thanks for helping me out on this one.
I changed the name of the tld, no worries there.
I, [2018-03-11T15:50:37.882967 #1196] INFO – : Scheduler running…
I, [2018-03-11T15:50:37.891380 #1196] INFO – : Running job thread for ‘Process escalation tickets’ (Ticket.process_escalation) status is: sleep
I, [2018-03-11T15:50:37.891516 #1196] INFO – : Running job thread for ‘Import OTRS diff load’ (Import::OTRS.diff_worker) status is: sleep
I, [2018-03-11T15:50:37.891566 #1196] INFO – : Running job thread for ‘Check streams for Channel’ (Channel.stream) status is: sleep
I, [2018-03-11T15:50:37.891608 #1196] INFO – : Running job thread for ‘Generate Session data’ (Sessions.jobs) status is: sleep
I, [2018-03-11T15:50:37.891648 #1196] INFO – : Running job thread for ‘Check Channels’ (Channel.fetch) status is: sleep
I, [2018-03-11T15:50:37.892020 #1196] INFO – : Started job thread for ‘Process auto unassign tickets’ (Ticket.process_auto_unassign)…
I, [2018-03-11T15:50:37.897993 #1196] INFO – : execute Ticket.process_auto_unassign (try_count 0)…
I, [2018-03-11T15:50:37.905804 #1196] INFO – : …stopped thread for ‘Ticket.process_auto_unassign’
I, [2018-03-11T15:50:38.757320 #1196] INFO – : execute Channel.fetch (try_count 0)…
I, [2018-03-11T15:50:47.893178 #1196] INFO – : Started job thread for ‘Import Jobs’ (ImportJob.start_registered)…
I, [2018-03-11T15:50:47.903587 #1196] INFO – : execute ImportJob.start_registered (try_count 0)…
I, [2018-03-11T15:50:47.910524 #1196] INFO – : …stopped thread for ‘ImportJob.start_registered’
I, [2018-03-11T15:50:57.893723 #1196] INFO – : Started job thread for ‘Process pending tickets’ (Ticket.process_pending)…
I, [2018-03-11T15:50:57.903517 #1196] INFO – : execute Ticket.process_pending (try_count 0)…
I, [2018-03-11T15:50:57.917923 #1196] INFO – : …stopped thread for ‘Ticket.process_pending’
I, [2018-03-11T15:51:05.609580 #1196] INFO – : Started job thread for ‘Delete old online notification entries.’ (OnlineNotification.cleanup)…
I, [2018-03-11T15:51:05.616766 #1196] INFO – : execute OnlineNotification.cleanup (try_count 0)…
I, [2018-03-11T15:51:05.625688 #1196] INFO – : …stopped thread for ‘OnlineNotification.cleanup’
I, [2018-03-11T15:51:06.485087 #1196] INFO – : execute Channel.fetch (try_count 0)…
I, [2018-03-11T15:51:15.610513 #1196] INFO – : Started job thread for ‘Generate user based stats.’ (Stats.generate)…
I, [2018-03-11T15:51:15.620324 #1196] INFO – : execute Stats.generate (try_count 0)…
I, [2018-03-11T15:51:15.630439 #1196] INFO – : …stopped thread for ‘Stats.generate’
I, [2018-03-11T15:51:25.610878 #1196] INFO – : Running job thread for ‘Execute jobs’ (Job.run) status is: sleep
I, [2018-03-11T15:51:25.611743 #1196] INFO – : Started job thread for ‘Cleanup expired sessions’ (SessionHelper.cleanup_expired)…
I, [2018-03-11T15:51:25.621065 #1196] INFO – : execute SessionHelper.cleanup_expired (try_count 0)…
I, [2018-03-11T15:51:25.630025 #1196] INFO – : …stopped thread for ‘SessionHelper.cleanup_expired’
I, [2018-03-11T15:51:35.612802 #1196] INFO – : Started job thread for ‘Closed chat sessions where participients are offline.’ (Chat.cleanup_close)…
I, [2018-03-11T15:51:35.621906 #1196] INFO – : execute Chat.cleanup_close (try_count 0)…
I, [2018-03-11T15:51:35.627137 #1196] INFO – : …stopped thread for ‘Chat.cleanup_close’
I, [2018-03-11T15:51:36.497174 #1196] INFO – : execute Channel.fetch (try_count 0)…
I, [2018-03-11T15:51:55.193995 #1196] INFO – : execute Job.run (try_count 0)…
I, [2018-03-11T15:52:06.510109 #1196] INFO – : execute Channel.fetch (try_count 0)…
I, [2018-03-11T15:52:36.522244 #1196] INFO – : execute Channel.fetch (try_count 0)…
I, [2018-03-11T15:52:37.249305 #1192] INFO – : Started GET “/” for 127.0.0.1 at 2018-03-11 15:52:37 +0100
I, [2018-03-11T15:52:37.271045 #1192] INFO – : Processing by InitController#index as HTML
I, [2018-03-11T15:52:37.365680 #1192] INFO – : Rendering init/index.html.erb within layouts/application
I, [2018-03-11T15:52:37.367229 #1192] INFO – : Rendered init/index.html.erb within layouts/application (1.3ms)
I, [2018-03-11T15:52:37.373706 #1192] INFO – : Completed 200 OK in 102ms (Views: 9.1ms | ActiveRecord: 86.0ms)
I, [2018-03-11T15:52:37.877562 #1192] INFO – : Started POST “/api/v1/signshow” for 127.0.0.1 at 2018-03-11 15:52:37 +0100
I, [2018-03-11T15:52:37.886941 #1192] INFO – : Processing by SessionsController#show as JSON
I, [2018-03-11T15:52:37.887074 #1192] INFO – : Parameters: {“fingerprint”=>"-1140119626"}
I, [2018-03-11T15:52:37.950694 #1192] INFO – : Completed 200 OK in 63ms (Views: 16.0ms | ActiveRecord: 5.9ms)
I, [2018-03-11T15:52:37.966762 #1192] INFO – : Started GET “/api/v1/translations/lang/de-de?=1520779960234" for 127.0.0.1 at 2018-03-11 15:52:37 +0100
I, [2018-03-11T15:52:37.979842 #1192] INFO – : Processing by TranslationsController#lang as JSON
I, [2018-03-11T15:52:37.979923 #1192] INFO – : Parameters: {"”=>“1520779960234”, “locale”=>“de-de”}
I, [2018-03-11T15:52:38.216791 #1192] INFO – : Completed 200 OK in 237ms (Views: 16.7ms | ActiveRecord: 28.1ms)
I, [2018-03-11T15:52:38.288757 #1192] INFO – : Started GET “/api/v1/getting_started?=1520779960235" for 127.0.0.1 at 2018-03-11 15:52:38 +0100
I, [2018-03-11T15:52:38.294434 #1192] INFO – : Processing by GettingStartedController#index as JSON
I, [2018-03-11T15:52:38.294517 #1192] INFO – : Parameters: {"”=>“1520779960235”}
I, [2018-03-11T15:52:38.298480 #1192] INFO – : Completed 200 OK in 4ms (Views: 0.2ms | ActiveRecord: 1.2ms)
I, [2018-03-11T15:52:39.715615 #1192] INFO – : Started GET “/api/v1/getting_started?=1520779960236" for 127.0.0.1 at 2018-03-11 15:52:39 +0100
I, [2018-03-11T15:52:39.719515 #1192] INFO – : Processing by GettingStartedController#index as JSON
I, [2018-03-11T15:52:39.719565 #1192] INFO – : Parameters: {"”=>“1520779960236”}
I, [2018-03-11T15:52:39.721964 #1192] INFO – : Completed 200 OK in 2ms (Views: 0.1ms | ActiveRecord: 0.6ms)
I, [2018-03-11T15:52:45.613954 #1196] INFO – : Scheduler running…
I, [2018-03-11T15:52:45.621620 #1196] INFO – : Running job thread for ‘Check Channels’ (Channel.fetch) status is: sleep
I, [2018-03-11T15:52:45.621733 #1196] INFO – : Running job thread for ‘Process escalation tickets’ (Ticket.process_escalation) status is: sleep
I, [2018-03-11T15:52:45.621809 #1196] INFO – : Running job thread for ‘Import OTRS diff load’ (Import::OTRS.diff_worker) status is: sleep
I, [2018-03-11T15:52:45.621951 #1196] INFO – : Running job thread for ‘Check streams for Channel’ (Channel.stream) status is: sleep
I, [2018-03-11T15:52:45.622024 #1196] INFO – : Running job thread for ‘Generate Session data’ (Sessions.jobs) status is: sleep
I, [2018-03-11T15:52:45.623479 #1196] INFO – : Running job thread for ‘Execute jobs’ (Job.run) status is: sleep
I, [2018-03-11T15:53:05.015789 #1196] INFO – : execute Import::OTRS.diff_worker (try_count 0)…
I, [2018-03-11T15:53:06.533978 #1196] INFO – : execute Channel.fetch (try_count 0)…
I, [2018-03-11T15:53:36.545852 #1196] INFO – : execute Channel.fetch (try_count 0)…
I, [2018-03-11T15:53:45.624916 #1196] INFO – : Scheduler running…
I, [2018-03-11T15:53:45.632932 #1196] INFO – : Running job thread for ‘Import OTRS diff load’ (Import::OTRS.diff_worker) status is: sleep
I, [2018-03-11T15:53:45.633051 #1196] INFO – : Running job thread for ‘Process escalation tickets’ (Ticket.process_escalation) status is: sleep
I, [2018-03-11T15:53:45.633119 #1196] INFO – : Running job thread for ‘Check Channels’ (Channel.fetch) status is: sleep
I, [2018-03-11T15:53:45.633182 #1196] INFO – : Running job thread for ‘Check streams for Channel’ (Channel.stream) status is: sleep
I, [2018-03-11T15:53:45.633252 #1196] INFO – : Running job thread for ‘Generate Session data’ (Sessions.jobs) status is: sleep
I, [2018-03-11T15:53:45.635346 #1196] INFO – : Running job thread for ‘Execute jobs’ (Job.run) status is: sleep
I, [2018-03-11T15:54:05.269858 #1196] INFO – : execute Ticket.process_escalation (try_count 0)…
I, [2018-03-11T15:54:06.557690 #1196] INFO – : execute Channel.fetch (try_count 0)…
I, [2018-03-11T15:54:36.567371 #1196] INFO – : execute Channel.fetch (try_count 0)…
I, [2018-03-11T15:54:45.635989 #1196] INFO – : Scheduler running…
I, [2018-03-11T15:54:45.644738 #1196] INFO – : Running job thread for ‘Import OTRS diff load’ (Import::OTRS.diff_worker) status is: sleep
I, [2018-03-11T15:54:45.644887 #1196] INFO – : Running job thread for ‘Process escalation tickets’ (Ticket.process_escalation) status is: sleep
I, [2018-03-11T15:54:45.644967 #1196] INFO – : Running job thread for ‘Check streams for Channel’ (Channel.stream) status is: sleep
I, [2018-03-11T15:54:45.645033 #1196] INFO – : Running job thread for ‘Generate Session data’ (Sessions.jobs) status is: sleep
I, [2018-03-11T15:54:45.645096 #1196] INFO – : Running job thread for ‘Check Channels’ (Channel.fetch) status is: sleep
I, [2018-03-11T15:54:45.646509 #1196] INFO – : Running job thread for ‘Execute jobs’ (Job.run) status is: sleep
I, [2018-03-11T15:54:46.390458 #1192] INFO – : Started GET “/api/v1/getting_started?=1520779960237" for 127.0.0.1 at 2018-03-11 15:54:46 +0100
I, [2018-03-11T15:54:46.394819 #1192] INFO – : Processing by GettingStartedController#index as JSON
I, [2018-03-11T15:54:46.394881 #1192] INFO – : Parameters: {"”=>“1520779960237”}
I, [2018-03-11T15:54:46.397397 #1192] INFO – : Completed 200 OK in 2ms (Views: 0.1ms | ActiveRecord: 0.5ms)
I, [2018-03-11T15:54:51.595689 #1192] INFO – : Started POST “/api/v1/import/otrs/url_check” for 127.0.0.1 at 2018-03-11 15:54:51 +0100
I, [2018-03-11T15:54:51.601662 #1192] INFO – : Processing by ImportOtrsController#url_check as JSON
I, [2018-03-11T15:54:51.601777 #1192] INFO – : Parameters: {“url”=>“http://support.sometld.at/otrs/public.pl?Action=ZammadMigrator;Key=kScyukFV9zQXNwt0qdT3dtG7Uj5c3fJROANNdpnC7jaFJp1A1f7hbVbRupnMlA7”}
I, [2018-03-11T15:54:51.943991 #1192] INFO – : Setting.set(‘import_backend’, “otrs”)
I, [2018-03-11T15:54:51.951043 #1192] INFO – : Setting.set(‘import_otrs_endpoint’, “http://support.sometld.at/otrs/public.pl?Action=ZammadMigrator”)
I, [2018-03-11T15:54:51.961684 #1192] INFO – : Setting.set(‘import_otrs_endpoint_key’, “kScyukFV9zQXNwt0qdT3dtG7Uj5c3fJROANNdpnC7jaFJp1A1f7hbVbRupnMlA7”)
I, [2018-03-11T15:54:51.966856 #1192] INFO – : Completed 200 OK in 365ms (Views: 0.3ms | ActiveRecord: 4.9ms)
I, [2018-03-11T15:54:52.632244 #1192] INFO – : Started POST “/api/v1/import/otrs/import_check” for 127.0.0.1 at 2018-03-11 15:54:52 +0100
I, [2018-03-11T15:54:52.636263 #1192] INFO – : Processing by ImportOtrsController#import_check as JSON
I, [2018-03-11T15:54:52.636667 #1192] INFO – : thread#-: POST: http://support.sometld.at/otrs/public.pl?Action=ZammadMigrator
I, [2018-03-11T15:54:52.636704 #1192] INFO – : thread#-: PARAMS: {:Subaction=>“List”, :Action=>“ZammadMigrator”, :Key=>“kScyukFV9zQXNwt0qdT3dtG7Uj5c3fJROANNdpnC7jaFJp1A1f7hbVbRupnMlA7”}
I, [2018-03-11T15:54:52.972905 #1192] INFO – : thread#-: POST: http://support.sometld.at/otrs/public.pl?Action=ZammadMigrator
I, [2018-03-11T15:54:52.972998 #1192] INFO – : thread#-: PARAMS: {:Subaction=>“Export”, :Object=>“DynamicField”, :Limit=>"", :Offset=>"", :Diff=>0, :Action=>“ZammadMigrator”, :Key=>“kScyukFV9zQXNwt0qdT3dtG7Uj5c3fJROANNdpnC7jaFJp1A1f7hbVbRupnMlA7”}
E, [2018-03-11T15:54:53.259271 #1192] ERROR – : undefined method each' for nil:NilClass (NoMethodError) /opt/zammad/app/controllers/import_otrs_controller.rb:131:in
import_check’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/basic_implicit_render.rb:4:in send_action' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/base.rb:186:in
process_action’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/rendering.rb:30:in process_action' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/callbacks.rb:20:in
block in process_action’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:131:in run_callbacks' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/callbacks.rb:19:in
process_action’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/rescue.rb:20:in process_action' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:32:in
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications.rb:166:in block in instrument' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications/instrumenter.rb:21:in
instrument’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications.rb:166:in instrument' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:30:in
process_action’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/params_wrapper.rb:252:in process_action' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/railties/controller_runtime.rb:22:in
process_action’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/base.rb:124:in process' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionview-5.1.4/lib/action_view/rendering.rb:30:in
process’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal.rb:189:in dispatch' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal.rb:253:in
dispatch’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:49:in dispatch' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:31:in
serve’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:50:in block in serve' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:33:in
each’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:33:in serve' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:834:in
call’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/omniauth-1.7.1/lib/omniauth/strategy.rb:190:in call!' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/omniauth-1.7.1/lib/omniauth/strategy.rb:168:in
call’
call’
call’
call’
call’
call’
call’
call’
call’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/omniauth-1.7.1/lib/omniauth/builder.rb:63:in call' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/etag.rb:25:in
call’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/conditional_get.rb:38:in call' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/head.rb:12:in
call’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/session/abstract/id.rb:232:in context' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/session/abstract/id.rb:226:in
call’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/cookies.rb:613:in call' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/callbacks.rb:26:in
block in call’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:97:in run_callbacks' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/callbacks.rb:24:in
call’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/debug_exceptions.rb:59:in call' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/show_exceptions.rb:31:in
call’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/rack/logger.rb:36:in call_app' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/rack/logger.rb:24:in
block in call’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/tagged_logging.rb:69:in block in tagged' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/tagged_logging.rb:26:in
tagged’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/tagged_logging.rb:69:in tagged' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/rack/logger.rb:24:in
call’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/remote_ip.rb:79:in call' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/request_id.rb:25:in
call’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/method_override.rb:22:in call' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/runtime.rb:22:in
call’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/cache/strategy/local_cache_middleware.rb:27:in call' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/executor.rb:12:in
call’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/static.rb:125:in call' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/sendfile.rb:111:in
call’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/engine.rb:522:in call' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/puma-3.11.0/lib/puma/configuration.rb:225:in
call’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/puma-3.11.0/lib/puma/server.rb:624:in handle_request' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/puma-3.11.0/lib/puma/server.rb:438:in
process_client’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/puma-3.11.0/lib/puma/server.rb:302:in block in run' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/puma-3.11.0/lib/puma/thread_pool.rb:120:in
block in spawn_thread’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context’
I, [2018-03-11T15:54:53.261197 #1192] INFO – : Completed 500 Internal Server Error in 625ms (Views: 0.2ms | ActiveRecord: 0.0ms)
I, [2018-03-11T15:55:06.580233 #1196] INFO – : execute Channel.fetch (try_count 0)…
