- Used Zammad version: V4.0
- Used Zammad installation type: (source, package, docker-compose, …): package
- Operating system: centos7
- Browser + version: chrome/firfox
- I want to connect my zammad instance to grafana
- I dont know how to configure grafana with the right parameters
->zammad and grafana are installed on different VM on the same private network
on zammad VM :
# curl http://localhost:9200
"name" : "helpdesk.xxx.xx",
"cluster_name" : "elasticsearch",
"cluster_uuid" : "yyyyyyyyyyyyyyyy",
"version" : {
"number" : "7.6.2",
"build_flavor" : "default",
"build_type" : "rpm",
"build_hash" : "dfg8eb548236666466ggddtaabd087olhtngf",
"build_date" : "2020-01-26T06:34:37.853214A",
"build_snapshot" : false,
"lucene_version" : "8.4.0",
"minimum_wire_compatibility_version" : "6.8.0",
"minimum_index_compatibility_version" : "6.0.0-beta1"
"tagline" : "You Know, for Search"
How to configure grafana datasource? I couldnt found clear documentation with steps , just this ticket helped me Grafana dashboards - #2 by MrGeneration
->I can’t put http://localhost:9200 because its on another server
→ I have tried http://helpdesk.xxx.xx:9200
