Zammad should prompt me if I would like to import the older emails as an archive
Zammad does not show the ‘Import as’ option
Try to import a new email channel with a lot of old emails
I was trying to find a way to import our mailbox archive, but there is no prompt to select ‘Import as’, so the ticket creation proceeds as usual creating a ton of new tickets with the current timestampt. I have been searching for a way to import as archive, either on the GUI or in console, even through API.
Can you please help me where to look for a solution, or point me to some clues on how to add an email mailbox through the console?
Every help is much appreciated
Just as a small follow up: The archive import doesn’t care about the read state of the mail. It does however care if you have mails older than 2 weeks inside the mailbox on the moment trying to add it.
(This is mentioned on the documentation Account Setup — Zammad documentation )
Now there’s limitations:
This only works within Zammads email channels and currently is not a functionality that affects gmail and office365 channels.
Thank you for your reply,
but if there are emails not read, older or not than 2 weeks, it does not distinguish from archive email or new email and do not ask for archive option.
It works only if all email are older than 2 weeks, may be a bug.
Thank you all for your replies!
After a few trials and errors the following worked for my case:
1, create an archive mailbox, which only contain the to-be-imported emails
2, add the mailbox as a separate email channel to Zammad and choose the “Import as archive” option
3, Wait… and wait some more
Some considerations about the feature:
the import process takes a suprisingly long time, but on the good side, Zammad still works and can be used to answer new issues from other channels
sent emails are not imported if I am correct, which somewhat makes sense, but also makes judging if older tickets are closed properly more difficult
Sorry but I don’t believe that.
During documentary I did test with a productive account that had mails that were older and newer than 2 weeks. It imported just fine as it should have been and was described in the docs.
