Title: Zammad-Helm add Custom ingressClassName e.g. “internal”
We use a customingressClassName
calledinternal
in our Kubernetes cluster, which is not officially defined by the standard Zammad chart. The current deployment setup does not support this custom class name correctly. -
- When deploying Zammad in our internal environment, the ingress is not created or functions incorrectly due to the unsupported
ingressClassName
. - This leads to broken or inaccessible services during internal testing or staging deployments, where the
internal
ingress class is required.
The Zammad Helm chart is not designed to handle customingressClassName
values that are not officially defined. It lacks the flexibility to override or extend the ingress configuration in a way that supports non-standard ingress class setups like ours. Additionally, there is a ConfigMap managed by the chart that contains ingress-related settings. Since this ConfigMap would be overwritten on every upgrade or change, I would have to manually adjust and maintain it repeatedly, which is error-prone and not maintainable in the long term. -
I want to be able to define and use our customingressClassName: internal
directly within the Helm deployment, without the need to manually patch resources afterward. Ideally, the chart should allow providing a full custom ingress manifest and optionally override the default ConfigMap or allow injecting custom values cleanly without modifying the upstream chart.
I created my own subchart with the following ingress.yaml
kind: Ingress
apiVersion: networking.k8s.io/v1
metadata:
labels:
app.kubernetes.io/managed-by: "Helm"
annotations:
nginx.ingress.kubernetes.io/proxy-body-size: "50m"
spec:
tls:
- hosts:
- xxx.xxx.de
secretName: xxx.xxx.de
rules:
- host: xxx.xxx.de
http:
paths:
- path: /
pathType: Prefix
backend:
service:
port:
number: 8080
Your Zammad environment:
- Average concurrent agent count: 3
- Average tickets a day: 50
- What roles/people are involved: IT Department
