Rocky
June 8, 2019, 1:28pm
1
I’m following these instructions to install Zammad on Ubuntu 18.04:
https://docs.zammad.org/en/latest/install-source.html#install-from-source-debian-7-8-ubuntu-16-04-ubuntu-18-04
But there is nothing in there to tell me how to customize database IP address, how do I change the database IP address? I have a dedicated MySQL server and don’t want to run it on localhost.
Thanks.
Rocky
June 8, 2019, 2:07pm
2
I got the database working and rake db:migrate worked fine but rake db:seed doesn’t work.
zammad@zammad:~$ rake db:seed
rake aborted!
ActiveRecord::StatementInvalid: Mysql2::Error: Incorrect string value: '\xD0\x91\xD1\x8A\xD0\xBB...' for column 'name' at row 1: INSERT INTO `locales` (`locale`, `alias`, `name`, `created_at`, `updated_at`) VALUES ('bg', '', 'Bulgarian (Български)', '2019-06-08 14:01:58.807000', '2019-06-08 14:01:58.807000')
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/mysql2-0.4.10/lib/mysql2/client.rb:120:in `_query'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/mysql2-0.4.10/lib/mysql2/client.rb:120:in `block in query'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/mysql2-0.4.10/lib/mysql2/client.rb:119:in `handle_interrupt'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/mysql2-0.4.10/lib/mysql2/client.rb:119:in `query'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/connection_adapters/abstract_mysql_adapter.rb:214:in `block (2 levels) in execute'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activesupport-5.1.7/lib/active_support/dependencies/interlock.rb:46:in `block in permit_concurrent_loads'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activesupport-5.1.7/lib/active_support/concurrency/share_lock.rb:185:in `yield_shares'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activesupport-5.1.7/lib/active_support/dependencies/interlock.rb:45:in `permit_concurrent_loads'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/connection_adapters/abstract_mysql_adapter.rb:213:in `block in execute'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/connection_adapters/abstract_adapter.rb:613:in `block (2 levels) in log'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/connection_adapters/abstract_adapter.rb:612:in `block in log'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activesupport-5.1.7/lib/active_support/notifications/instrumenter.rb:21:in `instrument'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/connection_adapters/abstract_adapter.rb:604:in `log'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/connection_adapters/abstract_mysql_adapter.rb:212:in `execute'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/connection_adapters/mysql/database_statements.rb:26:in `execute'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/connection_adapters/abstract_mysql_adapter.rb:223:in `execute_and_free'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/connection_adapters/mysql/database_statements.rb:31:in `exec_query'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/connection_adapters/abstract/database_statements.rb:102:in `exec_insert'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/connection_adapters/abstract/database_statements.rb:133:in `insert'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/connection_adapters/abstract/query_cache.rb:17:in `insert'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/relation.rb:61:in `insert'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/persistence.rb:583:in `_create_record'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/counter_cache.rb:176:in `_create_record'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/locking/optimistic.rb:69:in `_create_record'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/attribute_methods/dirty.rb:297:in `_create_record'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/callbacks.rb:344:in `block in _create_record'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activesupport-5.1.7/lib/active_support/callbacks.rb:131:in `run_callbacks'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activesupport-5.1.7/lib/active_support/callbacks.rb:827:in `_run_create_callbacks'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/callbacks.rb:344:in `_create_record'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/timestamp.rb:102:in `_create_record'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/persistence.rb:554:in `create_or_update'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/callbacks.rb:340:in `block in create_or_update'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activesupport-5.1.7/lib/active_support/callbacks.rb:827:in `_run_save_callbacks'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/callbacks.rb:340:in `create_or_update'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/persistence.rb:162:in `save!'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/validations.rb:50:in `save!'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/attribute_methods/dirty.rb:43:in `save!'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/transactions.rb:313:in `block in save!'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/transactions.rb:384:in `block in with_transaction_returning_status'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/connection_adapters/abstract/database_statements.rb:233:in `transaction'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/transactions.rb:210:in `transaction'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/transactions.rb:381:in `with_transaction_returning_status'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/transactions.rb:313:in `save!'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/suppressor.rb:46:in `save!'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/persistence.rb:51:in `create!'
/opt/zammad/app/models/locale.rb:129:in `block (2 levels) in to_database'
/opt/zammad/app/models/locale.rb:124:in `each'
/opt/zammad/app/models/locale.rb:124:in `block in to_database'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/connection_adapters/abstract/database_statements.rb:235:in `block in transaction'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/connection_adapters/abstract/transaction.rb:194:in `block in within_new_transaction'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/connection_adapters/abstract/transaction.rb:191:in `within_new_transaction'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/connection_adapters/abstract/database_statements.rb:235:in `transaction'
/opt/zammad/app/models/locale.rb:123:in `to_database'
/opt/zammad/app/models/locale.rb:63:in `load'
/opt/zammad/app/models/locale.rb:48:in `sync'
/opt/zammad/db/seeds.rb:33:in `<top (required)>'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activesupport-5.1.7/lib/active_support/dependencies.rb:286:in `load'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activesupport-5.1.7/lib/active_support/dependencies.rb:286:in `block in load'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activesupport-5.1.7/lib/active_support/dependencies.rb:258:in `load_dependency'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/railties-5.1.7/lib/rails/engine.rb:549:in `load_seed'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/tasks/database_tasks.rb:270:in `load_seed'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/activerecord-5.1.7/lib/active_record/railties/databases.rake:184:in `block (2 levels) in <top (required)>'
/opt/zammad/.rvm/gems/ruby-2.4.4/gems/rake-12.3.2/exe/rake:27:in `<top (required)>'
/opt/zammad/.rvm/gems/ruby-2.4.4/bin/ruby_executable_hooks:24:in `eval'
/opt/zammad/.rvm/gems/ruby-2.4.4/bin/ruby_executable_hooks:24:in `<main>'
Tasks: TOP => db:seed
Rocky
June 8, 2019, 2:35pm
3
I ignored the rake db:seed errors and continued installation.
When I click on the Knowledge Base option and then click on Time Accounting or some other options the UI is corrupted and displays things twice, like this:
I tested this in the latest versions of Firefox and Edge browsers, both give the same problem.
Rocky
June 8, 2019, 2:43pm
4
Another problem:
Email subjects are corrupted, they have =0A at the end like this:
" Helpdesk signin detected from a new device=0A"
" Invitation to Helpdesk at help.redacted.com=0A"
Welcome.
First, here’s some lecture for you:
https://community.zammad.org/t/asking-for-help-on-community/2262/2
Secondly, your installation is not finished with ignoring that.
Rocky:
ActiveRecord::StatementInvalid: Mysql2::Error: Incorrect string value: ‘\xD0\x91\xD1\x8A\xD0\xBB…’ for column ‘name’ at row 1: INSERT INTO locales (locale, alias, name, created_at, updated_at) VALUES (‘bg’, ‘’, ‘Bulgarian (Български)’, ‘2019-06-08 14:01:58.807000’, ‘2019-06-08 14:01:58.807000’) /opt/zammad/.rvm/gems/ruby-2.4.4/gems/mysql2-0.4.10/lib/mysql2/client.rb:120:in `_query’
You might want to ensure that you’re using an UTF-8 based database.
You’ll run in more and more errors, if you don’t fix that.
(I’ll ignore the other problems you experience, because the above needs to be fixed first)
You’ll need to add host: xyz to your database.yml.
Please note that we had better experience with postgresql.
system
Closed
October 8, 2019, 12:34am
6
