MANU007
February 28, 2019, 6:03am
#1
Hello, is there any way to query Counter in Zammad?
I want to create a dashboard similar to Icinga2 (https://github.com/dnsmichi/dashing-icinga2 ). The dashboard is based on http://dashing.io/ .
The dashboard should run on an Ubuntu or Deabian system.
Conceivable curl - queries if that is possible with Zammad.
Interesting would be the following values:
-Number of all open unassigned tickets
number of all escalated tickets
-Number of VIP tickets
and other individual such as Number of all open Icinga tickets …
The API should be perfect for you needs, you can find further information here:
https://docs.zammad.org/en/latest/api-intro.html
You could also use elasticsearch for that needs.
I user Grafana and to count closed here is the example code
Select concat(firstname, ’ ',lastname) as metric, count(t.state_id) as value, now() as time
from tickets as t
join users on users.id=t.owner_id
where t.state_id = 4 and age(now(),t.close_at) < ‘12 hours’
and users.id != 1
group by metric
hope that helps a bit
backba
March 6, 2019, 4:01pm
#5
Im new to Grafana and not that good at SQL, but tried your query it seem to be quite empty…?
Query looks OK, so have I missed something?
Thanks!
Magnus
did you connect to the zammad database using the postgress database connector snap in ?,
that would be the only reason i can think off unless you have different state IDs should just work,
i also use a pie graphs
backba
March 7, 2019, 9:15am
#7
Really nice graphs, I want that to
Yes, im using Postgress also. Think my problem is probably not the query, more likely how I should configure Granfana. I will do some deeper investigation.
Thanks for the inspiration!
system
closed
July 5, 2019, 9:15am
#8
