Hi there,
I updated today my vserver security & zammad @ digitalocean and got an error afterwards.
- Used Zammad version: can’t login
- Used Zammad installation source: (source, package, …)
- Operating system: ubuntu 18.04
- Browser + version: Chrome Version 79.0.3928.4 (Offizieller Build) dev (64-Bit)
- After updating my vserver it should all just load and that I can use my ticket system
- I got an error after update and my browser doesn’t load zammad.
I just found out, after searching a while that my nginx is failing
nginx.service - A high performance web server and a reverse proxy server
Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2019-10-07 11:42:49 UTC; 56min ago
Docs: man:nginx(8)
Process: 961 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=exited, status=1/FAILURE)
Process: 868 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Oct 07 11:42:48 nice-wsrn-support nginx[961]: nginx: [emerg] bind() to 0.0.0.0:80 failed (98: Address already in use)
Oct 07 11:42:48 nice-wsrn-support nginx[961]: nginx: [emerg] bind() to [::]:80 failed (98: Address already in use)
Oct 07 11:42:49 nice-wsrn-support nginx[961]: nginx: [emerg] bind() to 0.0.0.0:80 failed (98: Address already in use)
Oct 07 11:42:49 nice-wsrn-support nginx[961]: nginx: [emerg] bind() to [::]:80 failed (98: Address already in use)
Oct 07 11:42:49 nice-wsrn-support nginx[961]: nginx: [emerg] still could not bind()
Oct 07 11:42:49 nice-wsrn-support systemd[1]: nginx.service: Control process exited, code=exited status=1
Oct 07 11:42:49 nice-wsrn-support systemd[1]: nginx.service: Failed with result ‘exit-code’.
Oct 07 11:42:49 nice-wsrn-support systemd[1]: Failed to start A high performance web server and a reverse proxy server.
