Title: Webhooks for Zoom channel
- What is your original issue/pain point you want to solve? i can not to add a zoom as a webhook.
- Which are one or two concrete situations where this problem hurts the most? The type of security in Zammad-Webhook is not compatible with zoom security-System
- Why is it not solvable with the Zammad standard? Cause Zoom does not use HMAC SHA1 Signatur-Token or HTTP Basic Authentication Passwort
- What is your expectation/what do you want to achieve? i would like to send the new Tickets to our Admin-Team in the Zoom Channel
i get this in HTTP log:
“400 Bad Request","body":"400 Bad Request","success":false,"serverError":false}”
Your Zammad environment:
- Average concurrent agent count: 3
- Average tickets a day: 10
- What roles/people are involved: Customers and Agents
when i test the following commandline on Linux Machine. It will send the Message successfully:
curl 'https://integrations.zoom.us/chat/webhooks/incomingwebhook/XYXYXXYXYXXYXX?format=message' -X POST -H 'Authorization: xXXyxyxyxXXXYXYXX' -H 'Content-Type: application/json' -d 'Hello World!'
Best Regards
