2021-11-05T02:57:02.021922 #939762-175480] INFO -- : Started PUT "/api/v1/taskbar/39015" for 71.226.94.214 at 2021-11-05 02:57:02 +0000
I, [2021-11-05T02:57:02.032278 #939762-175480] INFO -- : Processing by TaskbarController#update as JSON
I’ve also noticed the state “new” is missing from the dropdown once the ticket has been updated as well. Is this normal as I do not recall it happening pre v.5.0 and am able to see it in the dropdown of a 4.x server. One more oddity, if I have a macro try to change the ticket state to new, I get an error “invalid value ‘1’ for field ‘state_id’!”
