Dear Zammad Team,
I found the same request at
which is unfortunately closed… but I’d like to provide some further implementation idea to make the Organization administration much more convenient.
Title: Search field in “Organization Administration”
If you have many organisations in a setup it’s hard to find it within the Administration section. You have to click through the different pages, as there is no search field.
- Which are one or two concrete situations where this problem hurts the most?
When ever you have to touch/change an Organization in the system.
- Why is it not solvable with the Zammad standard?
Because it misses the search field, like there is in “User Administration”.
- What is your expectation/what do you want to achieve?
Quick access to an Organization.
A further nice feature would be, to implement a link to a user’s Organization, once you are hovering over and click the Organization element within the result list of the “User Administration” module.
Cheers, Schweigi
