Zammad throwing 502 Bad Gateway after upgrade
I run zammad upgrade today followed procedure from the site.
Zammad old version was 3.6.0 and now it;s 6.1.0
That is bad since I needed to upgrade to version 4.0 first. I got that after exicute these commands;
apt update and apt upgrade
There is a way to downgrade a Zammad to a previous version?
  • Used Zammad version: 3.6.0
  • Used Zammad installation type: ( package)
  • Browser + version: Version 123.0.6312.124 (Official Build) (64-bit)
    • After updating my server I expected normal behavior like before upgrade
  • I’m getting error in my Browser when I try to open my ticketing. 502 Bad gateway
  • Zammad service is up and running, nginx also
  • Here is output from this command: zammad run rails c
miloje@ticketing:~$ sudo zammad run rails c
[sudo] password for miloje:
        53: from /opt/zammad/bin/rails:9:in `<main>'
        52: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:29:in `require'
        51: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:20:in `require_with_bootsnap_lfi'
        50: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/loaded_features_index.rb:65:in `register'
        49: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in `block in require_with_bootsnap_lfi'
        48: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in `require'
        47: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/commands.rb:18:in `<main>'
        46: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/command.rb:46:in `invoke'
        45: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/command/base.rb:69:in `perform'
        44: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/thor-1.0.1/lib/thor.rb:392:in `dispatch'
        43: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/thor-1.0.1/lib/thor/invocation.rb:127:in `invoke_command'
        42: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/thor-1.0.1/lib/thor/command.rb:27:in `run'
        41: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/commands/console/console_command.rb:95:in `perform'
        40: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/command/actions.rb:15:in `require_application_and_environment!'
        39: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/command/actions.rb:28:in `require_environment!'
        38: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/application.rb:337:in `require_environment!'
        37: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:29:in `require'
        36: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:20:in `require_with_bootsnap_lfi'
        35: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/loaded_features_index.rb:65:in `register'
        34: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in `block in require_with_bootsnap_lfi'
        33: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in `require'
        32: from /opt/zammad/config/environment.rb:5:in `<main>'
        31: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/application.rb:361:in `initialize!'
        30: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/initializable.rb:60:in `run_initializers'
        29: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:205:in `tsort_each'
        28: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:226:in `tsort_each'
        27: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:347:in `each_strongly_connected_component'
        26: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:347:in `call'
        25: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:347:in `each'
        24: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:349:in `block in each_strongly_connected_component'
        23: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:415:in `each_strongly_connected_component_from'
        22: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:415:in `call'
        21: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/initializable.rb:50:in `tsort_each_child'
        20: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/initializable.rb:50:in `each'
        19: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:421:in `block in each_strongly_connected_component_from'
        18: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:431:in `each_strongly_connected_component_from'
        17: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:422:in `block (2 levels) in each_strongly_connected_component_from'
        16: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
        15: from /opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/tsort.rb:228:in `block in tsort_each'
        14: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/initializable.rb:61:in `block in run_initializers'
        13: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/initializable.rb:32:in `run'
        12: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/initializable.rb:32:in `instance_exec'
        11: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/engine.rb:619:in `block in <class:Engine>'
        10: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/engine.rb:619:in `each'
         9: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/engine.rb:620:in `block (2 levels) in <class:Engine>'
         8: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/engine.rb:662:in `load_config_initializer'
         7: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/notifications.rb:170:in `instrument'
         6: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/engine.rb:663:in `block in load_config_initializer'
         5: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:50:in `load'
         4: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:50:in `load'
         3: from /opt/zammad/config/initializers/action_cable_preferences.rb:14:in `<main>'
         2: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/active_support.rb:57:in `load_missing_constant'
         1: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/active_support.rb:16:in `allow_bootsnap_retry'
**/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/active_support.rb:58:in `block in load_missing_constant': uninitialized constant Redis (NameError)**
Here is an error:
Any suggestion how I can resolve the issue? Thank you in advance
Vladimir
Hi @Vlad88. Sounds to me that you did something wrong during the upgrade path from Zammad 3.6.0 to 6.1.0 (which is by the way not the last version, you need to upgrade this again).
All information is here: Updating Zammad — Zammad System Documentation documentation
I hope you do have a backup of your Zammad install with version 3.6.0 that you can restore. You can do a proper upgrade then.
Thank you for response.
Yes, I made backup and I managed to restore Zammad to a previous 3.6.0 version.
Now, I will follow your guide for upgrade Zammad on a specific version.
Regards,
