hello,
I install Zammad deb version 3.1.x.
I configure zammad chat.
Then I add these lines at the end of the page’s source code before the body closing tag.
Files:
/opt/zammad/public/assets/chat/znuny.html,
/opt/zammad/public/assets/chat/znuny-no-jquery.html,
/opt/zammad/public/assets/chat/znuny-no-jquery-open_by_button.html,
/opt/zammad/public/assets/chat/znuny_open_by_button.html
But chat-box not found.
What is my wrong?
Please help me.
Thanks
Zammad does not have an internal chat.
You can find an howto use here:
https://admin-docs.zammad.org/en/latest/channels-chat.html#configuration-of-the-chat-widget
Spoiler alert This is not for the Zammad-WebApp.
Thanks for reply,
I follow your link and configure like that. But not work. Please again check my configure.
kindly help me.
Where do you try to embedd the Zammad chat in?
Your own website?
Ensure that at least one chat agent is active, other wise the Chat won’t open/load.
Also ensure via developer tools that the widget is being loaded.
Hostname: pc1.example.com
nginx config file:
cat /etc/nginx/sites-available/zammad.conf
upstream zammad-railsserver {
server 127.0.0.1:3000;
upstream zammad-websocket {
server 127.0.0.1:6042;
server {
listen 80;
server_name pc1.example.com;
root /opt/zammad/public;
client_max_body_size 50M;
expires max;
location /ws {
proxy_http_version 1.1;
proxy_read_timeout 86400;
location / {
proxy_read_timeout 300;
gzip on;
gzip_proxied any;
and I added these lines at the end of the page’s (znuny.html, znuny-no-jquery.html, znuny-no-jquery-open_by_button.html, znuny_open_by_button.html) source code before the body closing tag
I wish any user will login http://pc1.example.com/
he will find chatbox.
But any user not find chat box.
Is show like this image:
What is my wrong? I need help .
Thanks all
abu.sayeed:
Thanks all
Okay, again:
It is not possible to add a chatbox for customers or in between agents within Zammad .
The Chatbox is intended for external websites which are not the Zammad WebApp.
system
Closed
November 8, 2020, 10:55pm
7
