Hi Zammad Community
Trying to migrate from an old OTRS to Zammad using the Zammad - rails console.
I am already grateful for any help or advice from the community to successfully complete the migration.
- Used Zammad version: 5.1.1
- Used OTRS version: 5.0.26
- installed OTRS packages: FAQ, TimeAccounting
- Used Zammad installation type: package (zammad_5.1.1-1651218076.e3861908.bullseye_amd64.deb)
- Operating system: Debian 11.3.0
- Browser + version: / via Zammad - rails console
- That the OTRS migration will be completed successfully
- After starting the migration the following error message is thrown after a short time:
ActiveRecord::RecordInvalid (Validation failed: Data option must have integer for :maxlength)
The full zammad cli log (FQDN, Key and organization were replaced):
root@Hostname:# systemctl stop zammad
root@Hostname:# zammad run rails c
Loading production environment (Rails 6.0.4.8)
irb(main):001:0>
irb(main):002:0> Delayed::Worker.max_run_time = 7.days
=> 7 days
irb(main):003:0> Setting.set('import_otrs_endpoint', 'https://internFQDN/otrs/public.pl?Action=ZammadMigrator')
Setting.reset_change_id: set new cache, baf53d76-569b-4c05-9a00-c9b517f79f0d
Setting.set('import_otrs_endpoint', "https://internFQDN/otrs/public.pl?Action=ZammadMigrator")
=> true
irb(main):004:0> Setting.set('import_otrs_endpoint_key', 'KEY')
Setting.reset_change_id: set new cache, 42498711-e6a4-4f40-9a60-8be0c647c676
Setting.set('import_otrs_endpoint_key', "KEY")
=> true
irb(main):005:0> Setting.set('import_mode', true)
Setting.reset_change_id: set new cache, e749bdd5-ef1a-4777-b9b1-35fc4023719e
=> true
irb(main):006:0> Import::OTRS.start
thread#-: Start import...
thread#-: POST: https://internFQDN/otrs/public.pl?Action=ZammadMigrator
thread#-: PARAMS: {:Action=>"ZammadMigrator", :Key=>"KEY"}
thread#-: loading SysConfig...
thread#-: PARAMS: {:Subaction=>"Export", :Object=>"SysConfig", :Limit=>"", :Offset=>"", :Diff=>0, :Action=>"ZammadMigrator", :Key=>"KEY"}
Setting.reset_change_id: set new cache, e8f03c1c-4b3a-4380-ba07-0190fa1ab064
Setting.set('http_type', "https")
Setting.reset_change_id: set new cache, 91051987-75a8-44c7-a3c3-e662f6f6e985
Setting.set('organization', "company Name")
Setting.reset_change_id: set new cache, 300557a9-c641-4f41-992c-284222b6e6d4
Setting.set('system_id', "35")
Setting.reset_change_id: set new cache, 96e3f931-7d84-451e-abbd-f42f89405dd3
Setting.set('ticket_hook', "Ticket#")
Setting.reset_change_id: set new cache, 83549fa7-f2d5-4670-b391-01170e4c1757
Setting.set('ticket_number', "Ticket::Number::Date")
Setting.reset_change_id: set new cache, 77923c9b-3be8-4bda-959f-e94eb17516ad
Setting.set('ticket_number_date', {:checksum=>true})
thread#-: loading DynamicField...
thread#-: PARAMS: {:Subaction=>"Export", :Object=>"DynamicField", :Limit=>"", :Offset=>"", :Diff=>0, :Action=>"ZammadMigrator", :Key=>"KEY"}
-- add_column("tickets", "pre_proc_application_recorded", :string, {:limit=>255, :null=>true})
-> 0.0684s
-- add_column("tickets", "pre_proc_days_remaining", :string, {:limit=>255, :null=>true})
-> 0.0028s
-- add_column("tickets", "pre_proc_vacation_start", :date, {:default=>nil, :null=>true})
-> 0.0023s
-- add_column("tickets", "pre_proc_vacation_end", :date, {:default=>nil, :null=>true})
-> 0.0021s
-- add_column("tickets", "pre_proc_days_used", :string, {:limit=>255, :null=>true})
-> 0.0017s
-- add_column("tickets", "pre_proc_emergency_telephone", :string, {:limit=>255, :null=>true})
-> 0.0016s
14: from (irb):6
13: from lib/import/otrs.rb:26:in `start'
12: from lib/import/otrs.rb:144:in `base_objects'
11: from lib/import/otrs.rb:58:in `import'
10: from lib/import/otrs.rb:134:in `import_action'
9: from lib/import/base_factory.rb:9:in `import_action'
8: from lib/import/base_factory.rb:40:in `import_loop'
7: from lib/import/base_factory.rb:40:in `each'
6: from lib/import/base_factory.rb:12:in `block in import_action'
5: from lib/import/base_factory.rb:36:in `create_instance'
4: from lib/import/base_factory.rb:36:in `new'
3: from lib/import/otrs/dynamic_field.rb:15:in `initialize'
2: from lib/import/otrs/dynamic_field.rb:58:in `add'
1: from app/models/object_manager/attribute.rb:395:in `add'
irb(main):007:0>
irb(main):008:0>
After cross-reading the community topics is it possible, that custom dynamic fields in the OTRS instance could be causing this issue?
If needed i have extracted the following (log-)files, before restoring the original system states
Zammad
- production.log
OTRS
- mariadb.log
- Apache error_log, access_log, ssl_*_log
HTTP POST - https://internFQDN/otrs/public.pl?Action=ZammadMigrator&Subaction=Export&Key=KEY&Object=DynamicField&Diff=0&Limit=&Offset=
- public.pl.json
Unfortunately, I have no experience as far as Zammad is concerned and my knowledge of the OTRS instance at hand is also limited. Therefore i am grateful for any help and advice.
