- Used Zammad version: 6.5.2-1760945831.23b4cf50.noble
- Operating system: Ubuntu 24.04
- Browser + version: any
- zammad
- no zammad - 502 Bad Gateway
This is a fresh install of zammad on a fresh vm.
When I do a systemctl restart zammad it seems to shut down cleanly but doesn’t do anything after restarting. /var/log/zammad/production.log shows no activity after the clean shutdown, and ss -tuln | grep "3000\|6042" shows it is no longer listening on either of those ports. rebooting the server fixes the issue.
I seem to have extra zammad services with an appended “-1” at the end. Is that normal?
systemctl | grep zammad :
● zammad-web-1.service loaded failed failed zammad-web-1.service
zammad-web.service loaded active running zammad-web.service
● zammad-websocket-1.service loaded failed failed zammad-websocket-1.service
zammad-websocket.service loaded active running zammad-websocket.service
● zammad-worker-1.service loaded failed failed zammad-worker-1.service
zammad-worker.service loaded active running zammad-worker.service
zammad.service loaded active running zammad.service
journalctl --grep="zammad" --since "2 minutes ago"
Oct 27 08:53:01 zammad systemd[1]: Stopping zammad-web.service...
Oct 27 08:53:01 zammad systemd[1]: Stopping zammad-websocket.service...
Oct 27 08:53:01 zammad systemd[1]: Stopping zammad-worker.service...
Oct 27 08:53:01 zammad systemd[1]: zammad-web.service: Deactivated successfully.
Oct 27 08:53:01 zammad systemd[1]: Stopped zammad-web.service.
Oct 27 08:53:01 zammad systemd[1]: zammad-websocket.service: Deactivated successfully.
Oct 27 08:53:01 zammad systemd[1]: Stopped zammad-websocket.service.
Oct 27 08:53:01 zammad systemd[1]: zammad-worker.service: Deactivated successfully.
Oct 27 08:53:01 zammad systemd[1]: Stopped zammad-worker.service.
Oct 27 08:53:01 zammad systemd[1]: Stopping zammad.service...
Oct 27 08:53:01 zammad systemd[1]: zammad.service: Deactivated successfully.
Oct 27 08:53:01 zammad systemd[1]: Stopped zammad.service.
Oct 27 08:53:01 zammad systemd[1]: Started zammad.service.
Oct 27 08:53:01 zammad systemd[1]: Started zammad-web.service.
Oct 27 08:53:01 zammad systemd[1]: Started zammad-web-1.service.
Oct 27 08:53:01 zammad systemd[1]: Started zammad-websocket.service.
Oct 27 08:53:01 zammad systemd[1]: Started zammad-websocket-1.service.
Oct 27 08:53:01 zammad systemd[1]: Started zammad-worker.service.
Oct 27 08:53:01 zammad systemd[1]: Started zammad-worker-1.service.
Oct 27 08:53:01 zammad zammad[5462]: chroot: invalid group ‘domain’
Oct 27 08:53:01 zammad zammad[5467]: chroot: invalid group ‘domain’
Oct 27 08:53:01 zammad zammad[5464]: chroot: invalid group ‘domain’
Oct 27 08:53:01 zammad systemd[1]: zammad-web-1.service: Main process exited, code=exited, status=125/n/a
Oct 27 08:53:01 zammad systemd[1]: zammad-web-1.service: Failed with result 'exit-code'.
Oct 27 08:53:01 zammad systemd[1]: zammad-websocket-1.service: Main process exited, code=exited, status=125/n/a
Oct 27 08:53:01 zammad systemd[1]: zammad-websocket-1.service: Failed with result 'exit-code'.
Oct 27 08:53:01 zammad systemd[1]: zammad-worker-1.service: Main process exited, code=exited, status=125/n/a
Oct 27 08:53:01 zammad systemd[1]: zammad-worker-1.service: Failed with result 'exit-code'.
Oct 27 08:53:01 zammad systemd[1]: zammad-web-1.service: Scheduled restart job, restart counter is at 1.
Oct 27 08:53:01 zammad systemd[1]: zammad-websocket-1.service: Scheduled restart job, restart counter is at 1.
Oct 27 08:53:01 zammad systemd[1]: zammad-worker-1.service: Scheduled restart job, restart counter is at 1.
Oct 27 08:53:02 zammad zammad[5549]: chroot: invalid group ‘domain’
Oct 27 08:53:02 zammad systemd[1]: zammad-web-1.service: Main process exited, code=exited, status=125/n/a
Oct 27 08:53:02 zammad systemd[1]: zammad-web-1.service: Failed with result 'exit-code'.
Oct 27 08:53:02 zammad zammad[5550]: chroot: invalid group ‘domain’
Oct 27 08:53:02 zammad systemd[1]: zammad-websocket-1.service: Main process exited, code=exited, status=125/n/a
Oct 27 08:53:02 zammad systemd[1]: zammad-websocket-1.service: Failed with result 'exit-code'.
Oct 27 08:53:02 zammad zammad[5552]: chroot: invalid group ‘domain’
Oct 27 08:53:02 zammad systemd[1]: zammad-worker-1.service: Main process exited, code=exited, status=125/n/a
Oct 27 08:53:02 zammad systemd[1]: zammad-worker-1.service: Failed with result 'exit-code'.
Oct 27 08:53:02 zammad systemd[1]: zammad-web-1.service: Scheduled restart job, restart counter is at 2.
Oct 27 08:53:02 zammad systemd[1]: zammad-websocket-1.service: Scheduled restart job, restart counter is at 2.
Oct 27 08:53:02 zammad systemd[1]: zammad-worker-1.service: Scheduled restart job, restart counter is at 2.
Oct 27 08:53:02 zammad systemd[1]: Started zammad-web-1.service.
Oct 27 08:53:02 zammad systemd[1]: Started zammad-websocket-1.service.
Oct 27 08:53:02 zammad systemd[1]: Started zammad-worker-1.service.
Oct 27 08:53:02 zammad zammad[5633]: chroot: invalid group ‘domain’
Oct 27 08:53:02 zammad zammad[5634]: chroot: invalid group ‘domain’
Oct 27 08:53:02 zammad zammad[5640]: chroot: invalid group ‘domain’
Oct 27 08:53:02 zammad systemd[1]: zammad-web-1.service: Scheduled restart job, restart counter is at 3.
Oct 27 08:53:02 zammad systemd[1]: zammad-websocket-1.service: Scheduled restart job, restart counter is at 3.
Oct 27 08:53:02 zammad systemd[1]: zammad-worker-1.service: Scheduled restart job, restart counter is at 3.
Oct 27 08:53:02 zammad zammad[5717]: chroot: invalid group ‘domain’
Oct 27 08:53:02 zammad zammad[5718]: chroot: invalid group ‘domain’
Oct 27 08:53:02 zammad zammad[5725]: chroot: invalid group ‘domain’
Oct 27 08:53:02 zammad systemd[1]: zammad-web-1.service: Scheduled restart job, restart counter is at 4.
Oct 27 08:53:02 zammad systemd[1]: zammad-websocket-1.service: Scheduled restart job, restart counter is at 4.
Oct 27 08:53:02 zammad systemd[1]: zammad-worker-1.service: Scheduled restart job, restart counter is at 4.
Oct 27 08:53:02 zammad zammad[5801]: chroot: invalid group ‘domain’
Oct 27 08:53:02 zammad zammad[5802]: chroot: invalid group ‘domain’
Oct 27 08:53:02 zammad zammad[5805]: chroot: invalid group ‘domain’
Oct 27 08:53:02 zammad systemd[1]: zammad-web-1.service: Scheduled restart job, restart counter is at 5.
Oct 27 08:53:02 zammad systemd[1]: zammad-websocket-1.service: Scheduled restart job, restart counter is at 5.
Oct 27 08:53:02 zammad systemd[1]: zammad-worker-1.service: Scheduled restart job, restart counter is at 5.
Oct 27 08:53:02 zammad systemd[1]: zammad-web-1.service: Start request repeated too quickly.
Oct 27 08:53:02 zammad systemd[1]: Failed to start zammad-web-1.service.
Oct 27 08:53:02 zammad systemd[1]: zammad-websocket-1.service: Start request repeated too quickly.
Oct 27 08:53:02 zammad systemd[1]: Failed to start zammad-websocket-1.service.
Oct 27 08:53:02 zammad systemd[1]: zammad-worker-1.service: Start request repeated too quickly.
Oct 27 08:53:02 zammad systemd[1]: Failed to start zammad-worker-1.service.
