Zammad redirects me to index of (centos 7)
I did everything to enable https and it seems that it needs something more in my
zammad.conf and my nginx.conf
STEPS TO REPRODUCE THIS
HERE IS MY ZAMMAD.CONF
upstream zammad-railsserver {
    server 127.0.0.1:3000;
upstream zammad-websocket {
    server 127.0.0.1:6042;
server {
    listen 80;
    listen [::]:80;
    server_name localhost;
    server_tokens off;
    root /opt/zammad/public;
    index index.html;
    error_log  /var/log/nginx/zammad.error.log;
    client_max_body_size 50M;
        expires max;
    # legacy web socket server
    location /ws {
        proxy_http_version 1.1;
        proxy_read_timeout 86400;
location / {
    try_files $uri $uri/ @zammad;
location @zammad {
    proxy_set_header X-Real-IP $remote_addr;
    proxy_pass http://127.0.0.1:3000;
    # action cable
    location /cable {
    location / {
        # Change this line in an SSO setup
        proxy_read_timeout 300;
        gzip on;
        gzip_proxied any;
and here is my nginx.conf
# For more information on configuration, see:
#   * Official English Documentation: http://nginx.org/en/docs/
#   * Official Russian Documentation: http://nginx.org/ru/docs/
user nginx;
worker_processes auto;
error_log /var/log/nginx/error.log;
pid /run/nginx.pid;
# Load dynamic modules. See /usr/share/doc/nginx/README.dynamic.
include /usr/share/nginx/modules/*.conf;
events {
    worker_connections 1024;
http {
    log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
                      '$status $body_bytes_sent "$http_referer" '
                      '"$http_user_agent" "$http_x_forwarded_for"';
    access_log  /var/log/nginx/access.log  main;
    sendfile            on;
    tcp_nopush          on;
    tcp_nodelay         on;
    keepalive_timeout   65;
    types_hash_max_size 4096;
    include             /etc/nginx/mime.types;
    default_type        application/octet-stream;
    # Load modular configuration files from the /etc/nginx/conf.d directory.
    # See http://nginx.org/en/docs/ngx_core_module.html#include
    # for more information.
    include /etc/nginx/conf.d/*.conf;
# Settings for a TLS enabled server.
 server {
    listen 443 ssl;
    ssl_certificate "/home/centos/zammad_aspete_gr.crt";
    ssl_certificate_key "/home/centos/mydomain.key";
    autoindex on;
   index index.htm index.html index.php;
server {
    listen 80;
    server_name zammad.aspete.gr;
    location / {
    location /ws {
        proxy_pass http://127.0.0.1:6042;
        expires max;
        add_header Cache-Control public;
I did everything!!! PLEASE HELP
The problem is that you’re mixing up the nginx.conf and zammad.conf.
It technically contains duplicate directives which is not the best approach.
You should use the zammad.conf for proxying requests to your Zammad installation and remove Zammad specific settings from the nginx.conf.
