Zammad services not starting due to Telegram Module
  • Used Zammad version: 6.4.
  • Operating system: Ubuntu 24.04.1 LTS
  • Browser + version: any
  • Zammad services shuld be starting
  • While opening Zammad Website we get 502 Bad Gateway
  • Zammad services restart looping with error
  • Set up a new machine
  • importet backup from old machine
  • same behavior
I have the problem after updating to 6.4.
Did you already resolve the problem?
Hi. Are there any error logs available?
During update I get these error messages:
# Updating translations...
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/telegram-bot-ruby-2.4.0/lib/telegram/bot.rb:10:in `<main>': Telegram is not a module (TypeError)
/opt/zammad/lib/telegram.rb:3: previous definition of Telegram was here
        from <internal:/opt/zammad/vendor/ruby-3.2.8/lib/ruby/3.2.0/rubygems/core_ext/kernel_require.rb>:38:in `require'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/bootsnap-1.18.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.7.1/lib/zeitwerk/core_ext/kernel.rb:34:in `require'
        from /opt/zammad/lib/telegram_helper.rb:3:in `<main>'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.7.1/lib/zeitwerk/core_ext/kernel.rb:26:in `require'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.7.1/lib/zeitwerk/cref.rb:60:in `const_get'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.7.1/lib/zeitwerk/cref.rb:60:in `get'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.7.1/lib/zeitwerk/loader/eager_load.rb:173:in `block in actual_eager_load_dir'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.7.1/lib/zeitwerk/loader/helpers.rb:47:in `block in ls'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.7.1/lib/zeitwerk/loader/helpers.rb:25:in `each'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.7.1/lib/zeitwerk/loader/helpers.rb:25:in `ls'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.7.1/lib/zeitwerk/loader/eager_load.rb:168:in `actual_eager_load_dir'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.7.1/lib/zeitwerk/loader/eager_load.rb:17:in `block (2 levels) in eager_load'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.7.1/lib/zeitwerk/loader/eager_load.rb:16:in `each'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.7.1/lib/zeitwerk/loader/eager_load.rb:16:in `block in eager_load'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.7.1/lib/zeitwerk/loader/eager_load.rb:10:in `synchronize'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.7.1/lib/zeitwerk/loader/eager_load.rb:10:in `eager_load'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.7.1/lib/zeitwerk/loader.rb:413:in `block in eager_load_all'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.7.1/lib/zeitwerk/loader.rb:411:in `each'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.7.1/lib/zeitwerk/loader.rb:411:in `eager_load_all'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.2.2.1/lib/rails/application/finisher.rb:80:in `block in <module:Finisher>'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.2.2.1/lib/rails/initializable.rb:32:in `instance_exec'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.2.2.1/lib/rails/initializable.rb:32:in `run'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.2.2.1/lib/rails/initializable.rb:61:in `block in run_initializers'
        from /opt/zammad/vendor/ruby-3.2.8/lib/ruby/3.2.0/tsort.rb:228:in `block in tsort_each'
        from /opt/zammad/vendor/ruby-3.2.8/lib/ruby/3.2.0/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
        from /opt/zammad/vendor/ruby-3.2.8/lib/ruby/3.2.0/tsort.rb:431:in `each_strongly_connected_component_from'
        from /opt/zammad/vendor/ruby-3.2.8/lib/ruby/3.2.0/tsort.rb:349:in `block in each_strongly_connected_component'
        from /opt/zammad/vendor/ruby-3.2.8/lib/ruby/3.2.0/tsort.rb:347:in `each'
        from /opt/zammad/vendor/ruby-3.2.8/lib/ruby/3.2.0/tsort.rb:347:in `call'
        from /opt/zammad/vendor/ruby-3.2.8/lib/ruby/3.2.0/tsort.rb:347:in `each_strongly_connected_component'
        from /opt/zammad/vendor/ruby-3.2.8/lib/ruby/3.2.0/tsort.rb:226:in `tsort_each'
        from /opt/zammad/vendor/ruby-3.2.8/lib/ruby/3.2.0/tsort.rb:205:in `tsort_each'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.2.2.1/lib/rails/initializable.rb:60:in `run_initializers'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.2.2.1/lib/rails/application.rb:435:in `initialize!'
        from /opt/zammad/config/environment.rb:7:in `<main>'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.2.2.1/lib/rails/application.rb:411:in `require_environment!'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.2.2.1/lib/rails/command/actions.rb:20:in `boot_application!'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.2.2.1/lib/rails/commands/runner/runner_command.rb:30:in `perform'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/thor-1.3.2/lib/thor/command.rb:28:in `run'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/thor-1.3.2/lib/thor/invocation.rb:127:in `invoke_command'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.2.2.1/lib/rails/command/base.rb:178:in `invoke_command'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/thor-1.3.2/lib/thor.rb:538:in `dispatch'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.2.2.1/lib/rails/command/base.rb:73:in `perform'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.2.2.1/lib/rails/command.rb:71:in `block in invoke'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.2.2.1/lib/rails/command.rb:149:in `with_argv'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.2.2.1/lib/rails/command.rb:69:in `invoke'
        from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.2.2.1/lib/rails/commands.rb:18:in `<main>'
        from /opt/zammad/bin/rails:4:in `<main>'
# No custom packages detected...
-- Nevermind, no es_url is set, leaving Elasticsearch untouched ...!
-- The above is all right if you don't want to use Elasticsearch (locally) - if this is not intended, consult https://docs.zammad.org !
Do you also get this error when updating to Zammad 6.4.2/6.5?
Yes, I tried 6.5 today. Same problem. Any ideas?
There is no telegram.rb in Zammads source code (anymore)
So if I’d had to guess: You migrated at some point (with all filesystem files; not recommended) which is why your package manager does not track these affected files.
Dangerzone
You’ll have to manually drop affected files.
This is quite dangerous, you should be fine if you remove everything in /opt/zammad/ except for config/ and storage. You will need to force a reinstallation of the package afterwards.
Proceed at your own danger, have a backup.
