Trenga
April 24, 2018, 1:19pm
1
Used Zammad version: 2.4.x
Used Zammad installation source: (source, package, …)deb
Operating system: Debian 8.8
Browser + version: Actually Firefox
User login via URL like:
http://my_user:my_password@my_zammad/#ticket /view/my_view
User can login via URL but the browser shows no item (no Dashboard etc.)
Hi
I like to access a view on my Zammad server.
I tried different user and groups.
But if I open the URl, Firefox shows a blank Zammad frontend.
I’m not sure it will be work?
HTTP basic authentication Is that possible?
Thanks
Hi @Trenga - It is! We actually use it on most of our controller tests. All you need to do is to make sure the Basic HTTP Authorization header is set properly: https://tools.ietf.org/html/rfc7617#section-2
Trenga
April 26, 2018, 9:04am
3
Hi @anon29869905
Thanks for the fast help.
OK then I think I have another problem.
If I login with my URL I see this.
Are there any entries in your browser console? If you login with the same account via the regular login flow the result differs?
Trenga
April 26, 2018, 9:40am
5
Hi
With the regular Iogin I get the normal zammad frontend.
Max
April 26, 2018, 12:09pm
6
Can you post your Login URL Example ?
Trenga
April 26, 2018, 1:39pm
7
Hi Max
Like this:
http://YXV0by0xNTI0NTU1MjgxLTU4MDg4NTp6YWJiaXg=@dv-ticketcenter/#ticket/view/offen
or
http://auto-1524555281-580885 :$apr1$fTmqRh0F$Uh4V0KxiP.qH61o.R1Sy50
@dv-ticketcenter /#ticket /view/offen
or
http://auto-1524555281-580885:zabbix@dv-ticketcenter/#ticket/view/offen
Same user and password.
Do I need a specially setup on my nginx server like a .htpasswd file???
Max
April 26, 2018, 5:30pm
8
Trenga i dont understand your example for example my Usernam are teo@lula.com my Password helloworld and my zammad login site are login.ghueheiw.com how the use can now login to the Frontend from zammad with http ?
Trenga
April 27, 2018, 6:45am
9
Hi @Max
Then I would be try:
http://teo@lula.com :helloworld@login.ghueheiw.com2
or
http://dGVvQGx1bGEuY29tOmhlbGxvd29ybGQ=@login.ghueheiw.com2 (created with a Basic Authentication Header Generator)
Trenga
April 27, 2018, 6:58am
10
Good morning @anon29869905
Do we need a specially setup in the:
/etc/nginx/sites-available/zammad.conf
Thanks in advance. Have a nice long weekend.
Max
April 27, 2018, 8:01am
11
If i search in the URL Bar from Firefox at http://teo@lula.com :helloworld@login.ghueheiw.com nothing happen. it only say that login.ghueheiw.com dont need login name and password. Should i activate in Zammad anything i only see http basic authentication with curl ?
Trenga
April 27, 2018, 8:15am
12
That is also my question in our cummunity
Trenga
April 27, 2018, 8:25am
13
Hi @Max
Could you post a snap-shoot of your login page?
Max
April 27, 2018, 11:03am
14
The Standard Zammad Login Page :
I thing nobody can help us We need only a Link or an html / php code that allow to Login over extern login form to zammad i don’t want to login over the original zammad login form
Trenga
April 27, 2018, 12:03pm
15
Hi again
If I try
@dv-ticketcenter /#dashboard
Then I get a small windows like this:
Max
April 27, 2018, 1:55pm
17
@Trenga i have the same problem too.
system
Closed
June 26, 2018, 1:55pm
18
