Zammad/apache2 behind HAproxy?
  • Used Zammad version: 6.1
  • Browser + version: Firefox, Brave
  • Site loads
  • ERR_TOO_MANY_REDIRECTS
1- Cname zammad’d FQDN to HAproxy
2- Config haproxy.cfg
3- Flush cache
4- Browse website
Does anyone have experience with zammad behind HAproxy?
Cheers
I have zammad running behind haproxy but not for load balancing but as a simple proxy with SNI for routing decisions. What are you trying to accomplish?
That’s my working config. Keep in mind that the ssl certificate ist provided by the zammad vm and not haproxy:
global
        maxconn         5000
        ulimit-n        16384
        log             127.0.0.1 local0
        uid             99
        gid             99
        daemon
defaults
  timeout client 30s
  timeout server 30s
  timeout connect 5s
  log global
  option tcplog
frontend www
  bind *:80
  mode tcp
  default_backend www
frontend www-ssl
  bind *:443
  mode tcp
  tcp-request inspect-delay 5s
  tcp-request content accept if { req_ssl_hello_type 1 }
  default_backend cloud
# Using SNI to take routing decision
backend cloud
  mode tcp
  acl support req_ssl_sni -i FQDN_of_my_zammad_instance
  use-server server1 if support
  option ssl-hello-chk
  server server1 internal_IP_of_my_zammad_instance:443
backend www
   mode http
   acl support hdr(host) -i FQDN_of_my_zammad_instance
   option forwardfor
   server server1 internal_IP_of_my_zammad_instance:80
