Folder Structure to Better Organize Workflows
Title: Folder Structure to Better Organize Workflows
    When working with a larger number of workflows (e.g. 50+), it becomes increasingly difficult to keep an overview. The workflows list becomes long and cluttered, making it hard to quickly locate specific workflows.
    This affects users who manage multiple structured process areas, for example:
  • HR processes (onboarding, offboarding, employee changes)
  • Change, Incident, and Problem Management
  • Service request automation and operational workflows
In these cases, workflows often follow thematic areas, and a flat list becomes inefficient.
    Currently, workflows can only be sorted alphabetically by title. Many admins use naming conventions (e.g. prefixes like CM_), which is only a workaround and does not scale well.
  2. What is your expectation/what do you want to achieve?
    An option to assign workflows to folders or categories to improve structure and usability.
Add a field “Folder” in the workflow configuration, e.g.:
Example: Assign Workflow to Folder in the workflow configuration.
And display the workflows grouped by folders in the overview (expandable/collapsible folders).
Example - Workflow view with Folders (expanded)
This feature would purely enhance organization and visibility. The existing workflow priority logic can stay exactly as it is — this suggestion is simply about making workflows easier to navigate and group, especially as the number of workflows grows. It would help admins structure their processes more clearly right from the start.
The same concept could also be very useful for triggers.
Just a small idea from my side to help improve usability and make working with larger environments even smoother. :blush:
Thanks so much for considering it — and thanks for all the great work on Zammad!
Best regards,
With 4 pages of Workflows, I share your pain
Agreed, I think something like this would be a big QOL improvement for us too.
