Docker Treafik - csrf token validation failed
Hello I am running Zammad with Docker.
In order to be able to use the domain and LetsEnCrypt I have this running with Traefik.
Now I get everything displayed well and when I log in for the first time everything works.
After an initial logout, I can no longer log in.
He then always reports “csrf token validation failed”
sorry here my docker-compose.override.yml
version: '2'
services:
  zammad-backup:
    container_name: Zammad-Backup
  zammad-elasticsearch:
    container_name: Zammad-ElasticSearch
  zammad-init:
    container_name: Zammad-Init
  zammad-memcached:
    container_name: Zammad-MemCached
  zammad-postgresql:
    container_name: Zammad-PostgreSQL
  zammad-railsserver:
    container_name: Zammad-RailsServer
  zammad-scheduler:
    container_name: Zammad-Scheduler
  zammad-websocket:
    container_name: Zammad-WebSocket
  zammad-nginx:
    container_name: Zammad-NGINX
    labels:
      traefik.enable: true
      # Routers
      traefik.http.routers.zammad-nginx.rule: Host(`service.leather-fabrics-online.com`)
      traefik.http.routers.zammad-nginx.entrypoints: websecure
      traefik.http.routers.zammad-nginx.tls.certresolver: myresolver
      traefik.http.routers.zammad-nginx.service: zammad_svc
      traefik.http.services.zammad_svc.loadBalancer.server.port: 80
Hello I have been trying the last few days to fix the error.
Who wants can take my 2 files for testing here.
I saved everything under / home / container and there
git clone GitHub - zammad/zammad-docker-compose: Zammad Docker images for docker-compose
then the 2 attached files overwritten.
All containers go up and you can log in to Zammad for the first time after logging out, only the error then also my config for tobacco does nothing.
Is this header sufficient or does anything else have to be transferred?
Here my
docker-compose-override.yml
version: ‘2’
services:
zammad-backup:
zammad-init:
zammad-memcached:
zammad-postgresql:
zammad-railsserver:
zammad-scheduler:
zammad-websocket:
zammad-nginx:
labels:
  # Routers
  traefik.http.routers.zammad-nginx.rule: Host(`service.example.com`)
  traefik.http.routers.zammad-nginx.middlewares: zammadHeader
  traefik.http.middlewares.zammadHeader.headers.customrequestheaders.X-Forwarded-Proto: https
and my docker-compose.yml
version: “2”
services:
traefik:
image: traefik:v2.1
container_name: Traefik
command:
- “–log.level=INFO”
- “–api”
- “–providers.docker=true”
- “–providers.docker.exposedbydefault=false”
- “–entrypoints.web.address=:80”
- “–entrypoints.websecure.address=:443”
- “–certificatesresolvers.myresolver.acme.httpchallenge=true”
- “–certificatesresolvers.myresolver.acme.httpchallenge.entrypoint=web”
- “–certificatesresolvers.myresolver.acme.caserver=https://acme-v02.api.letsencrypt.org/directory”
- “--certificatesresolvers.myresolver.acme.email=infos@example.de”
- “–certificatesresolvers.myresolver.acme.storage=/letsencrypt/acme.json”
ports:
- 80:80
- 443:443
volumes:
- ./letsencrypt:/letsencrypt
- /var/run/docker.sock:/var/run/docker.sock:ro
labels:
  # Routers
  traefik.http.routers.traefik.rule: Host(`traefik.example.de`)
  traefik.http.routers.traefik.entrypoints: websecure
  traefik.http.routers.traefik.service: api@internal
  traefik.http.routers.traefik.tls.certresolver: myresolver
  traefik.http.routers.traefik.middlewares: traefik-auth
  # global redirect to https
  traefik.http.routers.http-catchall.rule: hostregexp(`{host:.+}`)
  traefik.http.routers.http-catchall.entrypoints: web
  traefik.http.routers.http-catchall.middlewares: redirect-to-https
  # Middleware
  traefik.http.middlewares.traefik-auth.basicauth.removeheader: true
  traefik.http.middlewares.traefik-auth.basicauth.users: example:$$1$$X[kMyb^l$$Npy/uslnNuMB4pK0focS00
  # middleware redirect
  traefik.http.middlewares.redirect-to-https.redirectscheme.scheme: https
portainer:
image: portainer/portainer
container_name: Portainer
command: -H unix:///var/run/docker.sock
restart: always
volumes:
- portainer_data:/data
labels:
  # Routers
  traefik.http.routers.portainer.rule: Host(`portainer.example.de`)
  traefik.http.routers.portainer.entrypoints: websecure
  traefik.http.routers.portainer.tls.certresolver: myresolver
  traefik.http.routers.portainer.service: portainer_svc
  traefik.http.services.portainer_svc.loadBalancer.server.port: 9000
zammad-backup:
command: [“zammad-backup”]
depends_on:
- zammad-railsserver
entrypoint: /usr/local/bin/backup.sh
environment:
- BACKUP_SLEEP=86400
- HOLD_DAYS=10
- POSTGRESQL_USER=${POSTGRES_USER}
- POSTGRESQL_PASSWORD=${POSTGRES_PASS}
image: ${IMAGE_REPO}:zammad-postgresql${VERSION}
links:
- zammad-postgresql
restart: ${RESTART}
volumes:
- zammad-backup:/var/tmp/zammad
- zammad-data:/opt/zammad
environment:
- discovery.type=single-node
image: ${IMAGE_REPO}:zammad-elasticsearch${VERSION}
restart: ${RESTART}
volumes:
- elasticsearch-data:/usr/share/elasticsearch/data
zammad-init:
command: [“zammad-init”]
depends_on:
- zammad-postgresql
image: ${IMAGE_REPO}:zammad${VERSION}
links:
- zammad-elasticsearch
- zammad-postgresql
restart: on-failure
volumes:
zammad-memcached:
command: memcached -m 256M
image: memcached:1.5.22-alpine
restart: ${RESTART}
zammad-nginx:
command: [“zammad-nginx”]
expose:
- “80”
depends_on:
links:
- zammad-websocket
restart: ${RESTART}
volumes:
zammad-postgresql:
environment:
- POSTGRES_USER=${POSTGRES_USER}
- POSTGRES_PASSWORD=${POSTGRES_PASS}
restart: ${RESTART}
volumes:
- postgresql-data:/var/lib/postgresql/data
zammad-railsserver:
command: [“zammad-railsserver”]
depends_on:
- zammad-memcached
- zammad-postgresql
links:
- zammad-memcached
- zammad-postgresql
restart: ${RESTART}
volumes:
zammad-scheduler:
command: [“zammad-scheduler”]
depends_on:
- zammad-memcached
links:
- zammad-memcached
- zammad-postgresql
restart: ${RESTART}
volumes:
zammad-websocket:
command: [“zammad-websocket”]
depends_on:
- zammad-memcached
links:
- zammad-postgresql
- zammad-memcached
restart: ${RESTART}
volumes:
volumes:
portainer_data:
elasticsearch-data:
driver: local
postgresql-data:
driver: local
zammad-backup:
driver: local
zammad-data:
driver: local
Hello, have you found a solution?
I have the same problem, in the same configuration.
Well…
I solved this problem by creating a new NginX container with an optimized configuration that you can find here : https://github.com/zammad/zammad-docker-compose/issues/120#issuecomment-567013772
Here is my code, something really simple.
Dockerfile
FROM nginx
RUN rm /etc/nginx/conf.d/default.conf
COPY config/nginx.conf /etc/nginx/nginx.conf
COPY config/services/* /etc/nginx/conf.d/
EXPOSE 443 80
config/nginx.conf (the same as zammad)
user www-data;
worker_processes auto;
pid /run/nginx.pid;
include /etc/nginx/modules-enabled/*.conf;
events {
	worker_connections 768;
http {
	sendfile on;
	tcp_nopush on;
	tcp_nodelay on;
	keepalive_timeout 65;
	types_hash_max_size 2048;
	include /etc/nginx/mime.types;
	default_type application/octet-stream;
	ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
	ssl_prefer_server_ciphers on;
	access_log /var/log/nginx/access.log;
	error_log /var/log/nginx/error.log;
	gzip on;
	include /etc/nginx/conf.d/*.conf;
config/services/default.conf
upstream zammad-railsserver {
    server zammad-railsserver:3000;
upstream zammad-websocket {
    server zammad-websocket:6042;
map $http_x_forwarded_proto $real_scheme {
    default $http_x_forwarded_proto;
    '' $scheme;
server {
    listen 80;
    server_name _;
    root /opt/zammad/public;
    access_log /dev/stdout;
    error_log  /dev/stdout;
    client_max_body_size 50M;
        expires max;
    location /ws {
        proxy_http_version 1.1;
        proxy_set_header X-Forwarded-Proto $real_scheme;
        proxy_read_timeout 86400;
    location / {
        proxy_read_timeout 300;
        gzip on;
        gzip_proxied any;
