Hi there,
I just setup a new copy of Zammad on my local machine.
I am trying to start Zammad servers with Systemd
I have run the command cd script/systemd
And the command sudo ./install-zammad-systemd-services.sh
But when I run the command systemctl start zammad
, the server does not start up
- Used Zammad version: Zammad v3.2.0
- Used Zammad installation source: source
- Browser + version: Google Chrome v77
- I expect the server the start up, so that when I visit
localhost:3000
I can see Zammad welcome screen
- The server does not start
I have ran the command systemctl status zammad
to check the status of Zammad and here’s the error message that I get
● zammad.service - Zammad
Loaded: loaded (/etc/systemd/system/zammad.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2019-10-09 19:41:56 WAT; 11s ago
Process: 19189 ExecStart=/bin/sleep infinity (code=exited, status=217/USER)
Main PID: 19189 (code=exited, status=217/USER)
Oct 09 19:41:56 Preston-PC systemd[1]: zammad.service: Failed with result 'exit-code'.
Oct 09 19:41:56 Preston-PC systemd[1]: zammad.service: Service hold-off time over, scheduling restart.
Oct 09 19:41:56 Preston-PC systemd[1]: zammad.service: Scheduled restart job, restart counter is at 5.
Oct 09 19:41:56 Preston-PC systemd[1]: Stopped Zammad.
Oct 09 19:41:56 Preston-PC systemd[1]: zammad.service: Start request repeated too quickly.
- Setup a fresh copy of Zammad
- Run the command
cd script/systemd
- Run the command
- Run the command
systemctl start Zammad
Thank you in advance for your assistance.
