Add Mastodon Integration
I would really appreciate a mastodon-integration similar to the twitter-integration, so DMs and Mentions can be used to create tickets and reply’s will get send to the person that mentioned the user.
The API-Documentation can be found under Apis - Mastodon documentation.
I’m closing this feature request in favor of Integration of Mastodon into Zammad which has more drag than this one.
