Title: Merge ticket keyboard shortcut
What is your original issue/pain point you want to solve? having to use the mouse to click the ticket options, then merge to paste in the ticket id and click submit
Which are one or two concrete situations where this problem hurts the most? Merging heaps of tickets opened by automated systems in rapid succession
Why is it not solvable with the Zammad standard? It requires moving the mouse alot. if you have 50 tickets to merge, its a lot of mouse moving, which is not as easy as keyboard shortcuts, which can then be converted to a macro using inbuilt OS tooling to automate the process. (getting it close to a bulk merge functionality)
What is your expectation/what do you want to achieve? Press a keyboard combination and it opens the merge ticket dialog, where i can paste the ticket ID and press enter. Then using inbuilt OS tools, i can convert this into a single key press macro.
Cheers all.
Jason
