Used Zammad installation source: Package, self-hosted
Operating system: Linux
Browser + version: Chrome
Hi everyone!
We are a new Zammad user, still mostly in setup stages but we’ve noticed a relatively annoying behaviour…
I’d like to know if there is a setting or to get a setting to auto-merge tickets with the same subject + sender? The ticketing systems our suppliers use aren’t quite as good as Zammad and each time they send a reply to us it’s a ‘new email’ from them, not an actual reply, so my inbox starts looking like this…
The ticket numbers you see above (453777 & 454185) are the other company’s ticket numbers, which are only ever interal - we do all the customer communication from another Zammad ticket and link the two.
Ideally I’d like to setup an auto-merge filter, only for specific scenarios with dynamic variables, for example if:
There’s actually a functionality that tries to automatically merge two tickets if they come in within a very short time period. Biggest thumb of rule for that is that the subject and sender are an exact match. I guess that time span is not enough in your case or other requirements are not met.
Beside of above mentioned there’s no possibility to always merge a specific mail with very specific meta information into a specific ticket. The issue you’re describing appears because the sender probably removes Header information and the ticket number from the subject which causes Zammad to not recognize a follow up.
The only thing we could do about that is a custom development in case those mails are always predictable technically. We actually did the same with ServiceNow which is a sponsored functionality for the Zammad core ( Release 3.4.0 (minor) & 3.3.1 (patch) | Zammad ).
