xeno
June 19, 2019, 2:50pm
1
Used Zammad version: 3.0.0-1560433985.617324d6.bionic
Used Zammad installation source: (source, package, …) ubuntu-package
Operating system: ubuntu 18.04 x64
Browser + version: not relevant
migrator reports some correlation data to identify issues
migrator fails with timeouts, but hard to find what is the cause for it
output grep cat console.log|grep -E "thread#5:|^[[:blank:]]+from"
thread#5: update Ticket.find_by(id: 35325) thread#5: update Ticket::Article.find_by(id: 3892741) thread#5: loading 20 Ticket starting at 56240... thread#5: POST: https://otrs.example.com/otrs/public.pl?Action=ZammadMigrator thread#5: PARAMS: {:Subaction=>"Export", :Object=>"Ticket", :Limit=>20, :Offset=>56240, :Diff=>0, :Action=>"ZammadMigrator", :Key=>"123456789wert6zuio"} from lib/import/otrs/requester.rb:130:inpost’
from lib/import/otrs/requester.rb:90:in request_json' from lib/import/otrs/requester.rb:77:inrequest_result’
from lib/import/otrs/requester.rb:32:in load' from lib/import/otrs.rb:141:inimport_action’
from lib/import/otrs.rb:135:in imported?' from lib/import/otrs.rb:99:inblock (3 levels) in threaded_import’
from lib/import/otrs.rb:93:in loop' from lib/import/otrs.rb:93:inblock (2 levels) in threaded_import’
thread#5: ERROR: #<Net::ReadTimeout: Net::ReadTimeout>
thread#5: PARAMS: {:Subaction=>“Export”, :Object=>“Ticket”, :Limit=>20, :Offset=>56240, :Diff=>0, :Action=>“ZammadMigrator”, :Key=>“123456789wert6zuio”}
from /opt/zammad/lib/import/otrs/requester.rb:90:in request_json' from /opt/zammad/lib/import/otrs/requester.rb:77:inrequest_result’
from /opt/zammad/lib/import/otrs/requester.rb:32:in load' from /opt/zammad/lib/import/otrs.rb:141:inimport_action’
from /opt/zammad/lib/import/otrs.rb:135:in imported?' from /opt/zammad/lib/import/otrs.rb:99:inblock (3 levels) in threaded_import’
from /opt/zammad/lib/import/otrs.rb:93:in loop' from /opt/zammad/lib/import/otrs.rb:93:inblock (2 levels) in threaded_import’
from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/logging-2.2.2/lib/logging/d`
run migration from very old OTRS (install 2005; currently running 5.0.x )
Any ideas how to track down the issue? I am missing any correlation to OTRS to get the corresponding error or message from log from OTRS
xeno
June 21, 2019, 10:08am
3
hey come on
So basic steps are surely done… You see it from the first log message also, that the migration was already running.
So yes, plugin is installed.
Have I not seen some correlationID in the OTRS logs? If so, what is the ID?
Sorry for asking
@anon29869905 might be a better partner here
xeno
June 24, 2019, 7:05am
5
I am failing with the migration and since of really to few details and also what time the thread was started it seems not to be solvable.
@anon29869905 any updates on the correlationID (e.g. a timestamp on requests or even better a uuid on OTRS log and zammad-migrator log) to track down my issues?
Maybe also something of these related issues? Are multiple runs of OTRS migrator possible - maybe with yearly migrate runs? - #3 by xeno
e.g. I am often failing on:
thread#1: loading 20 Ticket starting at 56480...
thread#1: POST: https://otrs.example.com/otrs/public.pl?Action=ZammadMigrator
thread#1: PARAMS: {:Subaction=>"Export", :Object=>"Ticket", :Limit=>20, :Offset=>56480, :Diff=>0, :Action=>"ZammadMigrator", :Key=>"1234567890ßqwertzuiop"}
thread#1: ERROR: #<Net::ReadTimeout: Net::ReadTimeout>
from /opt/zammad/lib/import/otrs/requester.rb:90:in "request_json"
from /opt/zammad/lib/import/otrs/requester.rb:77:in "request_result"
from /opt/zammad/lib/import/otrs/requester.rb:32:in "load"
from /opt/zammad/lib/import/otrs.rb:141:in "import_action"
from /opt/zammad/lib/import/otrs.rb:135:in "imported?"
from /opt/zammad/lib/import/otrs.rb:99:in "block (3 levels) in threaded_import"
from /opt/zammad/lib/import/otrs.rb:93:in "loop"
from /opt/zammad/lib/import/otrs.rb:93:in "block (2 levels) in threaded_import"
from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in "block in create_with_logging_context"
since I cannot correlate the error with OTRS log I am failing to track down the issue
Thorsten currently is quite busy, please give him sime time.
If you need help NOW and thus need commercial services, please feel free to contact us at sales [at] zammad [dot] com
Hi @xeno ,
I can’t see any remarks about the correlationID in the logs. Can you tell me where it comes from?
What I see in the logs is that your OTRS takes to long to answer that HTTP POST request:
It runs into a timeout:
These timeouts are usually enough but apparently not in your case. You can go and change these in your local installation by tweaking the following numbers:
xeno
June 24, 2019, 10:45am
8
on multi-systems debugging via log you need something to correlate the log messages. The simpliest one is a timestamp in the logs. This is missing in the migrator.
The better one is to have UUIDs on both sides, so you clearly identify errors independently if you have tons of parallel threads on any system.
thread#5: PARAMS: {:Subaction=>“Export”, :Object=>“Ticket”, :Limit=>20, :Offset=>56240, :Diff=>0, Action=>“ZammadMigrator”, :Key=>“123456789wert6zuio”}
how do you see it from that log message? I have no clue how you identify the issue from this line?
Thank you for the hint. Changed the timeouts by trippeling them. Will report if this will not work.
xeno
July 11, 2019, 9:22am
9
Just for clearance, I am referencing here the console output and not the production.log of zammad.
Got the hint from @MrGeneration to also check the production.log which I am running now again.
Anyway please add also the timestamp to the console output
xeno
July 11, 2019, 6:20pm
10
after identifying that production.log is containing similar data as the console output but with timestamps, I could track down that my read_timeout of 120sec is still too small. Increased it now to read_timeout=600 along with total_timeout=1800 and rerunning my migration again.
Maybe it helps now…
system
Closed
November 8, 2019, 6:20pm
11
