Telegram Channel Error: The webhook could not be saved by Telegram, seems to be an invalid URL
  • Used Zammad version: 5.2.x
  • Browser + version: Brave 1.39.11
  • Telegram Bot to be added successfully
  • Error “The webhook could not be saved by Telegram, seems to be an invalid URL.” is shown and the bot is not added
  • am using https as the http_type and have a proper fqdn for the site
  • the site is also externally accessbile
  • Add telegram bot using the standard procedure
Thank you,.
I tried running this over Postman:
https://api.telegram.org/bot<Redacted BOT ID>/setWebhook?url=https://<Redacted URL>/api/v1/channels_telegram_webhook/<Redacted random 10 digit number>?bid=<Redacted BOT ID>
And it registered the webhook in Telegram but this obviously does not register the bot in Zammad so it doesn’t completely work. This gave me confidence that the instance URL / FQDN was good so am not sure where its going wrong.
I found out that the channels_telegram_webhook seems to be treated as some markup and it is translated to channels<u>telegram</u>webhook. Searching through the forum I found this Is the markup interpretation in overview names intentional?
But could not find how to avoid the markup. Does anyone know?
I have the same issue.
I got around this problem by changing the version to 5.1.1 . Zammad added bots .
I couldn’t find a way to escape the pair of underscores and resorted to a hack for now
I edited /opt/zammad/lib/telegram.rb
Replaced:
callback_url = "#{Setting.get('http_type')}://#{Setting.get('fqdn')}/api/v1/channels_telegram_webhook/#{callback_token}?bid=#{bot['id']}"
with
callback_url = "#{Setting.get('http_type')}://#{Setting.get('fqdn')}/api/v1/channels%5ftelegram%5fwebhook/#{callback_token}?bid=#{bot['id']}"
then edited /opt/zammad/vendor/bundle/ruby/3.0.0/bundler/gems/telegramAPI-fb62dd5b48b0/libvi telegramAPI.rb and replaced:
def setWebhook url
    self.query("setWebhook", {"url"=>URI::encode(url)})
end
with:
def setWebhook url
    self.query("setWebhook", {"url"=>url.gsub("%5f", "_")})
end
Restarted the Zammad service and I could successfully register the Telegram bot.
I’m sure there is a way to escape it but I cannot for the life of me find the place where it is marking up the strings. Hoping someone will point me to the place, more than happy to push a contribution once I get this info.
did everything, but the error remains
Hi.
The reason I think is that:
didn’t work either =(
didn’t work for me too :frowning:
Did you restart the zammad service after editing the 2 files?
Hi @javierwonghf ,
The file /opt/zammad/vendor/bundle/ruby/3.0.0/bundler/gems/telegramAPI-fb62dd5b48b0/libvi telegramAPI.rb was slightly different in my instance (5.2.1)
In the original file I had
self.query("setWebhook", {"url"=>URI::encode_www_form([url])})
and not
I did the replacement with
def setWebhook url
end
Then a zammad restart and now it works! thank you.
