Ticket Full Quote Reply per Group
  • Used Zammad version:
  • Used Zammad installation source: (source, package, …)
  • Operating system:
  • Browser + version:
I would like to set the reply-behavior per group insead of globally for my user.
I have two groups. One of them should have the full history-quote in the replies. The other only the ticket-answer-message.
Only settable globally for my user.
This is a global option, sorry.
A per group basis would add a lot more complexity - not just in configuration terms.
We tend to try to keep Zammad as simple and slick as possible.
If this is a feature request, you may want to change the category to feature request instead.
Thank you for your reply. Thought I might have missed something.
Guess, it is one. Since this feature doesn’t exist. Though it might not be a good one, given you said it would complicate a lot of things.
I’m sorry, but how would I do so? Can’t find that function.
Just updated the category for you. :raised_hands:
