Just for completeness - the following issue affects above behavior:
opened 09:21AM - 21 Sep 21 UTC
bug
ticket
verified
prioritised by payment
Please post:
- Feature requests
- Development questions
- Technical questions
### Infos:
* Used Zammad version: 4.1/stable
* Installation method (source, package, ..): any
* Operating system: any
* Database + version: any
* Elasticsearch version: any
* Browser + version: verified on Google Chrome & Thunderbird
* Ticket: #1092157
### Expected behavior:
Using variables within URLs in signatures is no problem if you insert them correctly.
### Actual behavior:
Zammad sanitizes correct inserted URL to death upon saving the signature.
*Note: This does not affect e.g. trigger based emails*
* update any signature of your choice and insert the following URL without formatting (CTRL+SHIFT+V)
`https://example.com/kundenzufriedenheit/123456/1a2b3d/!pi=#{ticket.number}`
* save the signature
* go to any ticket and hit reply and check the signature - the link already is broken:
<a href="https://example.com/kundenzufriedenheit/123456/1a2b3d/!pi=#%7Bticket.number%7D"
title="https://example.com/kundenzufriedenheit/123456/1a2b3d/!pi=71005"
rel="nofollow noreferrer noopener"
target="_blank">https://example.com/kundenzufriedenheit/123456/1a2b3d/!pi=71005
</a>
* double tab in the signature section (it's broken there as well)
I also checked rails console level - this is how Zammad saves it into the database
system
Closed
January 19, 2022, 4:15pm
#3
