Zammad freezing / Dropping Emails under Load
Zammad Version 5.3.1-1674057058.5f657f26.centos7
OS: Centos 7
Kernel: 3.10.0-1160.81.1.el7.x86_64
Installed from package.
Hardware:
CPU: 8 cores 16 HT Intel Skylake
Ram: 32Gb DDR4
Disk: Cloud SSD 8250 IOPS / 110mb/s Read/write guaranteed
System is average on about 50% CPU Load, and 60% RAM Usage.
cat /etc/zammad/conf.d/other
export RAILS_LOG_TO_STDOUT=""
export WEB_CONCURRENCY="8"
export RUBY_MALLOC_ARENA_MAX="2"
export RUBY_GC_MALLOC_LIMIT="1077216"
export RUBY_GC_MALLOC_LIMIT_MAX="2177216"
export RUBY_GC_OLDMALLOC_LIMIT="2177216"
export RUBY_GC_OLDMALLOC_LIMIT_MAX="3000100"
cat /etc/elasticsearch/elasticsearch.yml
network.host: 0.0.0.0
discovery.type: single-node
http.max_content_length: 400mb
indices.query.bool.max_clause_count: 2048
Sessions.list.count
Is normally between 20 and 30.
Zammad Running Maybe a bit slower on High load but still be able to function correctly and sending mails.
Zammad Monitoring Api Check Shows Unhealthy when the error occurs.
Zammad is running slow, nearly unusable under daily load.
Emails getting Dropped / not sended.
Out of production log:
E, [2023-02-23T10:29:30.366324 #697-940260] ERROR -- : thread_client 134980 exited with error #<ActiveRecord::ConnectionTimeoutError: could not obtain a connection from the pool within 5.000 seconds (waited 5.014 seconds); all pooled connections were in use>
E, [2023-02-23T10:29:30.374367 #697-940260] ERROR -- : /opt/zammad/vendor/bundle/ruby/3.0.0/gems/activerecord-6.1.7.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:210:in `block in wait_poll'
  /opt/zammad/vendor/bundle/ruby/3.0.0/gems/activerecord-6.1.7.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:199:in `loop'
  /opt/zammad/vendor/bundle/ruby/3.0.0/gems/activerecord-6.1.7.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:199:in `wait_poll'
  /opt/zammad/vendor/bundle/ruby/3.0.0/gems/activerecord-6.1.7.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:160:in `internal_poll'
  /opt/zammad/vendor/bundle/ruby/3.0.0/gems/activerecord-6.1.7.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:286:in `internal_poll'
  /opt/zammad/vendor/bundle/ruby/3.0.0/gems/activerecord-6.1.7.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:155:in `block in poll'
  /opt/zammad/vendor/ruby-3.0.4/lib/ruby/3.0.0/monitor.rb:202:in `synchronize'
  /opt/zammad/vendor/ruby-3.0.4/lib/ruby/3.0.0/monitor.rb:202:in `mon_synchronize'
  /opt/zammad/vendor/bundle/ruby/3.0.0/gems/activerecord-6.1.7.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:164:in `synchronize'
  /opt/zammad/vendor/bundle/ruby/3.0.0/gems/activerecord-6.1.7.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:155:in `poll'
  /opt/zammad/vendor/bundle/ruby/3.0.0/gems/activerecord-6.1.7.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:870:in `acquire_connection'
  /opt/zammad/vendor/bundle/ruby/3.0.0/gems/activerecord-6.1.7.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:588:in `checkout'
  /opt/zammad/vendor/bundle/ruby/3.0.0/gems/activerecord-6.1.7.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:428:in `connection'
  /opt/zammad/vendor/bundle/ruby/3.0.0/gems/activerecord-6.1.7.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:1128:in `retrieve_connection'
  /opt/zammad/vendor/bundle/ruby/3.0.0/gems/activerecord-6.1.7.1/lib/active_record/connection_handling.rb:327:in `retrieve_connection'
  /opt/zammad/vendor/bundle/ruby/3.0.0/gems/activerecord-6.1.7.1/lib/active_record/connection_handling.rb:283:in `connection'
  /opt/zammad/vendor/bundle/ruby/3.0.0/gems/activerecord-6.1.7.1/lib/active_record/core.rb:490:in `cached_find_by_statement'
  /opt/zammad/vendor/bundle/ruby/3.0.0/gems/activerecord-6.1.7.1/lib/active_record/core.rb:386:in `find_by'
  /opt/zammad/app/models/application_model/can_lookup.rb:29:in `lookup'
  /opt/zammad/lib/sessions/client.rb:36:in `block in fetch'
  /opt/zammad/lib/sessions/client.rb:25:in `loop'
  /opt/zammad/lib/sessions/client.rb:25:in `fetch'
  /opt/zammad/lib/sessions/client.rb:9:in `initialize'
  /opt/zammad/lib/sessions.rb:579:in `new'
  /opt/zammad/lib/sessions.rb:579:in `thread_client'
  /opt/zammad/lib/sessions.rb:534:in `block (3 levels) in jobs'
When the Error Occurs, only a restart from Zammad can solve the problem.
I’m Happy to provide more Information, actually we have to reboot our Zammad nearly 3 to 4 Times a day to keep it functional.
Sometimes with the loss of Not sent / Dropped Emails.
If anyone have an idea whats wrong with our Instance that would be awesome.
Thanks
Moritz
Have you increased the max_connections of psql? The default is 100 and not enough for Zammad.
