How to install a specific version of Zammad using package managers
Hi.
Is it possible to install a specific version of Zammad using package managers (like apt)?
Thank you
This might be helpful:
You can use this to follow the upgrade path to upgrade your Zammad installation.
Since you’re using apt you’re probably also using the packaged version via packager.io.
Example using debian 11 as OS:
To install the latest stable you should have a list containing this repo:
deb https://dl.packager.io/srv/deb/zammad/zammad/stable/debian 11 main
To specifically install 5.1 instead your list would look like this:
deb https://dl.packager.io/srv/deb/zammad/zammad/stable-5.1/debian 11 main
You can see all available repos including their supported distros here:
There’s a dropdown on top.
Please follow the official documentation to add the repo etc. The example given should help you with specifying the version though.
cheers
p.s.: @Stubenhocker is still correct for specific version inside a given repo. I just added my answer in case you’re talking about “big” version jumps not builds inside a minor release.
