Infos
- Used Zammad version: 3.6.0
- Used Zammad installation source: Ubuntu package
- Operating system: Ubuntu 18.04 LTS
- Browser + version: Chrome 87.0.4280.88
- All Users displayed - searchindex:rebuild completes without errors
- No Users displayed - Rebuilding searchindex runs infinite
- run “sudo zammad run rake searchindex:rebuild --trace”
Hello
List of users, agents and admin is empty - again.
So tried - as usual - to rebuild searchindex with command listed above
Without success
** Execute environment
** Invoke searchindex:configured (first_time)
** Execute searchindex:configured
** Execute searchindex:rebuild
** Execute searchindex:drop
drop indexes...done
** Execute searchindex:drop_pipeline
** Execute searchindex:create
create indexes...done
** Execute searchindex:create_pipeline
create pipeline (pipeline)... done
** Execute searchindex:reload
reload data...
reload KnowledgeBase::Answer::Translation
- started at 2020-12-16 08:32:18 UTC
- took 2 seconds
reload KnowledgeBase::Category::Translation
- started at 2020-12-16 08:32:21 UTC
- took 0 seconds
reload KnowledgeBase::Translation
- took 0 seconds
reload Ticket
^Crake aborted!
Interrupt:
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/result.rb:44:in `initialize'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/postgresql/database_statements.rb:89:in `new'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/postgresql/database_statements.rb:89:in `block in exec_query'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/postgresql_adapter.rb:602:in `execute_and_clear'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/postgresql/database_statements.rb:81:in `exec_query'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract/database_statements.rb:482:in `select_prepared'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract/database_statements.rb:68:in `select_all'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract/query_cache.rb:106:in `select_all'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/querying.rb:41:in `find_by_sql'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/statement_cache.rb:108:in `execute'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/core.rb:208:in `find_by'
/opt/zammad/app/models/store/provider/db.rb:17:in `get'
/opt/zammad/app/models/store/file.rb:62:in `content'
/opt/zammad/app/models/store.rb:165:in `content'
/opt/zammad/app/models/ticket/search_index.rb:63:in `block (2 levels) in search_index_attribute_lookup'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.4/lib/active_record/relation/delegation.rb:71:in `each'
/opt/zammad/app/models/ticket/search_index.rb:59:in `block in search_index_attribute_lookup'
/opt/zammad/app/models/ticket/search_index.rb:40:in `search_index_attribute_lookup'
/opt/zammad/app/models/concerns/has_search_index_backend.rb:169:in `search_index_update_backend'
/opt/zammad/app/models/concerns/has_search_index_backend.rb:247:in `block in search_index_reload'
/opt/zammad/app/models/concerns/has_search_index_backend.rb:241:in `each'
/opt/zammad/app/models/concerns/has_search_index_backend.rb:241:in `search_index_reload'
/opt/zammad/lib/tasks/search_index_es.rake:162:in `block (3 levels) in <main>'
/opt/zammad/lib/tasks/search_index_es.rake:158:in `each'
/opt/zammad/lib/tasks/search_index_es.rake:158:in `block (2 levels) in <main>'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:273:in `block in execute'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:273:in `each'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:273:in `execute'
/opt/zammad/lib/tasks/search_index_es.rake:178:in `block (2 levels) in <main>'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:214:in `block in invoke_with_call_chain'
/opt/zammad/vendor/ruby-2.6.6/lib/ruby/2.6.0/monitor.rb:235:in `mon_synchronize'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:194:in `invoke_with_call_chain'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:183:in `invoke'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:160:in `invoke_task'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:116:in `each'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:116:in `block in top_level'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:125:in `run_with_threads'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:110:in `top_level'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:83:in `block in run'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:186:in `standard_exception_handling'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:80:in `run'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/exe/rake:27:in `<top (required)>'
/opt/zammad/vendor/bundle/ruby/2.6.0/bin/rake:23:in `load'
/opt/zammad/vendor/bundle/ruby/2.6.0/bin/rake:23:in `<top (required)>'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:74:in `load'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:74:in `kernel_load'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:28:in `run'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:463:in `exec'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/invocation.rb:126:in `invoke_command'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor.rb:387:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:27:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/base.rb:466:in `start'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:18:in `start'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/exe/bundle:30:in `block in <top (required)>'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/friendly_errors.rb:124:in `with_friendly_errors'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/exe/bundle:22:in `<top (required)>'
