Used Zammad version: 4.1
Used Zammad installation type: (source, package, docker-compose, …)
Source -
Operating system:
Ubuntu 20.04 -
Browser + version: Chrome
When using zammad reply send response to Sender not recipient
When an Agent of another Department emails Zammad departments it looks fine
But if i use reply its not going to that sender but back to itself
But Should be back to Veronica the sender
this is a fresh install of Zammad so im guess there is some config issue in email set up,
but compared to the old system i have it the same, old system works new system as above ?
