CSRF Token Verification Failed Issue – Reverse Proxy HTTPS Setup
  • Used Zammad version: 6.5.0-53
  • Used Zammad installation type: (source, package, docker-compose, …) (Docker image: Package zammad · GitHub)
  • Operating system: Ubuntu 24.04 LTS
  • Browser + version: * Google Chrome 124 (desktop & mobile), Safari (iOS), Firefox (tested incognito)
  • Succesfully log in to self hosted zammad
  • CSRF Token Verification Failed on submitting
Hey Zammad team :waving_hand:
I’m running into a persistent CSRF token verification failed issue when trying to log in to Zammad, even after setting up a secure HTTPS reverse proxy with proper headers and trusted proxy settings.
:wrench: Setup:
  • Zammad version: Docker Compose (latest stable)
  • Host OS: Ubuntu 24.04
  • Reverse proxy: External NGINX instance (192.168.1.202)
  • Zammad app server: Docker container (192.168.1.220)
  • Domain: support.handle-it.lt
  • HTTPS: Let’s Encrypt SSL (confirmed working)
  • Accessed through: https://support.handle-it.lt
:brick: NGINX config:
nginx
CopyEdit
server {
    listen 443 ssl;
    server_name support.handle-it.lt;
    ssl_certificate /etc/letsencrypt/live/support.handle-it.lt/fullchain.pem;
    ssl_certificate_key /etc/letsencrypt/live/support.handle-it.lt/privkey.pem;
    location / {
        proxy_pass http://192.168.1.220:8080;
        proxy_set_header Host $host;
        proxy_set_header X-Real-IP $remote_addr;
        proxy_set_header Cookie $http_cookie;
        proxy_cookie_path / "/; Secure; HttpOnly; SameSite=None";
server {
    listen 80;
:white_check_mark: What I’ve done so far:
  • Ran:
bash
CopyEdit
docker-compose exec zammad-railsserver rails r "Setting.set('trusted_proxies', ['192.168.1.202'])"
  • Restarted all containers (docker-compose restart)
  • Verified headers and cookies in browser devtools
  • Cleared browser cache and cookies, used Incognito mode
  • Tried both desktop and mobile login
  • Cookies like zammad_session and _csrf_token are often missing or inconsistent
:cross_mark: Current issue:
  • Login page loads correctly
  • On submit: CSRF token verification failed
  • WebSocket connects but login is rejected
  • No relevant logs beyond the CSRF message
  • Tried injecting a test cookie via NGINX (which is visible), so SSL + headers seem okay
:sos_button: What else can I check or do?
Let me know if I should test anything else, dump logs, or provide container environment info. Really appreciate your help on this – going nuts :sweat_smile:
:speech_balloon: Thank you in advance! :folded_hands:
You may want to check out my topic here ( Installing via Plesk and Fixing Error "CSRF token verification failed" ) for what I did to get it to work.
The main thing I’m seeing missing from your configuration here that helped me is
proxy_set_header X-Forwarded-Ssl on;
I was using a reverse proxy running on a separate machine like you but I was using traefik. What worked for me was by setting the environment variable NGINX_SERVER_SCHEME to https in my docker compose file.
x-shared:
  zammad-service: &zammad-service
    environment: &zammad-environment
      NGINX_PORT:
      NGINX_CLIENT_MAX_BODY_SIZE:
      NGINX_SERVER_NAME:
      NGINX_SERVER_SCHEME: https
