I have been able to upgrade versions fine using these commands before but for this upgrade there seems to be a step I overlooked (or possibly a bug as this is a very new release).
It would appear that I need to update PostgreSQL but I am not exactly sure if that is the issue or not.
Let me write down some more logs as I think there might be something else going on:
(Note; prefix to all of these containers is Containers > zammad-docker-compose_zammad)
websocket_1 - waiting for init container to finish install or update…
backup_1 - waiting for railsserver to be ready…
scheduler_1 - waiting for init container to finish install or update…
nginx_1 - waiting for init container to finish install or update…
railsserver_1 - waiting for init container to finish install or update…
init_1 - zammad railsserver waiting for postgresql server to be ready…
redis_1 - (no apparent errors)
memcached_1 - Signal handled: Terminated.
postgresql_1 - The data directory was initialized by PostgreSQL version 9.6, which is not compatible with this version 15.1.
elasticsearch_1 - (no apparent errors)
If I am reading into this correctly, most servers are depending on init_1 whish is depending on postgresql_1; which is trying to read from an incompatible database. So I need to convert the database to be compatible?
On a related note… is there an easy way I can downgrade to 5.2.3 until I can get this sorted out?
Hey mcayc,
i run into the same issue with my docker-compose installation. You have to convert your database to be able to work with new postgresql image.
