CSRF failure after backup and restore
  • Used Zammad version: 3.2
  • Used Zammad installation source: DEB
  • Operating system: Ubuntu
  • Browser + version: Chrome 80.0.3987.122
  • I am trying to move my Zammad system to a new server
  • Did a backup on old server as described here: backup and restore
  • Set up a new server with a new Zammad system
  • Restored old data
  • Got a CSRF failure
  • Assigned old IP and domain to new server
  • Still got a CSRF failure :wink:
Sorry for opening a new post, this would perfectly fit in here but that post was closed while I was typing :-/
Thanks for any help,
best regards,
Simon
This is my zammad.conf:
this is the nginx config for zammad
upstream zammad {
server localhost:3000;
upstream zammad-websocket {
server localhost:6042;
Added - Automatically redirect HTTP to HTTPS Nginx
server {
listen 80;
server_name my.domain.de;
Added - HTTPS configuration for Zammad
server {
listen 443 http2 ssl;
ssl_certificate /etc/letsencrypt/live/my.domain.de/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/my.domain.de/privkey.pem;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_prefer_server_ciphers on;
ssl_ciphers “EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH”;
ssl_ecdh_curve secp384r1;
ssl_session_tickets off;
ssl_stapling on;
ssl_stapling_verify on;
resolver 8.8.8.8 8.8.4.4 valid=300s;
resolver_timeout 5s;
add_header Strict-Transport-Security “max-age=63072000; includeSubdomains”;
add_header X-Frame-Options DENY;
add_header X-Content-Type-Options nosniff;
replace ‘localhost’ with your fqdn/domain name if you want to use zammad from remote
root /opt/zammad/public;
client_max_body_size 50M;
expires max;
location /ws {
proxy_http_version 1.1;
proxy_set_header Connection “Upgrade”;
proxy_read_timeout 86400;
location / {
proxy_read_timeout 180;
proxy_pass http://zammad;
gzip on;
gzip_proxied any;
Please have a look at this thread, it will solve your issue:
Thank you very much! I figured it out now.
But here is the next problem:
Everything is restored, I did
but I am not able to login, this is the error I get:
2020-03-07
Requesting a new password does not work either.
Any ideas?
Thanks in advance :wink:
Simon
Please don’t mix topics.
Lookup the provided ID with a friendly grep in your production log.
These error ids are generated randomly and have no real connection to learn what went wrong.
Hehe, thanks for the hint. It shows that I am not mixing topics, but that was lucky :wink:
[2020-03-07T14:49:42.690917 #2136-47063552666340] ERROR – : Error ID cSlzkeB p: CSRF token verification failed!
That error haunts me…
Fixed it.
What I did:
1.: Go to the old system.
2.: Find this in settings:
It was set to “https”, that was the mistake. Set it to “http”.
3. Do the backup
4. Restore on new server.
5. Get a beer.
Glad you could solve it.
I see flaws in your list thoguh.
DId you mean:
3. Do the backup
4. Get a beer.
5. Restore on new server.
6. Get a beer.
? :wink:
